Results 1 to 6 of 6
Thread: Ironhead Servicar questions
    Feb 2011
    Madison, Wi, USA
    Default Ironhead Servicar questions
    Hi all, new to the forum. I go by OX. anyways...
    I am in the saving and planning stage of my build and was looking for specifics. To start I have a 1000cc Ironhead powerplant. I am going to get a hardtail servicar custom made to fit an ironhead engine.
    The thing i was wondering is what rake do you all recomend I have him make it?? stock servi car rake is 23 degrees... Also have any other frame recomendations you can give me before i put my deposit down and ok final plans.....????
    Cheers
    OX
    Jun 2010
    Coram, NY USA
    Default Re: Ironhead Servicar questions
    No recommendations, but welcome Ox and greetings from Long Island. Good luck with the build.
    300+ Posts vw driver's Avatar
    Jan 2014
    Tacoma, WA USA
    I had a Servicar 45 flat-head trike back in the '80s. The frame was stock with Sportster forks and triple trees. It had a stock rake although I never measured it but it handled good, no issues with wobble or flop and it went down the road straight, cornered good too. I've kicked myself in the head a hundred times for selling it but I was younger then and preferred two wheelers.
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Welcome glad you joined us. Sorry no help with your question, but sure the Harley guys can help you out. RIDE SAFE
    30+ Posts
    Jan 2014
    Colgate,Wisconsin, USA
    I have built one just like you discribed It was a 66 frame and a juiced out 75 1000 cc motor The neck on the frame was shorter for the triple tree and I put in spacers above the bearing To do over I would make sure the treads on the triple tree matched the tube Rake depends on length of fork tubes My tubes were 4 inch over Have a picture but never checked on rake With tubes like this I would suggest around 30 degrees but would check with someone else When finished it looked very good Hope this is a help
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Ox_clauson View Post
    Cheers
    OX
    rake is not as important as the trail you end up with...
    you might be okay with 23 deg i would think that would be border line
    personally i like about 1.5 - 2.5 inchs of trail i feel much over that becomes more of a chore than a joy for a long ride... so you may want to look at a set of raked trees as well....
    depending on what sort of riding you plan on doing and spending $ to have a custom made frame you might want to consider a different motor
    just my 3 pennies worth
    stace
  1. 1973 Servicar Diff
    By Rocketman 3 in forum Harley Trike Conversions
    Last Post: 01-22-2018, 04:50 PM
  2. New guy questions
    By Dennis Murawski in forum Enabled Trikers
    Last Post: 08-01-2013, 08:03 AM
  3. 1970 ironhead chopper
    By oneup in forum 2 Wheelers
    Last Post: 02-18-2013, 08:05 AM
  4. New here. Have questions please....
    By ParrotLady3 in forum Harley Trike Conversions
    Last Post: 09-02-2011, 01:34 AM
