Likes Likes:  1
Results 1 to 6 of 6
Thread: Lehman Monarch I Rear Shocks
    5+ Posts Fleecemaster's Avatar
    Jul 2012
    Wright City
    Default Lehman Monarch I Rear Shocks
    I have an 04 GL1800 with a Monarch I conversion and need new shocks. Does anyone know what can be used other than the Lehman LS0600?
    Apr 2010
    Shenandoah Valley of Virginia
    Quote Originally Posted by Fleecemaster View Post
    Take one and measure eye to eye center compressed and or extended and contact Progressive Suspension, they likely need them. It's what came on my Lehman GTL except mine's on a GL1500
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    The Monarch I uses a pair of LS0610 shocks. The bottom eye is offset.
    I have spoken to Progressive to try to get a breakdown of their dampers and springs used on the Lehman Trikes. I have given them numbers and they continue to forward me to Lehman/Champion for the prioritized parts. I have bought shocks that I thought were right only to find out they were wrong. I have taken various shocks apart, swapped springs, swapped dampers, it is no easy fix to get the exact combination. They are 13.5" shocks with 70mm of travel and 140/190 springs. The eyes are 16mm sleeves. Just can't find the right combination and I am out of my old supply.
    Jim Murphy
    Iron Butt Rider 2001
    Apr 2010
    Offset Eyes?
    WOnder if that's a change from M-1 from earlier GTL? Mine look "normal" but I've not had one off on a bench to examine close?
    Martinsburg, WV
    I am pretty sure the GTL and Commander models used the LS0600.
    Jim Murphy
    Apr 2010
    Now I'll be lying under it and checking it out .....
  1. Rear tire sizes for gl1800 lehman monarch ii trike
    By Motogordo in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-24-2016, 10:23 AM
  2. 2003 Lehman Monarch II
    By CyberVet65 in forum Lehman Trike
    Last Post: 12-05-2015, 06:20 PM
  3. Germany need your help, Lehman Monarch
    By ramon in forum Lehman Trike
    Last Post: 11-24-2012, 07:47 PM
  4. Lehman Monarch II rear shock actuator
    By Mick in forum Lehman Trike
    Last Post: 04-21-2012, 11:47 AM
  5. Lehman Monarch II rear suspension
    By bette in forum Lehman Trike
    Last Post: 10-07-2010, 10:22 PM
