Results 1 to 12 of 12
Thread: Rear Wheel Fitment Guide
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Default Rear Wheel Fitment Guide
    I am putting together a rear wheel fitment guide for all makes and models of trikes. I need wheel size, offset and bolt pattern. If you know yours please post it here.
    20+ Posts Ron H's Avatar
    Feb 2008
    Northern Virginia
    Default DFT Fitment
    DFT Trike, (same for all Harley's)
    Wheels:
    16x7 5.5-in backset, 205/55-R16 or 215/60-R16 tires
    or
    18x8 6-in backset, 225/45-R18 tires
    5x100 bolt pattern
    1.5x12 lug nuts
    2007 Harley FLHX Street Glide
    DFT Smoothie Trike Conversion
    Champion Reverse
    Zumo 550
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    Default ron
    Ron-
    Great info-Thanks for adding. They aren't all the same due to the rear end setup, differing hubs the manufacturers use and the width of the fenders in relation to the hub. I will be adding the Motor Trike and Champion specs on all their models. I would ask that if anyone else can ad other manf specs I would really appreciate it. I will make a chart and add it here for all to access in case they want to change wheels in the future.
    20+ Posts QC Goldwinger's Avatar
    Apr 2008
    Quincy, IL
    Smile California Side Car
    I can give you the info from the trike specification brochure. It says for wheels, 15 x 7in, 5 on 100mm bolt pattern, 4.75 in back spacing.
    500+ Posts
    Feb 2008
    Planet Earth, Alpha Quadrant
    Quote Originally Posted by Bazooka View Post
    Motor-Trike Spyder 2+2
    Wheel size: 15 x 7
    Offset: 4-1/2 - (Critical)
    Lugs: 5 Lug on 4-1/2 - (5x114mm
    5+ Posts jack's Avatar
    Feb 2008
    Silver Springs, Fl.
    2001 Lehman GTL kit
    Lehman Wheel Information
    Did some measuring of back spacing, etc. They have the same 15" x 7" width and back spacing as the wheels found on my 1985 Thunderbird with 10 hole Ford 15x7 alloy wheels. It's "4 on 4 1/4"" or "4 on 4.25" pattern. Back-spacing is pretty darn near 4" (of the 7 between rim flanges) inside (brake side), with 3" outside the mounting surface. (near 13 mm positive offset as it's deeper on the brake side, offset is how far the wheel center is from the mounting surface while back-spacing is how much of the wheel's width is found to be on the brake or inside ... two differeing terms used to measure the same thing)
    Most of the early Mustang GTs used this pattern as well as T-Birds 80-88, Pintos, and Mercury counterparts. Many wheels out there to fit. Just don't go too deep.
    [SIGPIC][/SIGPIC]Jack & Jolene Huddle
    On 2000SE Lehman GTL
    Out of Silver springs,FL.
    Home of the "Chip Gard" Fender Protection Film
    & Accent LED lighting.
    Member Hines Wing Group
    10+ Posts ka1ogk's Avatar
    Feb 2008
    North Easton,Mass
    CSC here 15 X6.5 5 on 100mm 4.5" Back space
    20+ Posts
    Apr 2008
    Canada
    Default Trike rims size
    Lehman Commander trike kit on 2000 SE wing, Rims 14 x 6 x 4.25 x 4 with zero offset on rim. Roger [GYMPY]
    One Of The Origionals
    TOI - New England
    John Luciano's Avatar
    Mar 2008
    Conn
    Would be nice if we could add what car rim would fit . I noticed JACK added that.
    20+ Posts
    Apr 2008
    Canada
    Default Rims
    John. Jack mentioned the cars that these rims come from. The same applies for the rims on the Lehman Commander kit. Discount Tires have these rims in stock or can order them. I know as I put a new set of rims and tires on the trike last winter. Fall and spring put a hardship on the rims as they started to rust even with a lot of wax on them. Tires were not worn down but the rubber was drying out and had side wall cracks. They also were sliding when applying brakes hard, traction gone and hydroplaning in the wet weather. GYMPY
    Sep 2010
    Defiance, Ohio USA
    Default Re: Rear Wheel Fitment Guide
    I sure wish someone could give me wheel choices for my 1500 csc trike because i hate the look of there hummer wheel but havent been able to find anything other than its darn hard to find something for a 4/bolt rotor what were they thinking with this design?
    750+ Posts
    May 2009
    Down South
    I second Jack's answer. My 2001 Lehman Renegade uses the same bolt pattern (4 x 4.25/4 x 108mm), etc. I think it's great because we have a large choice of wheels from the older fox-bodied Ford line-up. It took me a while before I could actually admit it...but yes...the Pinto is in-the-mix as well.
    These will run anything from a 245 on down to a 195 tire. I recommend the same one that is on the stock TG...205/65R15. Anything much larger is a real problem to get out of the fender-well and the smaller tires seem to handle much better, especially in the rain.
  1. Front Wheel--Rear Wheel
    Last Post: 08-06-2015, 12:45 PM
  2. Rear wheel play
    By RobertW in forum Honda Trikes
    Last Post: 08-18-2013, 05:51 AM
  3. Mototrike rear wheel cylinders
    By polarsue in forum Motor Trike
    Last Post: 01-23-2013, 10:14 AM
  4. Rear wheel conversion?
    By oldladytriker in forum Tires, Wheels, Brakes, Front End
    Last Post: 11-20-2011, 07:15 PM
