Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Grandpot9tourmanHonda TrikesFront tire?
AriNV13Marc HNew Member Introduct...New to trike
Burnerboy4pawsRoadsmith Trikes
Too Pa Pa Zook
AriNV13Uncle FesterNew Member Introduct...New to trike
Jack Klarich2Jack KlarichGeneral DiscussionMY first guitar
Jack Klarich2ZammyGeneral DiscussionMY first guitar
Too Pa Pa Zook
Hdsteal4Jack KlarichSuzuki - Kawasaki Tr...Completed MS Trike Pics
Noodles1078Jack KlarichHarley Freewheeler /...Very Nice Gloves
Likes Likes:  1
Results 1 to 6 of 6
Thread: Headlight adjustment
    800+ Posts Motorcycle Mike's Avatar
    Jul 2014
    Lawrenceville, Ga
    Default Headlight adjustment
    I pulled the trike out of the garage at 04:30 this morning to ride to work. As I'm leaving the neiborhood I realize the only lights hiting the road are my passing lights. The headlight is illuminating the roof tops.
    No problem I think, I'll just adjust them down with the knob under the fairing. Wrong! Before the light gets anywhere near the road it bottoms out and starts pulling it to the left.
    No doubt this is caused by rakeing the front end.
    I'm sure I'm not the first to run into this. What did you do to fix it?
    You don't quit riding because you get old.
    You get old because you quit riding.
    Mike & Shirley
    Jun 2010
    Indianapolis, In.
    Default Re: Headlight adjustment
    I'd go see the installer, if that's possible!
    The ride height should have been reset when the rake kit was installed, as well as the headlamp aim being correctly set.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    150+ Posts
    West Bloomfield, Mi
    The rake should have lowered the aim. Split the fairing and check that all headlight mounting points are correct and fasteners are tight. Turn the adjuster while watching to be sure nothing is stopping it from going lower. Ours is raked and we have no problem with light aim.
    Jun 2010
    Indianapolis, In.
    If it has been this way since day 1, I would see the installer! Sounds like something may not have been R&R'd correctly during the rake kit install
    I'm not clear if the Yamaha's have a motored adjuster or not? My Wing does and I set the control knob in the center position and then adjusted the headlamps using the manual adjusters. That allows me to correct the aim with different "loading" of the trike by using the motored controller.
    Ragtop is correct. If nothing else changed and the ride height was not corrected, adding a rake kit should have lowered the aim!
    Patriot Guard
    Was a LEO
    Jul 2014
    Lawrenceville, Ga
    It was definatly aimed up.
    There is another adjustment on the right side I didn't know about. It's a long bolt with what looks to be a 10mm head on it. It is also cut for a phillips screw driver. Working back and forth between this and the knob on the left the light came down to where it's supposed to be.
    Thanks!
    Mike & Shirley
    300+ Posts Cougar's Avatar
    Mar 2009
    Near-Iowa City,Iowa
    I made spacers for my light. after the rake it the beam was way to high for me as well.
    the bike adjustment screws did not bring it down far enough for me.
    you could use washers as well.
  1. Headlight Modulator
    By 87Trike1200 in forum Accessories
    Last Post: 01-18-2014, 10:50 AM
  2. Headlight ?
    By howardg in forum General Discussion
    Last Post: 09-08-2013, 02:00 PM
  3. Headlight
    By clo in forum Honda Trikes
    Last Post: 02-06-2013, 05:51 PM
  4. Headlight modulator
    By RobertW in forum Honda Trikes
    Last Post: 07-13-2012, 09:02 AM
  5. Headlight on headlight off
    By dano2005 in forum Honda Trikes
    Last Post: 07-08-2012, 07:00 AM
