dthorn1dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
Jack Klarich2ISP-FLGeneral Harley ChatExhaust Heat Shield
gfaltersack4ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack4Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack4DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack4gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
Jack Klarich2Jack KlarichGeneral Harley ChatExhaust Heat Shield
Likes Likes:  766
Thanks Thanks:  3
Page 39 of 46 FirstFirst ... 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 LastLast
Results 761 to 780 of 913
Thread: Anyone else?
  1. #761
    450+ Posts
    Mar 2018
    Fernley
    I just love how clean everything looks. Bummer that you have to open it up, but at least you get to look over everything involved and see if anything else is showing signs of stress. A chance to build it up stronger, that is some horsepower you have cranking it all.
  2. #762
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    hopefully case and shafts are good? Good luck! Always a bummer when something fails.
  3. #763
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    It did not do a major blow out.
    Trans still functioned just not correctly.
    Everything should still be good except for whatever is the failing part.....hub....thrust bearing...ect.
    This was not a rev it up and dump the clutch thing like drag racing is.
    More a gentle accel the drum in 1 and 2.
    Get into 3rd and get it stable and at an rpm you think you can start at without bogging. Basically as slow as you can go in 3rd without chugging and pinging. Get stable aaaand....start recording......and nail it. No jerk, dump, snatch.....just as hard as it will dead pull.
    Computer calculates the rate of acceleration of the heavy rollor.
    I spun it 132mph in third gear.
  4. #764
    700+ Posts vwbug72501's Avatar
    Apr 2015
    Batesville, AR. 72501
    Time to think about tire speed ratings? Don't want a tire exploding even on the dyno.
  5. #765
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    All 3 are 130mph rated tires.
  6. #766
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    I have the gear stack out and on the table.
    Not yet tore down. Just by a visual inspection it looks like 3-4 hub and/or slider is not round.
    The big thing is both brass syncros are broken into several pieces.
  7. #767
    18000+ Posts
    Tech Contributor
    Jack Klarich's Avatar
    Oct 2016
    Jax, Fla USA
    Ouch, broken synchros, that is going to hurt
  8. #768
    Jun 2016
    milnor n.d. usa
    could it be a shaft bending under load , or a worn hub/gear tooth profile allowing the partial disengagement in
    3rd gear? doesn,t sound like it popped out of gear, but some sleeve or bearing allowing 3rd gears/hubs to rattle around?
  9. #769
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    It looks like the hub twisted.
    It is not as hard as a gear.
    The gears and shafts will take it.
    The syncro hubs are what connects the gears to the shaft.
  10. #770
    Jun 2016
    milnor n.d. usa
    hopefully there are stronger hubs available.....I had thought that a loose pocket bushing/bearing or loose countershaft front bearings, or worse yet spreading case bores could let the 3rd gears get loose....a bad hub is actually maybe the best news you could get!...at least that would explain the broken syncronizer I suppose with a direct 4th gear tranny 3rd is the weakest gear, but the gear that catches most of the grief....just the way it goes...good luck...hope you can make it stronger!
  11. #771
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    4th gear is not 1 to 1.
    Mine is .82 to 1
    Most normal is .89 to 1
    Third and fourth are both aftermarket gears.
    First and second are stock vw gears.
    The output/pinion shaft is aftermarket splined shaft to do away with the keys.
    It looks like I put a replacement "heavy duty" aftermarket hub and slider assembly on 3-4.
    After talking to a race trans builder I have been told that that heavy duty unit is half junk. Said the slider is excellent but the hubs were soft. A stock hub would be better.
    I think I am gonna put it back together with a German hub, the hd slider, and new syncro rings.
    Now to dig in my junk pile for an original keyed 3-4 hub. Then buy some new brass parts.
  12. #772
    Jun 2016
    milnor n.d. usa
    Just familiar with old school transmissions. Good to hear there was minimal damage. I suppose stock hubs have some heat treatment, whereas aftermarket, who knows what material and heat treatment?
    Are they a cast steel item, then internally and external broached?
    Anyway you've found the weakest link in the chain.
    Good luck on your way back together.
  13. #773
    Jun 2016
    milnor n.d. usa
    looked at the vw transmission diagrams this am. I am assuming the reason that the vw 4th or top gear is gear driven instead of coupled, must be that the power flow must take a 180 deg turn whereas in our conventional transmissions power flow is straight thru. Hope I am on the right track....lol I try to do my heavy thinking in the morning!
  14. #774
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    That is basically it.
    Good thing is that it can be changed to different ratios.
  15. #775
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Muncha Buncha
  16. #776
    Apr 2015
    Ouch!!!
  17. #777
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    3-4 hub is not round anymore. These broke rings are just collateral damage.
    I tore down another core.....and not happy with the rings in it either.
    But the hub was real nice.
    I thought I was going to scrounge up some parts and put it right back together. Just ain't working out that way. Looks like I will be ordering parts.
  18. #778
    450+ Posts
    Mar 2018
    Fernley
    Default Bummer
    Not good at all, but at least you found what went wrong and have the ability to fix it.
    Never opened up a tranny yet, you were my first, wow, what a whole new world. I am not a motor head, just that person that learned what was needed to fix what was needed. I just keep finding new info on new subjects I never thought of.
    so you have to wait, yet so that you fix it.
  19. #779
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Yeah....I am just gonna replace this weak link and see if it holds up.
    This trans is far far from stock. It has some hp parts in it already. It just was not built or heavily worked on this time around.
    I built it with the original build of the trike. And then did not like the gear ratios and took it back apart and changed a lot of parts. Not because of broken but to up gear it more.
    I changed 3 and 4. I also put a new hub assembly in for them. Now years later I find out that the hub in that assembly is weaker than stock.
  20. #780
    Jun 2016
    milnor n.d. usa
    years ago....like 45+ a guy at work, who ran vw's said you needed special fixtures to work on and assemble these transmissions, for that reason he just swapped with good used trannys. Any truth to the fixture business?
