dthorn1dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
Jack Klarich2ISP-FLGeneral Harley ChatExhaust Heat Shield
Jack Klarich2Jack KlarichGeneral Harley ChatExhaust Heat Shield
Likes Likes:  766
Thanks Thanks:  3
Page 42 of 46 FirstFirst ... 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 LastLast
Results 821 to 840 of 913
Thread: Anyone else?
  1. #821
    Dec 2014
    Grand Junction, Co. USA
    Sounds really good
  2. #822
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Sounds really good
    On the vid Ride Home you can tell a little.
    When I start off 1st and 2nd get revved to just barely on the cam.
    The tone starts to change around 3000rpm and is starting to talk at 3500. I pulled 1 and 2 to around 4500. So just a little of on cam talk. You do realize this is a 7500rpm motor and there is a lot more to go. I rarely get it up that high in normal driving. What your see there in Ride Home is pretty much my normal hot take off. I like to hear it turn on and right after it turns on I stick the next gear.
    I could drive around and never even get to the cam turn on point.
    The Natchez Trace vid is at a low gurgle for the 50mph speed limit there. You can not hear the engine over the wind noise.
  3. #823
    Dec 2014
    Hmmmm ... maybe getting on the cam is affecting your MPG's ... although, I'm fairly certain you didn't build this for economy ...
  4. #824
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    I don't know what would make you think that.
  5. #825
    450+ Posts
    Mar 2018
    Fernley
    Cherry Bomb, that is what hit me this AM as I looked at the last post, just an awesome Trike Rex.
  6. #826
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Did you see a few pages back where the work guys named it?
    They started calling it Reba and I tryed to get Jessica......but.....Reba stuck
    Name:  2DFDE3D100000578-3298724-The_real_Ms_Rabbit_The_cartoon_became_a_symbol_of_silver_screen_-m-111_.jpg
  7. #827
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    I'd agree, Reba when parked....but Cherry Bomb when the pedal hits the metal!
  8. #828
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Went and rode with my little sister today (her birthday)
    I guess the whole time we were riding away from the rain. Did get her home before getting wet. Did have to turn around and go a different route.
    But I was not so lucky. Was still 20 miles from my home. Almost the whole way in a good hard rain.
    Scooter handled it though. The electronics are not all waterproof. But everything stayed working while wet.
    It did wet me down good through. Looks like the rooster tail from the front tire goes straight onto the crank pulley and it in turn makes a circular spray right across the calves.....filled my shoes up.
    It is scary loose on the back end though, feels solid but just a touch on the throttle and it is spinning. The skinny front seemed to stay hooked up and steerable.
  9. #829
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Here is an interesting one.
    Stopped on the side of highway to start some pocket video.
    So putting along in second waiting on a car to pass by.
    Well he got over to let me in.
    I give it a squirt of gas.
    And then he starts coming over on me.
    I back off and go around him on the far side.
    I suppose he did not expect the to instantly be at 60mph (rural highway speed here).
  10. #830
    Dec 2014
    It do bark a tad.
  11. #831
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Cleaning up again....after getting caught in the rain a while back.
  12. #832
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Makes me giggle to left hand stick shift the murdercycle.
  13. #833
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
  14. #834
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    I burst my second oil cooler this weekend.
    I dont understand why though.
  15. #835
    450+ Posts
    Mar 2018
    Fernley
    wow, that is not cool. Could it be a flaw in the unit, did you change brands or use the same type when you changed them out ?
    Did the blow out occur in the same area on the cooler ?
    What a mess, no I do know much, just throw out some questions trying to help. Most would say to much pressure for the cooler, or that a stuck solenoid on the return line causing to much pressure in the cooler.
    Oh I should have said " my mind would have said those things to myself".
    Not good Rex, and I am sure you have thought and went over many things with the first blow out. Your knowledge of what you did to that engine, wow, it just blows me away.
    My mind is going nuts know wondering what caused it to blow out, here to learn all that I can.
  16. #836
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    I know right......
    Same set up as I have had on it for lots of years.
    I did add to or hang more stuff off the bottom mount lugs. Maybe I have put more vibrations into it.
    The first one that sprung a leak I blamed on myself. When I first cranked up the engine the oil pressure was too high. So I thought I had put some damage to it then and it began to leak a short while later.
    This one has not had that happen. All good and then leak.
    So the only change is the extra stuff on that mount. The cooler is rubber mounted but maybe it is too stiff now?
    I am gonna make a bypass something so I ain't down. But I have found me a block of aluminum and may just whittle out a billet unit. Probably will not shed the heat like it should but I may try and see. My oil still is not hot anyways.
  17. #837
    450+ Posts
    Mar 2018
    Fernley
    I like how you said that Rex. I say "I can whittle that" with wood a lot, yet you say it with metal, just blows me away how different the two are, yet so much seems to be the same process, just different tools and machinery..
    I do hope you can find what you need to make your bypass. Safe riding.
  18. #838
    700+ Posts vwbug72501's Avatar
    Apr 2015
    Batesville, AR. 72501
    Quote Originally Posted by DeathBySnuSnu View Post
    Details details.
    Attachment 48124
    You still running this setup? Did the cooler crack by the regulator? Just a thought, but that large of a mass hanging off center would definitely vibrate and resonate to cause stress fractures. How about a brace from mounting holes on blue block to cooler? That should dampen any resonance. Just my $.02
  19. #839
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Sorta kinda, but not really.
    Lower and right of center for both of them.
    I am thinking that regulator although it itself is light but with the added tension of the hose adding to it.
    Maybe that reg and stack of fittings is more of a lever on the cooler. Then that hose is so short. But then the hose takes to the shape after a couple heat cycles.
    I dunno......just thinking that short hose is pushing/pulling on the regulator with its stack of fittings.
    Wow what a rambling diatribe.....
  20. #840
    Jun 2016
    milnor n.d. usa
    assuming the break is where circled in yellow....looks like cooler mount is about 2 inches above the leak? Kind of midway between reg. and mount.....vote for the stress break, might have to have separate reg and cooler mountings and use very flexible hoses. but where to put them?
    I know you will figure it out.
