Likes Likes:  738
Thanks Thanks:  3
Page 87 of 89 FirstFirst ... 37778586878889 LastLast
Results 861 to 870 of 884
Thread: Anyone else?
  • Thread Tools
  1. #861
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    User ID
    7688
    Mar 2012
    Vicksburg MS USA
    FT Author
    2 Threads
    Yes that is a bought add on sump that bolts up to the bottom of the case.
    I have been looking at cutting it down in size/depth.
  2. #862
    400+ Posts LarryA's Avatar
    User ID
    23068
    Jun 2016
    milnor n.d. usa
    nice looking cooler that you made....assuming you will use both, the new cooler and sump?
  3. #863
    550+ Posts vwbug72501's Avatar
    User ID
    18630
    Apr 2015
    Batesville, AR. 72501
    I seem to remember somewhere in your build thread that you were addressing some undercarriage speed bump road rash due to low clearance. How are you going to address the additional thickness of an underslung deep sump?
  4. #864
    VW Tech Contributor
    TrikeTalk Moderator
    User ID
    7688
    Mar 2012
    Vicksburg MS USA
    FT Author
    2 Threads
    Yep.
    That is the problem. No real place for it to be.
    I do have it up a touch higher this time around and have not had any clearance problems at all this time.
    This sump would have to be cut down a lot.....if it would even work at all.
    This is just an idea out of my junk pile......thinking of something else in the wind cooling oil.
    I am gonna hafta get back interested in working on the thing.
    I had gotten serious about tuning and was doing some hard cranking on the throttle. I found a couple small problems and was making it somewhere. Then the first cooler started leaking. Once I got it back together from that.....I have done nothing but ride. It is reasonable close on basic tuning. I really need to do some colder weather tuning.
    Just have not been interested in a while.
  5. #865
    User ID
    18630
    Apr 2015
    Sounds like you need a little inspiration:
    This is one of my favorites.
  6. #866
    VW Tech Contributor
    TrikeTalk Moderator
    User ID
    7688
    Mar 2012
    Vicksburg MS USA
    FT Author
    2 Threads
    Still have not worked on it any. Well I think I finished making that oil cooler a while back, but still not on there.
    Rode a little yesterday.
    The weatherman said that winter is scheduled for a day this upcoming week.
  7. #867
    User ID
    23068
    Jun 2016
    milnor n.d. usa
    Default no trike rides for me!
    afternoon high.jpgafternoon high, afternoon.jpglooking out my shop door....colder tomorrow! come on spring!
  8. #868
    VW Tech Contributor
    TrikeTalk Moderator
    User ID
    7688
    Mar 2012
    Vicksburg MS USA
    FT Author
    2 Threads
    We had winter last night.
    Schools closed today.
  9. #869
    VW Tech Contributor
    TrikeTalk Moderator
    User ID
    7688
    Mar 2012
    Vicksburg MS USA
    FT Author
    2 Threads
    Making a few small adjustments to the syncronization of the throats and the idle air valve.
    Then next is to get the billet oil cooler on there and the oil changed.
    Then more tuning......
  10. #870
    VW Tech Contributor
    TrikeTalk Moderator
    User ID
    7688
    Mar 2012
    Vicksburg MS USA
    FT Author
    2 Threads
    On a side note.....maybe this should be added into the tech thread.....but anyway....
    About the front end. By using the chopper builders handbook for a knowledge reference, plus some experience. This skinny tire works just fine. No head shake. Easy stearing, one hand driving. All this with less than an inch of trail. It even steered well in the rain. I have enough power I can push the front end around and the back end is crazy loose in the rain
    So bottom line.....you can make it work....just takes some geometry and a bit of math.
    Some pics I found on the internet......
Bookmarks
