Likes Likes:  1
Results 1 to 8 of 8
Thread: Needing a leading link front end for my vw
    Oct 2014
    West Monroe La
    Default Needing a leading link front end for my vw
    I have a vw trike that is coming together nicely but I need a front end to finish it off I have tried in town but everyone says they will do it but it's been 3 months and no front end
    5250+ Posts Pegasus1300's Avatar
    Spring City,Utah, USA
    Default Re: Needing a leading link front end for my vw
    I am at work right now, but I have a website that I found in a google search for such a front end. When I get home I will look it up. It gives you the plans to make one yourself. In the mean time you can do a search for an "Earles Type Front end" That is their official name. there are a couple of companies in England that make them to order and one can be had with a wheel that will accept a car tire. They are expensive and then there is the shipping but it is a thought. Good Luck
    Happy TRAils/NSD
    Paul
    Oct 2014
    West Monroe La
    Yeah I have seen the plans to build it but don't trust my welding on important stuff lol I will look at earls thanks
    Here is one of the sites I found who makes them
    http://hedinghamsidecars.co.uk
    Happy TRAils/NSD
    Paul
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    I plan on making my own front end for my vw trike. My progress is very slow but whatever I learn I will pass on to you.
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Sounds like you are making progress. Good luck and keep us posted. RIDE SAFE
    20+ Posts carcentric's Avatar
    Jun 2015
    Seattle area
    Quote Originally Posted by carlpaulman View Post
    I'm planning to use a variation of Robert Q. Riley's Trimuter design - it's a lot simpler than an Earl's and the top of it can be a lot lower.
    Here's a pic:
    I'll be using a round tube for the crosspiece right under the neck because it's easier to drill at an angle in round. For a spindle/brake, I'm going to try a Super Beetle - same wheel bolt pattern as my rear wheels so all three can match (from the driver's side at least).
    If anyone's built one, or has the plans, I'd like to ask some questions.
    My project:
    http://www.carcentric.com/Les.htm
    450+ Posts irmagoo's Avatar
    Dec 2012
    washington il.
    I think you will enjoy the process,, I have been working on mine for while the only thing I am not to happy with are the shocks- at this time i have a set of hd ultra rear air shocks mounted on mine and at the angle they are mounted I think the spring rate of 1 shock would be to much- guess i'll wait and see- don't want harsh ride !! ,,,
    mike aka magoo
  1. leading link front end
    By stevie in forum Home Built Trikes
    Last Post: 09-30-2014, 01:42 PM
  2. My New Leading Link Front End
    By Shadowlord in forum VW Powered Trikes
    Last Post: 05-20-2013, 08:52 AM
  3. LL front end build (leading link)
    By redneckray in forum VW Powered Trikes
    Last Post: 04-28-2013, 08:07 AM
  4. leading link front forks
    By stevie in forum General Discussion
    Last Post: 01-29-2013, 09:34 PM
  5. Need help with my steering (Leading Link) forks...
    By TrikerDawg in forum General Discussion
    Last Post: 07-25-2010, 02:46 PM
