Results 1 to 8 of 8
Thread: Replacing brake light?
    60+ Posts bohomus's Avatar
    Jan 2014
    Jackson, MS, USA
    Default Replacing brake light?
    My left brake light went out. How the heck do you replace it?
    I have a 97 1500 with a champion conversion.
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Default Re: Replacing brake light?
    On mine you remove the light assembly.Theres 2 or 3 nuts on the back of the light accessed in the wheel well area.
    1989 GL1500 Goldwing (SOLD)
    2006 GL1800 CSC
    Jan 2014
    Jackson, MS, USA
    Thanks for the response. I hate to sound like an idiot, but what tool do you use to take off the wheel cap? It looks like an allen wrench but I don't have one to fit it. Also, when I can get off the cap, what do I use to remove the tire?
    Looking into the wheel well (with the wheel on) I can't tell what kind of bolts are holding on the light fixture. It looks kind of strange but I can't see it real well.
    250+ Posts cscsonny's Avatar
    Dec 2011
    St.Louis,Mo.
    Hello,
    If,yours is similar to my CSC,they used a OEM GL 1500 light assembly and housing.You can get to the 10mm (?)nuts without having to pull wheel,however you will first have to scrape and remove the silicone sealant from around the nuts,then pull the entire housing out the back to get to bulbs just like you would do if it were a stock 2-wheel bike.Replace silicone over nuts when re-installing.
    About the center cap on your rear wheels.The allen bolt is most likely mm (mine is) however once removed,lug nuts are not mm because it is a Ford rear end.
    Found a lot of mixing back and forth between mm and standard on these kits made for earlier bikes.
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    It's best to provide a picture. My VTX Honda Champion kit has hub caps. There is a slot to inset a screw driver. Lug nuts are metric but don't remember the size. My taillight is an LED from a Yamaha. It is held on with 3 bolts. Much easier to remove the tire to get at the light.
    4250+ Posts
    Marc H's Avatar
    Dec 2011
    Evensville,Tn.
    Mine uses the lights that came on the bike.Like sonny said scrape the silicone from around the nuts and I think mine were more like a 8mm.My kit is a new kit even though its a Gl1500 bike and my wheels are like Cavie's.I'm sure different wheels have been used over the years.
    2006 GL1800 CSC
    Jan 2014
    Jackson, MS, USA
    Thanks for the responses. I got the lights replaced. Thanks for the help!!!
    Jan 2014
    Harvard
    Default brake light assembly will not slide out.
    Quote Originally Posted by Marc H View Post
    Bulb assembly will not budge.
  1. rear brake light
    By Bruce 1953 in forum Honda Trikes
    Last Post: 09-27-2014, 09:54 PM
  2. Brake Light/Blinker
    By Clell12 in forum Stallion Trikes
    Last Post: 07-28-2014, 05:06 PM
  3. auxillary brake light.,turn signal running light conversion
    By fogrider in forum Harley Trike Conversions
    Last Post: 08-25-2013, 09:24 AM
  4. replacing pads on rear brake
    By wriddle in forum Harley Trike Conversions
    Last Post: 02-14-2012, 08:03 AM
  5. Brake Light Modulators
    By Muleskinner in forum General Discussion
    Last Post: 06-26-2010, 04:14 PM
