BigN693GorillaEnabled TrikersFull length floorboards
Likes Likes:  0
Results 1 to 14 of 14
Thread: Tri-Glide Steering damper issue
    200+ Posts rayg5102's Avatar
    Nov 2012
    New Market MD
    Default Tri-Glide Steering damper issue
    My tail of woe:
    I have a 2010 HD Tri-Glide, just turned it to 15,000 miles today. If I ride at about 2-5 MPH and let go of the bars, the whole front end shakes. Went to HD today and they say the part is about $550.00, but I should check to see if mine is adjustable. There is a screw at one end.. Sure enough it's one of those damn star types. Anyway, I found a driver that fit, turned it one whole rotation and.............SNAP............... I broke the DAMN Damper.
    Two questions.........
    1. is this still rideable for now?
    2. is there a part or place I can find an aftermarket that don't cost $500?
    any other ideas?
    thanks in advance.
    200+ Posts sprinkman's Avatar
    Sep 2011
    Ashland,Ohio USA
    Default Re: Tri-Glide Steering damper issue
    Quote Originally Posted by rayg5102 View Post
    My tail of woe:
    any other ideas?
    thanks in advance.
    You should still be able to ride it. A lot out there with no damper on them take it you are not under warrenty. Can't help you with buying I would check ebay and the internet. Good Luck
    Jun 2010
    Indianapolis, In.
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    My tail of woe:
    any other ideas?
    thanks in advance.
    In the manual there is an address of a company that will rebuild it for you. Never had one done, but surely it is less expensive than a new one from HD.
    www.DKCustom.com
  6. DKCustoms postbit
  7. #6
    Contributing Member JJTRIKER's Avatar
    Sep 2009
    QUINCY,IL.
    ouch i believe they are out there somewhat cheaper than that
    Zook will fix you up with a hole new set of trees for not much more
    2014 TRIGLIDE
  8. #7
    Sep 2009
    QUINCY,IL.
    2014 TRIGLIDE
  9. #8
    450+ Posts tbear's Avatar
    Sep 2013
    Carleton, Michigan
    Quote Originally Posted by JJTRIKER View Post
    Do you know what Front Stabalizer # is used for a Triglide?
    TBEAR
    2010 Triglide Harley Davidson
    V&H Exhaust,True Duals, Big Sucker Ac,,557 S&S Cam,SE Compensator 2014, oil cooler,EBC r.brakes,Progressive air-shocks,Floorboard extensions,rear fender bras, Dynoed,krome-werks 2+2 bars, and a sheep wool butt protector....
  10. #9
    Nov 2012
    New Market MD
    when you cycle through the choices, none are for 2010 tri glides. Not sure why, or would they work anyway, might be worth a try.
    My next choice may be to find a cycle "junk" yard and try my luck there.
  11. #10
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Quote Originally Posted by tbear View Post
    # 83808-09
    2019 Tri-Glide.......
  12. #11
    5+ Posts alsdeb's Avatar
    Jul 2013
    Rye, Texas, USA
    Quote Originally Posted by sprinkman View Post
    You can also go to Pingle and get one for a drag bike that is fully adjustable. And it's a LOT less than $500!
  13. #12
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    Does your head shake at low speed go away without the damper? If not I'd be checking those head bearings / torque of head nut .... and also front brake drag left/right.
    ??? Are all HD dampers adjustable?
    Bob
  14. #13
    Nov 2012
    New Market MD
    Quote Originally Posted by HDB0B View Post
    Bob
    Don't know, have not removed it and tried what it's like without. Should try that this weekend.
    Mine is not adjustable. Thought it was..that's how I broke the screw.
  15. #14
    5+ Posts
    May 2018
    Heath, Ohio USA
    My tail of woe:
    any other ideas?
    thanks in advance.
    Yes you can ride it and never put that thing back on. I’ve built trike and never used dampers. It may share a little now and then but doesn’t hurt anything. GO RIDE 😂
  1. Steering Damper Leaking 2013 Tri-Glide
    By dfpk in forum Harley Tri Glide
    Last Post: 02-19-2014, 07:59 PM
  2. Replies: 5
    Last Post: 10-26-2011, 07:20 PM
  3. steering damper pro/con ?
    By krazybob in forum Outrigger Style Trikes
    Last Post: 10-04-2011, 12:24 PM
  4. Tri Glide steering damper
    By Tonyd in forum Harley Tri Glide
    Last Post: 05-10-2010, 07:11 PM
  5. Tri-Glide Steering Damper
    Last Post: 03-15-2010, 12:47 PM
Tags for this Thread
