Papa Zook1Papa ZookHarley Tri Glide2024 Harley Trikes Lineup - Laidlaw...
Bonsai4rhino 2New Member Introduct...New member from Texas
Bonsai4GorillaNew Member Introduct...New member from Texas
Rawhideken1714TGHarley Tri Glide2024 Tri glide
kj5ix32trike ladyHonda TrikesMotor Trike Service Manual Finished
Bonsai4trike ladyNew Member Introduct...New member from Texas
Bonsai4BonsaiNew Member Introduct...New member from Texas
Sunman4BowdenTrikeHonda TrikesF1 Warning Light
LD-Ordie10Marc HNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13ZammyNew Member Introduct...New member from FL
DrCrazyTrain4rhino 2Harley Freewheeler /...True Dual Header
LD-Ordie10ZammyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10Uncle FesterNew Member Introduct...Newbie from the Mojave Desert
DrCrazyTrain4Ron BaxterHarley Freewheeler /...True Dual Header
Burnerboy10rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
DK Custom Products362PosseRiderHarley Tri GlideWhat did you do to Your Tri-Glide T...
Sunman8PuckoachHarley Freewheeler /...Value of 2015 Freewheeler
dthorn5rhino 2Harley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack7rhino 2Harley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
hardwickbv1hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn5dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
gfaltersack7ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
LD-Ordie10ol' schoolNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17KoolbreezeHarley Tri Glide2024 Tri glide
LD-Ordie10trike ladyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie10SullyNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13SullyNew Member Introduct...New member from FL
LD-Ordie10Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17LD-OrdieHarley Tri Glide2024 Tri glide
ADSavarese13Jack KlarichNew Member Introduct...New member from FL
ADSavarese13woodyNew Member Introduct...New member from FL
LD-Ordie10LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13hardwickbvNew Member Introduct...New member from FL
SSpoon14hardwickbvNew Member Introduct...Hello from VA
ADSavarese13ol' schoolNew Member Introduct...New member from FL
gfaltersack7TFNCHarley Tri GlideDK Customs remote oil filter kit in...
ADSavarese13GorillaNew Member Introduct...New member from FL
ADSavarese13Marc HNew Member Introduct...New member from FL
ADSavarese13ADSavareseNew Member Introduct...New member from FL
ADSavarese13Phu CatNew Member Introduct...New member from FL
ADSavarese13trike ladyNew Member Introduct...New member from FL
ADSavarese13Uncle FesterNew Member Introduct...New member from FL
dthorn5nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn5TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
kj5ix32ADSavareseHonda TrikesMotor Trike Service Manual Finished
ADSavarese13rhino 2New Member Introduct...New member from FL
gfaltersack7Phu CatHarley Tri GlideDK Customs remote oil filter kit in...
gfaltersack7Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14woodyNew Member Introduct...Hello from VA
SSpoon14hogmemberisoldNew Member Introduct...Hello from VA
SSpoon14ol' schoolNew Member Introduct...Hello from VA
SSpoon14Marc HNew Member Introduct...Hello from VA
SSpoon14ZammyNew Member Introduct...Hello from VA
SSpoon14Uncle FesterNew Member Introduct...Hello from VA
gfaltersack7DK Custom ProductsHarley Tri GlideDK Customs remote oil filter kit in...
SSpoon14rhino 2New Member Introduct...Hello from VA
SSpoon14trike ladyNew Member Introduct...Hello from VA
SSpoon14SullyNew Member Introduct...Hello from VA
SSpoon14Jack KlarichNew Member Introduct...Hello from VA
SSpoon14GorillaNew Member Introduct...Hello from VA
SSpoon14SSpoonNew Member Introduct...Hello from VA
DrCrazyTrain4powerhaulicHarley Freewheeler /...True Dual Header
DrCrazyTrain4DrCrazyTrainHarley Freewheeler /...True Dual Header
Likes Likes:  12
Results 1 to 20 of 22
Thread: Push Pull Steering
    200+ Posts
    May 2011
    Orlando,Fl--USA
    Question Push Pull Steering
    I am asking for any trikers who have built
    any trikes with "Push-Pull" steering to give me their insights about that type of steering---
    Or anyone who has a thought about this type of steering.
    In Push-Pull steering, there are 2 bars that the steering rods connect to...
    A FRONT bar on the forks and a REAR bar that is around the handlebars.
    Here is the question:
    1--How is the steering changed if the FRONT bar is made longer?
    2--How is the steering changed if the REAR bar is made longer?
    3--How is the steering changed if BOTH bars are made longer?
    Basically, is the steering made easier if 1 bar is made longer (Either one) or is it made easier if BOTH bars are made longer?
    Thank you.
    Hope everyone has a happy, healthy, safe and prosperous 2015 !
    Ride safe!!! Lots of idiots out there!!!
    Mar 2013
    Little Falls
    Default Re: Push Pull Steering
    Quote Originally Posted by drumdoctor View Post
    Thank you.
    I would think it should work like pulleys or sprockets. A shorter bar at the handlebars would make the handlebars easier to turn but you would have to turn the handlebars farther to make the fork turn. A shorter bar at the fork would mean that the fork would move quicker or more when turning the handlebars but, would make turning quicker and harder. I hope this makes sense and, that I understood your question correctly.
    100+ Posts
    Feb 2010
    Pekin, IN. U.S.A.
    Short bar on the handlebars equates to easier steering however it will have less travel. The farther you go from the pivot point the more travel you will have however you will have less strength. Cheers, caveman
    VW Tech Expert Loner's Avatar
    Aug 2010
    Harvest, AL USA
    From your post:
    A: Steering would require more strength, and turning would be slower.
    A: Steering would require less strength, and turning would be faster.
    A: If changed equally, you should experience no change in steering reaction.
    We're assuming that the pivot points on each bar are at the ends.
    I personally think it advisable to work with your trail numbers to make the steering easier before you modify your pivot bars as discussed, but your method will work.
    Sep 2012
    Lakeland, FL
    Theory, longer bars more leverage? I donno, just asking.
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Loner View Post
    From your post:
    i think this is partly backwards....
    if the front bar is wider steering is slower but will be easier not harder
    also be aware that if one bar or tree is wider than the other the front to back links will bind
    did a quick layout... one tree 10 in wide other 14 in wide if the short one turns 30 degrees if i held the one side at 48 the other needs to be about 20 thou longer... it doesnt sound like much but you will feel the bind an depending on the link you will probably see it bend too
    i do aggree try to get the trail set up so you dont need to worry about the leverage on the bars
    Aug 2010
    Harvest, AL USA
    I realize that this is a prehistoric thread, but in doing some of my time-killing browsing around I ran across it again. I had to respond to give a nod to Stacy. His post is exactly right - I must have been having a senior moment that day and got my mind screwed on exactly backwards.
    Just didn't want to let it go by without giving props where they are due.
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    I will be going with a push/pull steering like this on my new build.
    I have been wondering the same questions asked.
    I'm glad you brought this back up
    So am i correct in that
    Both ends should be the same length.
    But what is the difference is the length on both ends are the same but shorter or longer
    Also the Trail is most important on a Trike.
    As for the Rake. I can use just about any Rake as long as the Trail is good (1 - 2 inches)
    Correct???
    How does Wheelbase affect turning?
    Im not happy about it but my wheel base will be right at 10 feet.
    That is because of the seating area I want. If I reduced the space for seating I could make it shorter but I really do not want to do that.
    Thank you
    Bob
    750+ Posts
    Jan 2010
    east windsor ct
    i saw this came to the top again and started reading from the first post came to the lay an thought yup that is correct didnt even realize it was my post till u gave the nod....(thanks)
    how quickly the ole mind forgets what it has done lol
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by Fowler View Post
    So am i correct in that Both ends should be the same length.
    Correct???
    see sketch distance 1, 2, 3, 4 must all
    which makes the connecting rods the same
    correct
    yes i have found 1_2 inches works well
    not sure how far out you can go with the rake and still be handle correct... been wanting to experiment but no time as yet
    500+ Posts LarryA's Avatar
    Jun 2016
    milnor n.d. usa
    Default 1 consideration
    .....started thinking about the "side view" of this steering set-up...thinking with a larger rake angle 45deg or so, the steering rods would have to somewhat follow at 90 deg to the fork angle, or they may not pull correctly...front bar higher than rear bar..... also steering links would have to cross the top of the engine... .probably less rake would be better, just thinking out loud here!
    750+ Posts
    Jan 2010
    east windsor ct
    Correct???
    i think you will be fine with the wheel base..... you may need a bigger place to turn around is all
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    Quote Originally Posted by LarryA View Post
    Use a heim joint at each end of the connecting rod. This will allow you to keep your 45 degree rake and keep the connecting rods closer to level. It shouldn't effect leverage too much either.
    Sep 2014
    Moneta VA
    I am at the point where I am looking into this myself.
    Thank you
    Bob
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    How about one rod with real tie rod ends. Hot rods only have one drag link.
    Jun 2016
    milnor n.d. usa
    One rod would certainly eliminate the binding problem with different lengths of steering horns...... now talking "looks" I like the dual rods, they also appear stronger. But it's up to the builder/owner.
    Attempting to get lighter steering by having to turn the handlebars to more extreme angles could cause clearance issues and throttle/brake/ switch issues also....all kinds of considerations!
    Sep 2014
    Moneta VA
    Well right now I can handle a heaver steering
    I am worried about as I get older. I have nerve damage in my back from injuries while in the Army. It affects my arms. The doc says it will just get worse as I get older.
    SO I was hoping to get the best of both ways. Easier steering and a good turning radius.
    Thank you
    Bob
    600+ Posts TomyJ's Avatar
    May 2016
    Hemet, Ca. USA
    Default steering
    Fowler I hope this will help?Name:  Trike-Push pull steering-2010-244.jpg
    JakeJacobsen@Pinterest.com
  19. #19
    Sep 2014
    Moneta VA
    Quote Originally Posted by TomyJ View Post
    That is exactly what I want to do.
    Would like to see close ups of both ends
    Thank you
    Bob
  20. #20
    May 2016
    Hemet, Ca. USA
    Default steering
    This one is off center? Name:  Trike push pull steering.jpg
Size:  494.2 KBI hope something works out for you...
  1. Who has a pull behind camper and what do you like about it?
    By Skeet7373 in forum Trailers / Campers
    Last Post: 03-16-2018, 02:52 PM
  2. Pull behind trailer
    By Jerry469 in forum Honda Trikes
    Last Post: 08-16-2014, 06:37 AM
  3. E-Z pull clutch
    By Mcwac in forum Harley Trike Conversions
    Last Post: 10-11-2011, 03:20 AM
  4. What Trailers do we have and Pull
    By kj5ix in forum Trailers / Campers
    Last Post: 10-12-2010, 10:39 AM
Tags for this Thread
