SSpoon4SullyNew Member Introduct...Hello from VA
SSpoon4Jack KlarichNew Member Introduct...Hello from VA
SSpoon4GorillaNew Member Introduct...Hello from VA
SSpoon4SSpoonNew Member Introduct...Hello from VA
Results 1 to 7 of 7
Thread: Potential charging problem
    90+ Posts pddgm's Avatar
    May 2014
    Sunrise Beach, MO
    Default Potential charging problem
    I finally got to take the trike out yesterday (1st time in a month) The battery was almost dead, so had to charge it for a while. Once it started and I got it warmed up and took it down the road, I checked the gauges and notice the warning light on the amp gauge was on and the gauge was showing 10 or 11 amps but not 12 or over. I rode it back and put the trickle charger on it, to finish topping off the charge. Any suggestions where I should start looking for the problem. I checked the alternator belt and it is tight.
    Joe
    1750+ Posts slick rick's Avatar
    Aug 2012
    Dora Al
    Default Re: Potential charging problem
    Alternator or generator ?????????? If gen it could be regulator, if so use nothing but Bosch !!!!! If alternator it's simply not charging enough .....click below great source of information
    Search Results
    Rob and Dave's Aircooled Volkswagen Pages
    www.vw-resource.com
    we all have our faults .....others point them out to us......guess we know what theirs are
    May 2014
    Sunrise Beach, MO
    Quote Originally Posted by slick rick View Post
    It's an alternator, at least that is what it looks like to me.
    Joe
    Aug 2012
    Dora Al
    Click on the link ,,,a lot of great information and good luck . Does it have a voltage regulator if not it will be a alternator
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    300+ Posts vw driver's Avatar
    Jan 2014
    Tacoma, WA USA
    If you have a battery with removable caps check the water level. If low add distilled water. Also make sure all connections are clean and tight including ground connections. Make sure battery terminal connections are clean and tight.
    This is a generator:
    This is an alternator:
    Trouble shooting procedures will vary depending on which you have.
    300+ Posts
    Oct 2012
    Marietta Ga.
    How old is the batt. you said it sat for a mo. swap the batt with a known good batt. like the one in your car, and go from there, a bad batt. can cause all kinds of elect. prob's. it only takes a few min's for this simple task.
    just a thought, just use the kiss system, some times it works.
    I've suffered a great many catastrophes in my life....
    most of them never happened.;)
  1. Potential TriGlider
    By JimmyDee in forum New Member Introductions
    Last Post: 04-19-2013, 08:27 AM
  2. Roadhawk Charging Problem ?
    By 2blackbelts in forum VW Powered Trikes
    Last Post: 05-09-2012, 11:14 PM
  3. potential new indiana laws go to
    By eagle1 in forum General Discussion
    Last Post: 02-19-2012, 07:50 PM
  4. New member (potential sponsor)
    By Baxley Trailers in forum New Member Introductions
    Last Post: 12-26-2011, 05:44 PM
  5. Current Biker -- Potential Triker
    By Stumpy in forum New Member Introductions
    Last Post: 09-02-2011, 09:10 AM
