Page 2 of 2 FirstFirst 1 2
Results 21 to 30 of 30
Thread: DNA rear ends
  1. #21
    Aug 2017
    englewood fl
    Default Help dna trike shock mounts
    Have 96 road king can't get lower shock mounts to attach to line up any help appreciated thanks
  2. #22
    Have you let all the air out? Careful not to lose the oil inside keep them upright
  3. #23
    Aug 2017
    englewood fl
    Default bottom shock mounts
    I don't have air shock problem is where to weld shock tabs
  4. #24
    May 2020
    San Angelo, TX, USA
    Default dna installation guide/owners manual
    I bought a 2007 Sportster 1200C with a DNA trike kit. I love it, but tonight my rear end rotated forward for some reason, which chewed up my belt. I think it is the standard 1200C belt, but not sure. Also need to know what I need to tighten up to prevent from rotating again. I see a couple small allen bolts, one on each side of the differential, but that doesn't seem to be enough...but maybe I"m wrong. Also, while doing lots of upgrades after I got it (new seat, 12" z bars, new rear fender, making a bracket to hold my tail lights and turn signals) I saw that the rear brake reservoir was low, so I added some. Maybe a dumb question, but would the increased braking power be enough torque that it would rotate the differential? Thanks for your time folks!
  5. #25
    40+ Posts
    Oct 2017
    Lexington, KY,40517
    Quote Originally Posted by Tin Man 2 View Post
    Ive got a Trike Axle and Swingarm ordered from Rebbeca also, I hope I don't regret going with the low cost set up. I can not find any complaints on the Web, but only time will tell I guess. I'm a decent wrench and bike restorer so I intend to build my own body for the trike, I work at a Fiberglass shop so the guys will be keeping an eye on me, keeping my work up to standards.LOL...... I'm surprised that I can not find much info on the installation process for the DNA parts, I guess it must be pretty obvious as no instructions are available. I really want to know the lubrication requirements, hopefully the info will come with the parts, I'm waiting for delivery now.
    I had a run around from her and finally went to DNA. She seemed kind of sketchy so i wasn't happy and posted a review of the problems i had. Guess she didnt leave it up but it was for a Yamaha so that may have been the issue but she said they had Yamaha axles available,
  6. #26
    Jun 2021
    TANEYTOWN
    Default DNA Axle Not Centered
    I purchased a DNA axle and swingarm from Trike Life. It's installed on my 95 FLH. But with drive belt lined up correctly the Axle is not centered on the bike, in fact, it's off by almost a foot. This can't be right
  7. #27
    750+ Posts
    Jan 2010
    east windsor ct
    Quote Originally Posted by OldMan57 View Post
    possibly upside down???if not u have the wrong rear... 1" or so i wouldnt worry much
  8. #28
    Oct 2021
    Prescott, AZ USA
    Quote Originally Posted by BigMac View Post
    my plan for the axle is to weld the mounting blocks once it is lined up.
  9. #29
    30+ Posts
    Oct 2021
    Camden, TN, USA
    The DNA setup on my 1998 Harley Heritage Softail is off approximately 1 1/4" when the belt is perfectly aligned. I used a 1 1/2" wheel adapter for a Jeep Cherokee in order to compensate. The folks that I got my DNA setup from went "radio silent" after my purchase. I contacted Rebecca at Trike Life by email. She has been most helpful. I definitely wish that I had purchased through her.
    Once everything was mocked up to my satisfaction, I tack welded the blocks. Finish welding will be done by a professional. Take a look at an original servicar rear frame section and an original servi axle. Mounting is exactly the same as DNA.
  10. #30
    Jul 2023
    Payson,AZ,Gila
    Default DNA
    I built my wife’s trike about 8 years ago. It’s a Yamaha road star with a DNA axle. I built my own swingarm & body. The trike has several thousand miles on it and no issues.
  1. Shortened swing axels and oil leak from axel ends
    By Trike in forum VW Powered Trikes
    Last Post: 06-05-2014, 08:18 PM
  2. Shake Them Rear Ends
    By 1550vt in forum Harley Trike Conversions
    Last Post: 10-13-2011, 07:34 AM
  3. For those with raked front ends
    By Chumbly in forum General Discussion
    Last Post: 11-18-2010, 05:44 PM
