1500 goldwing se w/csc conversion
Feb 3, 2015
10
2
Wilton IA 52778
Is there a way to tell if my 1998 Goldwing has been raked? Maybe a measurement from wheel to wheel? Also I will be replacing the front tire will a BT45 130/70/18 rear work good? I see a lot about the 1800 but not the 1500. I'm new to this and any info would be great. Thanks Jack
Welcome glad you joined us. Yes you should be able to tell by measuring. Look at a Goldwing Two wheeler and you should see the difference. BT45/MPA both work well. RIDE SAFE
Thanks for the info to everyone on this thread. This gives me some good info. Does anyone know if there is a manual on how to work on a CSC conversion like things to check and different adjustments? Thanks again for any help. Jack
Call them at (434) 263-8866. They are good people to talk with and (usually) very helpful. Congrats on your 'new' trike.
2011Case
2011Case
