Likes Likes:  2
Results 1 to 17 of 17
Thread: Roadsmith Unveils New Auxiliary Fuel Tank Option for Harley-Davidson Touring
    News
    TrikeTalk Administrator
    Trike Talk News's Avatar
    Mar 2008
    USA
    Default Roadsmith Unveils New Auxiliary Fuel Tank Option for Harley-Davidson Touring
    White Bear Lake, MN (February 10, 2015) – Roadsmith Trikes unveiled an all new auxiliary fuel tank option at the V-Twin Dealer Expo in Cincinnati, and at the Minneapolis Progressive International Motorcycle Show this past weekend. Roadsmith’s new option will be of utmost importance to the true touring trike rider, featuring a full 3-gallon fuel capacity and separate filler neck allowing for long distance range and rapid fill. The system also features an “on-the-fly” transfer system, with the push of a button, all 3-gallons can transfer to the main tank in a matter of minutes.
    This new option is poised to not only allow the rider to go the extra mile, but more importantly offer a peace of mind knowing that fuel will no longer limit the adventure. The auxiliary tank retails for $799 and is designed for the 2009 and newer Harley-Davidson based trike conversions for the company’s flagship HDTR model.
    For more than 40 years, Roadsmith Trikes has been designing and producing some of the best engineered, best handling trikes in the business. Based in White Bear Lake, MN, Roadsmith manufactures and distributes 19 different trike conversion kits for Honda, Harley-Davidson, Victory and Indian motorcycles. They are represented by over a 100 Roadsmith dealers in the U.S. and Canada as well as their own retail location, The Trike Shop, on Beach Street in Daytona Beach, FL.
    Ride With The Expert
    Name:  Roadsmith Aux Fuel Tank HD.jpg
    Roadsmith Trikes
    (800) 331-0705
  2. Roadsmith banner
  3. #2
    200+ Posts HarleyPap57's Avatar
    Jan 2015
    Mooresville, NC., USA
    Default Re: Roadsmith Unveils New Auxiliary Fuel Tank Option for Harley-Davidson Touring
    Wonder if this will fit a stock HD Tri-Glide?? I've been looking for something like this even before I bought mine
    2014 Big Blue Pearl / Vivid Black, 1.5" Lift Brackets, Street Cannon Mufflers, 10" Wind Splitter Windshield, Daymaker LED Fog Lights, Passing and Fog Lamps work on both High and Low Beams, BAL-1R Rear Taillights, Dunlop American Elite Rear MT90B16 (34AE92) on Front turned backwards, Dynojet Power Vision Turner, De-Cat Headpipe just for a start.
  4. #3
    Sep 2012
    Lakeland, FL
    Seems to me they would have this for the HD as well, RS does the HD conversion.
  5. #4
    Sponsor - Roadsmith Trikes
    TrikeTalk Sponsor
    Roadsmith Trikes's Avatar
    Mar 2008
    MN
    Quote Originally Posted by HarleyPap57 View Post
    HarleyPap57 - Afraid not...the auxiliary fuel tank option is specifically designed around the Roadsmith Trike conversion and for a handful of reasons it would not be a direct bolt-in application on a Tri-Glide.
  6. #5
    Jan 2015
    Quote Originally Posted by Roadsmith Trikes View Post
    Thanks for the reply. Guess I'm back to the drawing board and still looking for someone to come up with one the fit the HD Tri-Glide.
    1+ Posts daveking95's Avatar
    Sep 2018
    Milo, Iowa, USA
    Default Possible upcoming Aux Fuel Tank for factory Tri-Glide?
    Well, I just spoke with the folks up at Roadsmith... they currently have a 2.5 gallon (ish) Aux Fuel Tank in the R&D stage, and they asked me to call back around November (2019) to see if it's come to fruition yet. I like their filler neck and I like the auto-shutoff feature on the setups for the Roadsmith trike kit, so I'd hope they use those items on the TG kit too. Bad part is- the TG has a solid axle, so it uses more room under the tub than their Roadsmith independent rear uses.
    So, a smaller tank. Even another 2.5 is better than carrying a separate gas can...
    I'm definitely setting up a reminder to call them back!
    50+ Posts Ridernut's Avatar
    Lorena, Texas, USA
    Quote Originally Posted by daveking95 View Post
    I would certainly be up for one of these. 2.5 gallons would be awesome.
    2016 Purple Fire Harley Tri-Glide
    Sep 2016
    Springfield, Mass. USA
    If I already have a Roadsmith trike (Goldwing) set up, can this be added if trike had been built two years ago??
  10. Roadsmith banner
  11. #9
    Sep 2012
    Lakeland, FL
    I have a 2005 GW w/2012 RS conversion, and I can assure you mine does not have the auto shut off valve. RS must have designed this 2.5 gal different. Those that have the 5 gal aux tank will know what I'm talking about. Forget the transfer pump is on and you will experience a 'fuel flooding' problem.
  12. #10
    Sep 2016
    Hmmmmmmmmm very interesting situation here::: I did not get the added fuel tank when I had my Roadsmith kit added (goldwing) BUT to be truthful, I honestly don't feel like I really ever needed the extra gallons or weight added to my bike's already heavy weight...I have never ran out of fuel....
  13. #11
    Sep 2012
    Lakeland, FL
    Agree Ronnie, if I had it to do over, I'd probably make the same decision. You know how it goes, I was younger back in 2012 and had visions of riding west of the MS river over those long west bound roads, blah, blah, and surprise, that never happened. Age has way of overtaking those grandeur thoughts of riding far and wide.
    Cheers, Bill
  14. #12
    Thumper
    1dn5up's Avatar
    Nov 2015
    Bear Mtn. NY
    Done many trips , and after a tank full , and 3-4 hrs later , I’m ready for a break .
  15. #13
    Sep 2016
    Cheers, Bill
    Billy,
    It totally sucks getting old doesn't it?? [I just turned 69 last week] I also had "big dreams" of riding the entire USA.... BUT of course that never even came close to happening!
  16. Roadsmith banner
  17. #14
    Lorena, Texas, USA
    Default Aux tank
    Any word yet?
  18. #15
    Sep 2012
    Lakeland, FL
    Ronnie, yes, getting old does suck, but getting old and riding softens the "suck" factor some.
    OldBikerBilly
  19. #16
    TrikeTalk Sponsor
    Mar 2008
    MN
    Hi Ronnie - yes, we can retro-fit your trike with an auxiliary fuel tank (assuming you do not have the extended trunk option). It requires removing the seat, tour-box and trike body. The tank bolts into place, route some fuel lines, vent lines, and wiring. Put everything back on. Takes about 6hrs of time. Cost for the parts is $499. Let me know if we can help you out!
    Jim
  20. #17
    TrikeTalk Sponsor
    Mar 2008
    MN
    Quote Originally Posted by Ridernut View Post
    Any word yet?
    Hi Ridernut - we have installed a couple tanks on TriGlides. Still working through the process, evaluating installation time, parts cost, and frankly, how much demand is out there. We just aren't certain at this time that we are going to go into production on the tank. Sorry to ask again, but please check back in a couple months.
    Jim
  1. Roadsmith Aux fuel tank
    By minnleeboy in forum Accessories
    Last Post: 02-17-2020, 10:20 AM
  2. Slow filling of Auxiliary Fuel Tank
    By ibsteve in forum Honda Trikes
    Last Post: 03-07-2013, 10:47 AM
  3. Roadsmith Aux. Fuel Tank
    By Konrad in forum Honda Trikes
    Last Post: 10-10-2011, 02:01 PM
