dthorn1dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
Jack Klarich2ISP-FLGeneral Harley ChatExhaust Heat Shield
Jack Klarich2Jack KlarichGeneral Harley ChatExhaust Heat Shield
Likes Likes:  3
Results 1 to 11 of 11
Thread: Kudos to Motortrike
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    Default Kudos to Motortrike
    My VTX 1300 Champion is in the shop getting it's 2nd head gasket job in 12 months. (Don't ask). should have it back on Monday. While there we got to talking about Goldwing trikes. My wrench had 2 coming in with drive shaft issues. He will work on the motorcycle 1/2 but will have nothing to do with the trike 1/2. He found the problem to be with the rear u joint. He did call Mototrike and was told that if his customer was the first owner to have him take it to any Motortrike dealer for full repair no questions asked. He was also told that if he was the second owner that they would send him a new driveshaft and he would have to pay for the install by anyone. The wrench still wanted no part of it. He stops at the transmission output. That's pretty damn good customer relations from Motortrike if you ask me. No mileage restrictions or anything. If I ever go looking for a new trike you can bet Motortrike will be on top of my list.
    Ridin' three and free. Ain't never goin' back
    2003 1800 Gold Wing Trike w/Roadsmith kit. Northeast Region Trike Riders on F B.
    200+ Posts RTwing's Avatar
    Mar 2014
    Minnesota
    Default Re: Kudos to Motortrike
    They run a very clean and professional factory and take terrific pride in everything they do. I am not surprised they would stand behind their product 100%.
    90+ Posts Chappy KC's Avatar
    Apr 2015
    Marion, Illinois
    I just bought a new Motor Trike kit on my Kawasaki Voyager. That is really comforting information. Thanks.
    1250+ Posts jaxbobg's Avatar
    Nov 2011
    Jacksonville Beach
    Yes, my experience with Lehman, Hannigan, and Roadsmith is that they all go out of their way to help out. Sometimes they say "no charge" and other times they ask for some payment.
    Regardless, the trike conversion manufacturers seem to go to any length to keep their customers happy. Very unusual in this day and age.
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Always good to hear a good report about one of the KIT Builders. RIDE SAFE
  6. #6
    10+ Posts
    Oct 2015
    Greens Fork
    I'll soon find out about Motor Trike. I was looking under my wife's Motor Trike to see about belt adjustment if I wanted to do a 30T conversion and if there was enough adjustment to tighten the original belt, and saw that the left CV joint boot had either pulled off one side or tore and exposed the joint on the inside to the elements. So, we're going to find out what happens on that. I've never seen a CV boot on anything give out before, although I'm sure they do periodically.
  7. #7
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    actual CV joint boot failure is quite common at least on cars but trike boots get exposed to the same elements.
  8. #8
    60+ Posts
    Nov 2014
    Stow, Ohio USA
    Quote Originally Posted by Skippy49 View Post
    I realize that your post is a few weeks old, but I'll throw this out: All 4 of my CV boots separated from their holding rings on my MT / HD conversion. Also happened to a friends MT conversion. I called my installer, who called MotorTrike. They shipped two complete axle shaft assemblies immediately for my dealer to install. No questions asked. Very happy with that kind of service. The opinion at the dealer is that they may have had a batch of poorly assembled half shafts.
  9. #9
    200+ Posts
    Apr 2015
    Arlington, TX 76017
    I had my Motortrike in for service and the found a ripped CV joint boot. The factory agreed to replace the part, but I had to pick up the labor.
    Obviously there is a issue with these CV joints or Motortrike would not be replacing these units.
    IMO they should be picking up labor as well.
  10. #10
    60+ Posts
    Nov 2014
    Stow, Ohio USA
    MotorTrike is notorious for being closed-mouthed about their products, processes, and problems. According to my installer, they have had as many as 5 units at one time waiting for axle shafts due to boot failure. Which is why they think there must have been a systemic problem at one time. MT denied any "known problem" when I called them. Of course, I've called in the past seeking technical info and asking why there is no shop manual for their product. They are less than helpful.
    Sloride, I don't know how old your conversion is, but I agree that a failure such as this should be covered for both parts and labor.
  11. #11
    200+ Posts
    Apr 2015
    Arlington, TX 76017
    Quote Originally Posted by RoadKingTrike View Post
    My conversion 2 years old with less than 2500 miles on it
  12. #12
    60+ Posts
    Nov 2014
    Stow, Ohio USA
    Quote Originally Posted by Sloride View Post
    Mine is in its first season ( converted last winter ) and had about 5000 miles on the conversion when the boots failed. Remember, though, that the boots on mine pulled loose from their retaining rings. They were not torn. Have put 1400 miles on since the repair, and all is well so far.
  1. Kudos to Thoroughbred Motorsports
    By Dean H in forum Stallion Trikes
    Last Post: 02-14-2019, 07:57 AM
  2. Kudos to Gold Rush
    By Hunter1 in forum General Discussion
    Last Post: 01-09-2015, 02:13 PM
  3. RSV with Motortrike?
    By steamer in forum Yamaha Trikes
    Last Post: 09-28-2013, 06:34 PM
  4. Another Kudos to MotorTrike
    By keepinon in forum Motor Trike
    Last Post: 06-05-2013, 04:20 PM
  5. MotorTrike
    By earlyriser4444 in forum Honda Trikes
    Last Post: 03-18-2012, 09:59 PM
