Likes Likes:  2
Results 1 to 12 of 12
Thread: I found a grease fitting On my 2014 Trike
    40+ Posts
    Aug 2014
    PA
    Default I found a grease fitting On my 2014 Trike
    Purchased a Seat, Road Zeppelin Air Adjustable, while finishing the installation, I dropped the screw that secures the seat. So I jacked Trike up, looking for the screw that I know didn't hit the floor, I rotated the back tires thinking the screw could have gotten stuck in the rear sprocket, while rotating I see at least one grease fitting on the rear belt sprocket, I though there weren't any grease fittings, guess I was wrong. Just a heads up for others. Found the screw and everything in working fine.
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Default Re: I found a grease fitting On my 2014 Trike
    Quote Originally Posted by Side by side View Post
    Next time you take that screw out , Cut a piece of plastic the size of a quarter slit the center and with the screw still on the seat tab' push it on the screw, And the screw will stay with the seat.
    2019 Tri-Glide.......
    300+ Posts
    Dec 2011
    Iowa
    Might want to read your owners manual about that. My 2011 manual says that is greased at the factory and does NOT need greased for the life of the part. I could be wrong, but I don't think the 2014s are any different than the 2011s on that particular part.
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Quote Originally Posted by rap47 View Post
    You are right, nothing has changed. The grease is added when the differential is built, with none to be added after that. I wonder how many have saw it and gave it a few pumps of grease, they should have just removed the grease fitting and put a plug in.
    http://i1347.photobucket.com/albums/...pswnuweejq.jpg
    Red Ultra Powered By Head-Quarters 120, Easy Clutch Pull By ClutchWIZ. 2012 GL1800 Hannigan. I've yet to ride a stock Harley which wasn't in need of a mechanical intervention.
    40+ Posts
    Aug 2014
    PA
    If I wasn't so focused on finding that screw, I probably would have greased it, I'm glad I ask first. Thanks
  6. DKCustoms postbit
  7. #6
    350+ Posts
    RickDeVon's Avatar
    Jun 2010
    Pine Mountain,Ga
    What I hate about the 14-15 MY there is not a fitting on the steering head...
    Miss Mysterious...
    2015 Mysterious Red Tri Glide...
    Vance&Hines head pipe w/Rhinehart slipons...Slipstream Collection...DK Lift...11" Clearview w/ recurve...HD chrome Enforcers w/Goodyear Triple Tread Assurance...just a touch of chrome & LEDs...
  8. #7
    300+ Posts
    Dec 2011
    Iowa
    Quote Originally Posted by RickDeVon View Post
    Yep, and I do believe that Harley says that the 14s and 15s steering neck bearings should be replaced at 25,000 miles. Witch means tearing the front end apart to do it. So the guys that don't do their own work are going to have to pay to have this done and I would think that would be pretty labor intensive!!
  9. #8
    Sep 2009
    NE Ohio
    Every 25,000 they have to be serviced, they inspect and grease and only replace if needed. The crappy part is what all has to come apart to service them, it won't be a cheap date. Figure remove front wheel, fender, inner and outer fairing and the triple trees. Like you said, labor intensive.
  10. #9
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    Quote Originally Posted by msocko3 View Post
    That might be time to put in EZ steering triple trees from the Zook ! If he has them for the '14/'15's.
    Many won't be changing those until they get really bad I bet.
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
  11. #10
    350+ Posts
    RickDeVon's Avatar
    Jun 2010
    Pine Mountain,Ga
    Quote Originally Posted by Sloufoot View Post
    Yes Sir....^^^^THAT^^^^
    If and when mine is took apart the bearings will be replaced...
    Miss Mysterious...
  12. #11
    300+ Posts
    Dec 2011
    Iowa
    Ya, I think they dropped the ball on this one. I can't imagine taking a $32000 car in to the dealership at 25000 miles and have tear the front end apart just to service a bearing! To me this is just a little gimme to the dealers from Harley for their service departments.
  13. #12
    Jul 2012
    Chubbuck Idaho
    It gives you one more thing to dicker with he purchase ! Ya don't think MOCO would ,,,,,,,, NAH don't even go there !!!!
  1. Windshiels, Handle Bars, & Seat. Fitting The Rider
    By Geezzer Glide in forum Harley Trike Conversions
    Last Post: 12-02-2013, 12:46 AM
  2. Universal Grease Fitting
    By Yogisan in forum General Discussion
    Last Post: 07-20-2011, 07:42 AM
  3. Just found the trike forum
    By Mr Bulldog in forum New Member Introductions
    Last Post: 02-16-2011, 08:11 AM
  4. I found a new trike.....
    By secondroy in forum New Member Introductions
    Last Post: 11-21-2010, 09:03 AM
  5. Found another trike
    By FreeBird in forum General Discussion
    Last Post: 08-06-2010, 05:24 PM
