Likes Likes:  2
Results 1 to 16 of 16
Thread: trike steering help please!
    Feb 2015
    kent, swanley
    Angry trike steering help please!
    hello, i am a new member but hadnt had a chance to introduce myself as i have been ill, i have a suzuki gs1000 trike convertion, today i was test riding it and found that the steering feels as if you are being pulled side to side quite violetly, this starts at almost no speed at all causing you to be pulled into the path (luckily it was the path rather than a parked car haha)
    there arent any steering dampers on the trike, there isnt any visible the the front wheel or to the frame.
    any help asap would be greatly appreciated as i want to get out on my trike as soon as i can
    Default Re: trike steering help please!
    My new tri glide was my first trike ... the first couple times riding it I had the feeling I was "out of control" also ... I'm not saying what you feel is normal, but, it is a different beast. I'd have it checked out by a qualified service tech or at a minimum, but someone who is experienced riding trikes ...
    On my Tri, i feel like I have to "muscle" the bike into and out of turns ... hope this helps ... I would definitely get it checked out ... if it's okay ... take it to a large empty parking lot and practice doing figure eights ... really helped me get used to the trike.
    Good Luck and Be Safe
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    yes, you probably need a steering damper on your bike. Triglides have 'em. happens with short wheel base conversions I'm told. Goldwings don't use 'em. my VTX doesn't either. Rake kit is a must. Power steering.
    30+ Posts nomad06's Avatar
    Jan 2011
    alberta canada
    Default steering
    try posting in general post some members work on or have parts that might help, fix your problem and thing that should work
    May 2015
    Oceanside, New York, USA
    Can a universal steering dampner be put on a 2006 Kawasaki Vulcan 750 cruiser with a voyager trike conversion kit.....?? Help
    Jun 2010
    Coram, NY USA
    Was a rake kit added to front end? Also, are you sure about alignment of conversion?
    May 2015
    Default Ugh
    So now the bike has a stator malfunction... Is this complicated on a Vulcan 750 cruiser (2006)..😨
    100+ Posts
    Jan 2011
    illinois
    Cool
    I've been "triking" with a '94 Kaw. Vulcan 1500 with a tow-pac for a bit over two years and 10,000 miles now. It has been my experience that a little head shake is fairly normal. If it's really bad it could be a tire pressure issue, a lost wheel weight, worn out tires or even a mechanical problem in the steering. Mine does not have a rake kit and it steers really easy, with just slight pressure required to make most turns. I have found that higher speed or sharper turns require increased effort however.
    I just recently got new tires on the bike (Pirelli) and they are internally balanced with Dyna Beads. So far they seem to have eliminated all head shake.
    As others have suggested; find an empty parking lot and experiment a bit with turns, figure 8's etc and as you go along it will get more comfortable. I feel really comfortable on mine; but it did take several hundred miles.
    40+ Posts
    Apr 2015
    Selden, KS
    Quote Originally Posted by Wboopn View Post
    So now the bike has a stator malfunction... Is this complicated on a Vulcan 750 cruiser (2006)..��
    Stator change on a VN750 isnt a lot of fun. You have to remove the motor from the frame. Check out VN750.com, you will find a lot of good info there.
    200+ Posts dbruce56's Avatar
    Nov 2014
    Salem, Al
    Another thing to check is the tree bearing adjustment. Lift the front wheel off the ground and check for play in the forks.
    May 2011
    San Angelo
    I've seen "Rake Kit" mentioned a couple times in this thread. Don't I remember that "Rake Kits" are a huge no no for bikes with Voyager kits installed?
    2015 GL1800/Roadsmith HTS1800
    1500+ Posts leo3wheel's Avatar
    Aug 2011
    Cranford, NJ, USA
    True if you ever go back to two wheels.
    Leo TOI #617
    (Jeannette)
    09 RSV Black on Red with Hannigan trike conversion
    TOI - New Jersey 87Trike1200's Avatar
    Feb 2008
    The Jersey Shore
    Quote Originally Posted by Gunner45 View Post
    Go into this job with "your eyes wide open". 1200 Gold Wings are famous for stator problems - also requires engine removal. For the Wing (round numbers) $100 for the part and $1500 to put it in. We had a quote from a reliable shop ahead of time, so we knew what was coming. Has worked great ever since. Hopefully your engine removal might be less "involved" than our GL1200 was... Best wishes!
    "Only a biker knows why a dog sticks it's head out of a car window."
    - - - '95 GL1500 / '12 MT Phoenix IRS - & - '87 GL1200 / TriKing - - -
    90+ Posts Chappy KC's Avatar
    Apr 2015
    Marion, Illinois
    What kind of conversion do you have? Is it 2 wheels added to the rear or is it a true trike conversion? They do handle a little differently. My Kawasaki Voyager with the Motor Trike conversion does not require a steering damper or rake kit (Easy Steer). I do notice a bit of a wobble if I don't keep the front tire around 40 - 42 lbs psi.
    2017 Can Am Spyder RT-S
    20+ Posts
    Sep 2015
    BAKERSFIELD CA
    did that stop the front end wobble
    Jul 2014
    Union City PA
    Default steering problem
    Quote Originally Posted by suzukispud2015 View Post
    I have a C-90 with a Lehman conversion. It steered hard for me until I had a raked triple tree installed. It made a big differance in the steering. Jim
  1. 4.3 trike steering question
    By butchvoss in forum Home Built Trikes
    Last Post: 01-16-2015, 12:03 PM
  2. steering stabilizer sportster trike
    By captdanwh in forum Harley Trike Conversions
    Last Post: 09-20-2013, 01:28 PM
  3. V8 trike steering
    By KDHUFF in forum Home Built Trikes
    Last Post: 01-26-2012, 09:00 PM
  4. H.D. trike steering
    By apulizzi in forum General Discussion
    Last Post: 04-15-2011, 06:37 PM
  5. v8 trike steering bearing
    By jasandbob 2 in forum General Discussion
    Last Post: 11-15-2010, 03:44 PM
