ADSavarese6Marc HNew Member Introduct...New member from FL
ADSavarese6ADSavareseNew Member Introduct...New member from FL
ADSavarese6Phu CatNew Member Introduct...New member from FL
ADSavarese6trike ladyNew Member Introduct...New member from FL
ADSavarese6Uncle FesterNew Member Introduct...New member from FL
ADSavarese6rhino 2New Member Introduct...New member from FL
Likes Likes:  1
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 41
Thread: Future V-8 build questions.
    5+ Posts shameless's Avatar
    Jul 2014
    Lowell OH
    Default Future V-8 build questions.
    I'm planning on building a V-8 trike, but I have a few questions. I'd like to stay with a rigid frame with a suspended seat, keep is short, (preferably with no driveshaft, just trans. to axle) I've considered using suspension but I'm not sure how to go about it, and not get negative body roll. ( trike leaning left/outside, or a right hand turn.) If usig suspension, I've consisdered both solid rear axle with springs, and Independant rear suspensions.
    Also, I'm not sure of a good front end to use, I'm trying not to break the bank, but don't want to hit a pothole and wind up pole vaulte into a guardrail either. Are Goldwing or Silverwing front ends stong enough, or am I going to have to buy a custom front? Can I go with a wider front wheel, or will it completely change the handling and steering of the trike?
    Sorry I'm so long winded, just trying to get a decent start.
    Default Re: Future V-8 build questions.
    The only experience I've had with V8's on motorcycles was a Boss Hog.
    I would think a big issue would be torque ... it was on the Boss Hog, I met a guy in Sturgis in 07 (my neighbor at a campground). He was riding a Boss Hog. 502 Ford V8, he asked me if I'd like to take a ride .... Duh ... Even after he warned me profusely about the torquing to the right when the engine starts, I almost dumped it just starting it. The torquing the whole bike to the right when the engine rev'd didn't get much better while riding it. I would think the frame would take a beating on a trike ... but I'm no engineer.
    100+ Posts rrunner's Avatar
    Oct 2010
    Zuni, New Mexico, USA
    The trike will probably break something with a rigid rear end with no drive shaft. My v8 has leaf springs and a Harley front end with helper springs. Got it into the shop today to have a rollbar made and place a correct rake on the front. I find the Harley front with the springs is too much for my trike. It keeps blowing out the fork seals so plan is to remove the springs and see how it seats. I would like to put a leading link front on it. I made my own for the vw trike I have but would like to make one up for the v8. I'll have a better idea after the rake is addressed. By the way the ride with the leaf springs isn't too bad on the open road but on city streets it can be a bit jarring.
    Jul 2014
    Lowell OH
    I've seen a few online that looked like they were no drive shaft, however, I'd probably be ok with a short drive shaft. my plan is to run airplane gears in it to dial back the torque, at least till I can get more accustomed to the ride. I'm definitely not opposed to running leaf springs or coils in the rear for a smoother ride, just not sure about the body roll, or if there would be any body roll at all. would a springer front be best for that amount of front end weight?
    By the way guys, I realize I probably sound like a meandering goof, but I'm learning. I've seen the bikes built, cant afford a Boss Hoss, but want my own interesting trike. So to those of you who are willing to teach, and be patient with me, my sincerest thank you!
    Oct 2010
    In my opinion an air bag suspension would be best in combination with good shocks to control the body lean. I also like the idea of a short frame but consider the rear axle as a fulcrum, the longer the front end is from that axle the less weight that will be on the front wheel. So keep on planning your build and continue to ask questions.
    20+ Posts Mo Lee's Avatar
    Nov 2011
    Waynesville Mo
    Here is a pic of the one I built a couple of years ago I started with an sub-frame assy out of an 97 Mark VIII Independent susp set up I'm using the front end off a 83 1100 wing with the heaviest springs Racetech had and with 40PSI in the front shocks it rides well. It does had a little body roll however it does ride 100% better than I ever expected. My biggest problem is when you get above 20-30 MPH the steering get pretty stiff which I guess is really a good thing.
    Jul 2014
    Lowell OH
    I don't know if I want to be that far away from the forks, I'm willing to spend a little to do this if I need to. I'm hoping for something like these.
    Also, if I go with a wide front tire, how much will my handling be affected?
Size:  674.3 KBName:  maxresdefault.jpg
Size:  64.7 KBName:  218494_01ad38797030aa19.jpg
    300+ Posts vw driver's Avatar
    Jan 2014
    Tacoma, WA USA
    Quote Originally Posted by Mo Lee View Post
    Ya gotta love Hooters
    Jul 2014
    Lowell OH
    Do you mean that you changed the springs in the front forks? I guess that never really crossed my mind that it was a possibility. If I do that though, will the metal (meaning all other metal, not just the springs,) and the seals hold up to the weight? I live in South East Ohio and we have some pretty major pot holes, and the occasional wheelie, so I just want to make sure the thing wont snap under pressure of a hard jarring.
    Quote Originally Posted by vw driver View Post
    We are taking about the restaurant ... right?
    10+ Posts JethroBodine's Avatar
    Oct 2014
    Springfield, VT, USA
    Default In process
    I am currently building a V8 trike and am using a Goldwing 1500 front end and a Subaru WRX independent rear end. I will start a build thread soon and will, hopefully, be riding sometime in June. I had a drive shaft made at a specialty shop for about $250 US. The guy laughed and said it is the shortest shaft he has ever made.
    Nov 2011
    Waynesville Mo
    Quote Originally Posted by shameless View Post
    I would be a fool to say yea it will hold up, my front end is on my mind everytime I see a pothole, I have hit several and it hasn't broke yet. I would like for it to be stronger however I figure it is stronger than one homemade. I was worried about the skinny front tire skipping in the corner but it seems to be holding well. The best way is just build it and test it slowly until you trust it and your own skills. I still have not run much on the interstate even though I've got nearly 3000 trouble free miles on it and yes I do run at interstate speeds frequently.
    Jan 2014
    Tacoma, WA USA
    [QUOTE=FuzzyWuzHe;282183]We are taking about the restaurant ... right? [/QUOTE
    Of course, what else could it mean?
    Ahhh ... we've done a lot of talking about geese lately.
    100+ Posts butchvoss's Avatar
    Jul 2013
    patrick SC
    On the short drive shaft, my trike is a 4.3 V6. my shaft is 10 inchs u joint to u joint. No problems with the short shaft. If u build it yourself just remember to keep joints in synch .
    Quote Originally Posted by JethroBodine View Post
    I used a 1100 gold wing air front end. My trike is 1700 with me and have 600 on front wheel. Not a V8 but a 4.3 V6. I run 65 lbs air in forks all last summer.. so far so good on the pot hole roads of NH
    Jan 2014
    Tacoma, WA USA
    Not the same........those are honkers.
    750+ Posts
    Jan 2010
    east windsor ct
    imho.. unless u r building a TT bike (tavern to tavern) take the time to put some suspension under it... not only will you feel better but its a lot easier on the trike,,, again in my opinion nothing like an irs and while i am at i put in a link to lean the bike to compensate for the crown in the road....as for the drive shaft... i wont say its impossible to run without one but darn near it.. cant have much if any flex in the frame an you would need solid motor mounts... couple all that w no suspension cant imagine youd get a very nice ride.... for the front end i think i would opt for an inverted-ed front end an maybe even an aftermarket one the bigger the tube the better .. and plan on a set of raked trees... or make a leading link front end.... not very pleasing to the eye but sure work well..
    Jul 2014
    Lowell OH
    I'd love to go with an IRS, what kind of link is it you spoke of, an are you saying it leans the bike into a turn, instead of letting it lean out of a turn?
    I'm assuming you mean the tubes of the forks, and not "Tube" as slang for a front tire. I'm not opposed to a leading link front if its safer. are you saying to go with both inverted forks, and either the raked trees or leading link front?
    Also, Does a wide front tire make a better ride or handling, or am I thinking in reverse and I should stick with a thinner font.
    I'll be going with a driveshaft, and some kind of rear suspension now.
    Thanks again for all of your help. I'm so new to this that I'm almost ignorant to it. I have excellent welders and fabricators that are willing to help, but I need a plan for set up first. Thanks again for your patience and willingness to teach.
  19. #19
    Jan 2014
    Tacoma, WA USA
    Why not save yourself all the hassle and buy one of these. You'll probably end up spending about the same money.
  20. #20
    750+ Posts
    Jan 2010
    east windsor ct
    no not for turns but for the crown in the road... if you are on a back road usually a three wheeler will pull to the right but the less the crown the less the pull.... now if you get on a hiway in the left lane it will pull a little to the left .. this is all because of the crown in the road...
    the more trail you have the worse this effect will be...
    you can see the link in my pics... it goes between the top shock mount and there is an electric screw jack attached that leans the bike.... be no means is this a neccesity but on long days i find myself a little more tired if i dont have it an its really not that much work
    by a lot of standard it may not be much but usually if i go off for the weekend it will over 500 mile and some time we will do 400 in a day for lunch... a couple yrs ago i did about 15,000 on the v max..
    just by design the inverted forks are stronger the whole reason for modifying the front is to reduce the trail... a stock front end may be as much as 6 or 7 inches... for me 1.5 to 2.5 seems to work well
    the more trail the tougher to make a 3 wheeler turn
    basically what you are doing with the raked trees and or leading link is pushing the front wheel forward while leaving the neck alone... but since you are making yours you can put it any place you want
    cant say i have expirimented with that
    no problem wish some of all this info was available back in 79 when i built my 1st.... internet what is that???
  1. Future Triker
    By mcridernj in forum New Member Introductions
    Last Post: 05-13-2011, 10:35 AM
  2. future triker here
    By jerry in forum New Member Introductions
    Last Post: 05-04-2011, 10:10 AM
  3. Got my future trike
    By Sacred Steel in forum Harley Trike Conversions
    Last Post: 12-17-2010, 05:14 PM
  4. Car of the future?
    By Nana in forum General Discussion
    Last Post: 07-06-2009, 06:08 AM
