Likes Likes:  4
Thanks Thanks:  1
Results 1 to 12 of 12
Thread: Warning about ordering Avon trike tire
    Mar 2011
    mountain home,ar. USA
    Default Warning about ordering Avon trike tire
    I've noticed some confusion on the new "Avon Cobra Trike" front tire, especially when talking about ordering the tire. Be careful! It's confusing and you could end up receiving the wrong tire. I wrote to Avon yesterday regarding this and suggested they change the info.
    There are four things that must be present when ordering:
    1. The numerical designation "AV-71" (This is used for an entire line of tires not just the trike tire"
    2. The words "Avon Cobra Trike" are embossed on the sidewall in large letters (Look for this in any picture shown) and require the vendor to substantiate that the tire they're selling you contains this.
    3. The tire is "V" rated for speed
    4. The tire is a radial.
    1250+ Posts jaxbobg's Avatar
    Nov 2011
    Jacksonville Beach
    Default Re: Warning about ordering Avon trike tire
    A little technical info needed here.
    Looks like this is the flatter profile trike tire everyone has been asking for.
    However, I've read and been told we need to run a bias ply rather than radial on the trike front because they have a stiffer side wall. If the Avon is a radial, will it make a difference in ride and handling?
    I currently run a BT45 rear, reverse mounted on the front of my trikes, which I can mail order for $100 to $120. Looks like the Avon runs $150 to $200+ online. Is the new tire worth the price difference, considering mileage expectations and resistance to cupping?
    Just wondering.
    Jun 2010
    Indianapolis, In.
    Along the way, I have noted these 3 statements made, that for some reason, have become "gospel" in the trike world and are not really gospel at all
    1. The stiffer side wall of a bias tire is needed on the front.
    Not sure why this was ever stated to begin with?
    2. Run the rear tire reverse rotation when mounted on the front.
    This was actually stated by a couple of tire manufacturers but, later disappeared from their web sites.
    3. Run 41/42psi in the front tire.
    I have a much smoother ride w/36psi!
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
    Mar 2011
    Quote Originally Posted by jaxbobg View Post
    Just wondering.
    The bias ply recommendation we all use is for sport bike rear tires where using on the front. However, the Avon Cobra Trike tire was specifically designed for the trike as a radial. The ride and handling (IMO) are quite superior to either the BT-45 or MPA.
    Check this out: http://www.avonmoto.com/blog/4958
    4750+ Posts
    Mar 2015
    Texas
    There's a saying in the bike world. "Any new tire will feel great. It's how they feel after a couple thousand miles that counts." Is that true with trikes? All new tires feel great but after a few thousand you are back to what you had. Not being able to lean would seem to take a lot of the "feel" out of the question. But maybe now you really do feel the things. I'm not on a trike yet and the wife is on a Spyder which has it's own tire quirks.
    American Legion Rider
    Nov 2011
    Jacksonville Beach
    Quote Originally Posted by mhgoldwing View Post
    Okay, I'm good with the fact that the radial was designed for a trike. I like radials on a vehicle.
    What mileage have you experienced and is it worth the price difference?
    Mar 2011
    tire hasn't been on long enough to determine mileage.
    If it achieves the same as the others I will buy it again simply because the ride and handling are so much better.
    this is different because the tires most of us have been forced to use to obtain any decent kind of mileage are bias-ply, heavy wall, sport bike rear tires. When you put them on the front of a trike they are so stiff and hard, 41 psi, that you feel every grain of sand on the road.
    Ok, a little exaggeration but they do ride harsh and feel little things they shouldn't.
    The Avon Cobra Trike front tire is a radial with flatter tread area, v speed rated, and designed specifically for trikes. Yes, there's that much difference!
    May 2011
    San Angelo
    Bob I can't speak to mileage from personal experience but I was in our local trike shop a couple weeks ago and the topic came up. The owner said Richard from MotorTrike told him they have been running a test on a few of their GL1800s and have gotten as much as 35K out of them. On Texas roads covered in that crushed granite that is a HUGE accomplishment.
    2015 GL1800/Roadsmith HTS1800
    2250+ Posts
    Ocala, Florida
    FYI, I e-mailed Avon earilier this afternoon and about 45 minutes later a phone call came to the house and the caller ID showed "Mickey Thompson". Well I knew this had to be a joke of some kind cuz you guys in racing know the real story of MT and I can see by the phone number it's not my cousin Mike that we used to call Mick back in our drag racing days. So it turns out to be the guy from Avon returning my call about their having a tire for the Triglide in the engineering process. I got the impression (he didn't say this) that since there aren't a whole lot of Tglides on the road as compared to 'Wings, they're not in as big of a hurry, but he did say they'll scream 'loud and long' when it's available. I just never expected anyone from Avon to take the time to call me, a nobody, at home!
    PC
    Beware of liberals posing as Americans.
    250+ Posts Illini_Triker's Avatar
    Jul 2014
    Not Chicago and no I did not vote for him
    Took mine out Sunday for the first time with the new Avon Trike tire and New Progressive front Springs don't know its the tire or the springs but the ride was great, before the front would bottom out on a lot of bumps in the road did not have any bottoming out
    1998 Harley FatBoy
    2006 GL1800 Lehman trike Kit
    2 dogs and a wife
    Sep 2013
    Pittsford NY USA
    Default More info
    Hi Everyone I have not mounted my new tire yet but contacted Avon. I contacted them asking what air pressure should be in the new trike tire. Their response was that it should be 42-44 PSI. Anyone with mileage on their's I would like some feedback with how it changed the ride and handling if any.
    200+ Posts HarleyPap57's Avatar
    Jan 2015
    Mooresville, NC., USA
    Quote Originally Posted by Phu Cat View Post
    PC
    With this said, looks like I'm replacing my 16" front wheel with a 18" Chrome one so I can use this tire. Love the idea of having radials on both the front and back.
    2014 Big Blue Pearl / Vivid Black, 1.5" Lift Brackets, Street Cannon Mufflers, 10" Wind Splitter Windshield, Daymaker LED Fog Lights, Passing and Fog Lamps work on both High and Low Beams, BAL-1R Rear Taillights, Dunlop American Elite Rear MT90B16 (34AE92) on Front turned backwards, Dynojet Power Vision Turner, De-Cat Headpipe just for a start.
  1. Update Avon Cobra Trike tire
    By Hocky in forum Honda Trikes
    Last Post: 12-03-2016, 11:44 AM
  2. First impression of new Avon Cobra Trike front tire
    By mhgoldwing in forum Honda Trikes
    Last Post: 08-19-2016, 06:31 AM
  3. avon trike tire
    By irmagoo in forum Tires, Wheels, Brakes, Front End
    Last Post: 02-19-2015, 08:48 AM
  4. Avon Cobra Trike front tire #2
    Last Post: 12-04-2014, 08:02 AM
