Likes Likes:  6
Page 2 of 2 FirstFirst 1 2
Results 21 to 22 of 22
Thread: Throttle Lock
  1. #21
    4250+ Posts pcombe's Avatar
    Feb 2013
    casper,wy. usa
    With your customization of the back side and using your finger, does that mean you are able to rotate the fat part down because you are taking the tension off? If so that's not a bad idea. I've not put one on because I wasn't sure I could get it out of the way quickly. That would sure do the trick.
    yes it can work that way as well as flipping it over the grip backward, its easier to flip it backward though.
    If you have fringed grips it will also not get hung up on the seams.
  2. #22
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    Be sure you are using it correctly. Thumb lever down is ON. but you can roll thru it. Thumb lever up is OFF and throttle should work freely. Do not lube it. It holds the throttle using friction. the nut and spring provide the friction.
  1. Trunk Lock
    By Deeman in forum Harley Trike Conversions
    Last Post: 11-28-2016, 10:41 AM
  2. Do you use the 'Lock' key position?
    By rmrc51 in forum Honda Trikes
    Last Post: 03-31-2015, 02:57 AM
  3. Lock Jammed
    By biddlej in forum Honda Trikes
    Last Post: 08-29-2013, 11:03 PM
  4. Cannot Lock Handlebars
    Last Post: 11-18-2012, 02:08 PM
  5. What is the best way to lock my trailer up
    By Boscoporp in forum Trailers / Campers
    Last Post: 11-20-2011, 03:58 PM
