SSpoon9Marc HNew Member Introduct...Hello from VA
SSpoon9ZammyNew Member Introduct...Hello from VA
SSpoon9Uncle FesterNew Member Introduct...Hello from VA
SSpoon9rhino 2New Member Introduct...Hello from VA
SSpoon9trike ladyNew Member Introduct...Hello from VA
SSpoon9SullyNew Member Introduct...Hello from VA
SSpoon9Jack KlarichNew Member Introduct...Hello from VA
SSpoon9GorillaNew Member Introduct...Hello from VA
SSpoon9SSpoonNew Member Introduct...Hello from VA
Likes Likes:  17
Page 9 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 161 to 180 of 186
Thread: Harley Fluids What and Why!
  1. #161
    1+ Posts
    Nov 2011
    Bonita Springs, Fl. USA
    Default Re: Harley Fluids What and Why!
    Quote Originally Posted by 1852cc View Post
    Ok, just want to know what you all are running in twin cam's (ultras, trikes etc), and why you have settled on that brand and weights.
    What are you running in all 3 holes, motor, primary and trans.
    Thank You
    Mike
    I was told 20w50 mobil 1
  2. #162
    450+ Posts Bill G's Avatar
    Mar 2015
    Bakersfield California USA
    A good quality Dino or Synthetic oil will do the job that meets spec just change it according to or before manufactures spec's and the old Harley motors will go for a long time. I have seen 100.000 plus mile engines on both Syn and Dino oils.
    My self I prefer good old HD360 20/50 have tried others and find they work fine too but have come back to good old HD360. I also have found I don't care for the marbles rolling around in the top end sound that most synthetics cause. I have heard this sound with Amzoil, Syn3 and Mobile 1 oils. (not a wear issue with these oils at all just a sound issue, don't care for it) I don't care for Amzoils advertising at all and will not buy it again just a personal choice, it is a very good oil with that said. So for all the Amzoil guys don't rip into me thats just the way it is.
    For me HD360 20/50 in engine, Formula + in Primary. Spectro 6 speed Platinum 75/140 in trany or a good quality gear oil, Mobil 1, Bel Ray, and others will do just fine.(do not care for Syn3 at all in a trany and belive it will cause wear issues in time and have seen evidence of this a few times over the years also not a fan of it in the primary either but I personaly am not a fan of Sythetics in the primary anyway)
    Below answers some of the questions why good old HD360 is still used as a factory fill on bikes other than CVO models for what it's worth. This is what the MoCo says about HD-360, read lines 4 & 5 and what they say about HD-360 oil. Lines 4 & 5 answer some of the questions raised by many about Harleys HD360 conv oil. The MoCo point on# 8 has considerable value and makes a good point no matter which oil you choose to use. There will be many that still debate this though!!!!
    The Following Information was provide by Harley- Davidson Service, 3rd Floor.
    1. Why should I use Harley-Davidson motor oil? This is the only available motorcycle oil specially developed for Harley-Davidson motorcycle engines. It is also the only available oil tested for two years by our engineering staff on engine dynamometer stands in Milwaukee and motorcycle track tests at Talladega. And in other tests, Harley-Davidson has found it to be superior to other oils.
    2. Can I use aviation oils in my Harley-Davidson? We do not recommend this, because these oils do not contain an important additive that provides good wear protection of the Harley-Davidson engine.
    3. What viscosity grade should I use in my Harley-Davidson? The recommended viscosity grade for use in all temperatures is SAE 20W50 Harley-Davidson Oil. The SAE 50 grade is satisfactory in ambient temperatures of 60 deg to 90 deg F, and the SAE 60 grade is appropriate for ambient temperatures above 80 deg to over 100 deg F.
    4. At what temperature will Harley-Davidson HD360 break down? This oil has been designed for use at temperatures up to 300 deg F for extended periods with no significant breakdown.
    5. What oil temperature is best for my Harley-Davidson? A good oil operating temperature range is 200 deg to 240 deg F. Water condensation and acids tend to build up in the oil if the temperature is consistently below 180 deg F, and oil thickness can become marginal at temperatures above 300 deg F.
    6. Does Harley-Davidson Motorcycle Oil do anything besides lubricate engine parts? Yes. Besides lubricating engine parts and preventing wear, it protects the engine from rust and corrosion, keeps the inside of the engine clean, cools engine parts and "seals in" combustion pressures, prevents foaming, permits easy starting and quick oil circulation, and reduces friction and power loss.
    7. Is it true that oil never wears out? No. All motor oils wear out. During normal use, the oil molecules undergo a chemical reaction with oxygen and begin to break down; additives in the oil become depleted; and contaminants like water, gasoline, soot and dust get mixed in with the oil. Therefore, your motorcycle oil needs to be changed at the interval recommended by Harley-Davidson.
    8. Can I go longer between oil changes if I put in a new oil filter? No. The filter keeps the oil free of solid matter, but it doesn't remove water, gasoline or acids. Also, it can't pinch-hit for additives that become used up. Follow Harley-Davidson's recommended intervals for oil and oil filter changes, and don't expect a new filter to extend the life of the oil.
    9. Is it okay to mix Harley-Davidson Motorcycle Oil with a different brand? Harley-Davidson Motorcycle oil is compatible with other petroleum oils. However, mixing with another oil will reduce the superior engine protection of Harley-Davidson oil, so this should be done only when absolutely necessary.
    10. Does it help to put in a can of additive with each oil change? No. Just as you wouldn't add sugar to a bottle of soda, you shouldn't use additives with Harley-Davidson Motorcycle oil. It already contains the right additives in the correct amounts to last between recommended oil changes. More additives won't help. In Fact, they might upset the oil chemistry and create problems you wouldn't ordinarily have. Use Harley-Davidson Motorcycle Oil and forget the extra can of additive. It's money down the drain.
    For me good old HD360 20/50 has got the job done.
    Take Care All,
    Bill G
    Through Jesus Christ, I a sinner am saved. Not by my doing but through his doing by his sacrifice and Blood Shed on the Cross. His gift to all mankind that will only believe and accept him by Faith. Through his Death and Resurrection I am Saved by Grace and someday I will be with our Lord in Heaven forever.
  3. #163
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    2014 Touring maintenance manual chart 1-4.
    Maintenance schedule says (after 1K service) Engine oil + filter every 5K, Primary oil every 10K, Transmission every 20K.
    What are your thoughts?
    I'm using Syn3 in motor, Formula+ in Primary, Bel Ray 85W-140 in tranny.
    Any tips / tricks to doing the oil filter with the least amount of mess????
    Bob
  4. #164
    99500 + Posts
    rhino 2's Avatar
    Oct 2011
    Utopia New Jersey USA..
    Harley Syn. 3.. I have it changed every 5/6 thousand miles, All 3 holes at the same time.
    Makes the math easy, I just make an appointment and they do it while I Wait.. Plus the ride to the dealer is in PA 160 miles round trip, So that gives me a excuse to ride, And also make a stop across the river [Delaware] at my club in NY..
    2019 Tri-Glide.......
  5. #165
    Mar 2015
    Quote Originally Posted by HDB0B View Post
    Bob
    Bob they sell a special half funnel for lack of a better word that slides under the filter between the engine before you loosen the oil filter. It has a channel with a hose hooked to the bottom it that will guide the oil to a container of your choice. They have them available at the dealer it's a very handy cost effective tool to have.
    Ride Safe,
    Bill G
  6. DKCustoms postbit
  7. #166
    Jul 2014
    S.E. PA, USA
    Quote Originally Posted by Bill G View Post
    Ride Safe,
    Bill G
    I heard that it did not work that well with a trike because we don't lean and it has no drain angle. I guess I could drive one tire up on a car ramp to get some tilt. Thanks.
    Bob
  8. #167
    Dec 2014
    Grand Junction, Co. USA
    Bob
    I bought all the gadgets that hd sells ... actually pretty good
    The drain pan actually fits under the bike and holds all oils
    The primary fill funnel actually gets the oil in the primary
    The oil filter drain funnel is a little dicey, but if ya get it in the right spot, gets most of the oil in the funnel with only a little mess
  9. DKCustoms postbit
  10. #168
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Bob
    Thats how I service them, engine 5k, primary 10k and trans 20k. The oil filter is just a PIA, I've tried lots of gadgets and still have a mess. I just suck it up and pull the filter, then clean up the mess.
    http://i1347.photobucket.com/albums/...pswnuweejq.jpg
    Red Ultra Powered By Head-Quarters 120, Easy Clutch Pull By ClutchWIZ. 2012 GL1800 Hannigan. I've yet to ride a stock Harley which wasn't in need of a mechanical intervention.
  11. #169
    450+ Posts geezerglide11441's Avatar
    Apr 2013
    Redmond
    Quote Originally Posted by msocko3 View Post
    Thats how I service them, engine 5k, primary 10k and trans 20k. The oil filter is just a PIA, I've tried lots of gadgets and still have a mess. I just suck it out and pull the filter, then clean up the mess.
    I find it best to punch a hole in the filter at the top (OEM filter) and use the funnel. Then I rotate the filter in the OFF direction until the punched hole is at the bottom and leave it until the filter drains down. There may be a small amount still in the filter when removing, but it is a lot better (for me) than just toughing it out and cleaning up a mess!!
    Roger
    2013 TriGlide w/120st motor/PV w/TT Module/SE Roller Rockers/Smith Adj Push Rods/T-Man 577 cams/V&V Valve Springs/Wards Fans/SE Heavy Breather/High Capacity Oil Pan/Fuel Moto Power Duals/Kuryakn Slip-ons/2014 SE Compensator/2014 SE Clutch Assembly w/AIM VP024 Clutch Kit/Pro-Action Shocks/PS Mono-Tube fork assembly/Pntd Inner Faring/H-D Road Zeppelin Seat/Chrome Rear Bumper/Air Wing Luggage Rack/Garmin Road Tech Zumo 660/DK Customs Lift kit & Tour Pack leveling kit and Oil filter relocation kit.
  12. DKCustoms postbit
  13. #170
    750+ Posts
    Aug 2011
    Lake Murray, SC
    You suck the oil out instead of draining it?
  14. #171
    750+ Posts
    Aug 2011
    Lake Murray, SC
    Bob
    I have an oil cooler adaptor so the HD oil filter funnel will not fit all the way under the filter. I raise up the right side and then put the filter funnel under the filter as far as I can get it and punch a hole in the bottom end of the filter and let as much of the oil drain as I can, after it has drained a bit you can punch a small hole in the top end to vent it. Doesn't get it all but helps.
    I use Mobil 1 & HD filter, Red Line shock proof trans and Red Line Primary. I change everything 4,000 to 5000 miles. Think I will start doing the trans at every other oil change.
  15. #172
    Sep 2009
    NE Ohio
    Quote Originally Posted by Lakeman View Post
    Oh boy did I typo, it should have said suck it up, I'm going to fix that.
    Well I guess I can't fix that, it must be carved in stone after awhile.
  16. #173
    Dec 2014
    Fixed it for you ...
  17. #174
    750+ Posts
    Aug 2011
    Lake Murray, SC
    Nope you can't change it after an unknown time.
  18. #175
    20500+ Posts
    Zammy's Avatar
    Jan 2015
    W. Florida
    Just had my 1K service done and after doing a ton of reading I decided to go with Redline products, my HD dealer stocks it. 20/50 in the engine, V-Twin Primary Case Oil, and the V-Twin Transmission Oil with ShockProof. We've only got about 70 miles since the service, neutral is definitely a lot easier but I think I've got one of the noisy trannies, it still clunks and not just going into 1st gear.
  19. DKCustoms postbit
  20. #176
    Jul 2014
    S.E. PA, USA
    2014 with 18K miles
    I am now going to change my Primary fluid (Formula+) every time along with my engine oil (Syn3). That primary fluid really takes a beating. I am also using 40 ounces of primary fluid (38 ounces is standard wet fill for my primary cover type) per advice of my dealers master tech.
    Tranny (BelRay 85W-140) I will continue to change at every other oil change.
    Bob
  21. #177
    300+ Posts
    Dec 2014
    florissant
    mobil 20-50 in engine and primary, redline heavy shockproof in trans in the six speed and spectro in the five speed right now. either one is good top of the line lube.
    hardheaded
  22. #178
    Dead animals deserve balloons... MikeyTX's Avatar
    May 2016
    Big Bend Country, TX
    Default Mobil1
    20W50 engine 10W40 primary and whatever the weight is for the gear oil in the transmission. Synthetic
  23. #179
    10+ Posts
    Aug 2013
    Summerset, SD USA
    Default redline fluids
    I am using HD Syn just to avoid any warranty issues. I have been a fan of AMSol in my old bike but have been looking into Redline 20W50 transmission and primary fluids. The specs I have seen are equal or better then Amsoil. Anyone have any experience withe redline products?
  24. DKCustoms postbit
  25. #180
    May 2016
    Quote Originally Posted by harman View Post
    You will not have any warranty issues using any oil as long as it meets the specs. There are many H-D dealers that sell and install Amsoil or RedLine products.
    2021 Mustang GT Premium A10 Handling Pkg
    Red White and BBQ Texas, it's whole whole nother country .........
    [SIGPIC][/SIGPIC]​
  1. sportster fluids
    By drvndbus in forum Harley Trike Conversions
    Last Post: 09-07-2014, 07:05 PM
  2. we want a Harley
    By lboos in forum Harley Trike Conversions
    Last Post: 08-20-2014, 02:36 PM
  3. Harley's Gone
    By Johnlyn in forum Harley Trike Conversions
    Last Post: 09-08-2012, 10:57 AM
  4. Harley Reverse Trike - Morgan Threewheeler to Return with Harley Power
    By SBStormy in forum Harley Trike Conversions
    Last Post: 11-08-2010, 07:43 AM
