Likes Likes:  17
Page 2 of 10 FirstFirst 1 2 3 4 5 6 7 8 9 10 LastLast
Results 21 to 40 of 186
Thread: Harley Fluids What and Why!
  1. #21
    Default Re: Harley Fluids What and Why!
    Rick as stated above there is 2 scales on the stick. Some are on the same side some are on opposite sides. HD did that long ago because they planned for people attaching side cars to their bikes. Works great for us trikers.
  2. #22
    Jun 2010
    Indianapolis, In.
    Quote Originally Posted by Tonyd View Post
    Ok lets think for a minute....would you put trans fluid in your car engine? or motor oil in the rear end gear case? :no: NO right?......well why do you think is ok to put motor oil in all three holes cause some guy says do it from Harley...the people that want to sell more bikes .......So me...I run Red line 20w50 in the motor...motor oil......and Red line heavy duty shock proof gear oil in the trans.......and Red line MTL (manuel trans lube) in the primary :yes:
    BTW all syn.
    google it on the net
    just my 2 cents
    Tony
    And my .02 back at ya
    Syn 3 is touted as having been formulated for use in all 3 places on the Harley's. I understand the CVO bikes come w/Syn 3.
    Your statement is exactly one of the reasons Harley had different "stuff" available for each use, IMHO.
    Would the manufacturer mislead us:no:
    I think Syn3 is OK. I wonder about using it in my Gold Wing?
    Patriot Guard
    Was a LEO
    Part time Corrections Officer
  3. #23
    750+ Posts
    May 2009
    Down South
    Tonyd...Crisco is more like a grease....so it goes in the tranny. Run Wesson Oil in the primary! Sounds like a post I read on one of these oil argument threads where a guy said he ran "slippery oil". (LOL)
    Seriously now folks...I run Mobil1 VT20-50 in the engine most of the time, Mobil1 primary fluid in the chain case and a good grade of 75W140 synthetic in the transmission. I run an aftermarket 6-speed and it simply does not like anything but 75W140. I never have owned a Harley that would shift properly with any brand of 20-50 motor oil in the gearbox...be in Amsoil or Syn3.
    I actually do change up a bit now and then. Harley dino runs a lot quieter in the motor and reduces that little lifter-tap a few of us have. On the longer trips when I know I may not get to change it before a 4,000 to 5,000 run...I will run synthetic...and no..mixing it has never killed any engine I have ever owned. I have also ran ATF in the chain case just too see if it would explode....never has, nor has any good grade of 20-50 motor oil in there.
    I have a friend with an 02 Ultra that has never ran a thing other than HD dino and his just rolled over 160,000 miles a couple of weeks ago.
  4. #24
    The key is to take care of it and change the fluids.
  5. #25
    80+ Posts pin-hi's Avatar
    Jun 2009
    Cobble Hill, BC Canada
    Amsoil synthetic in my 1200 cc Harley Sportster trike. I switched to synthetic oil in my Subie cage years ago and happy so I wanted to go with synthetics in the trike as well. I recently read a Blackstone report of oil analysis on a Harley running Amsoil Synthetic and the report came back with excellent results. Just my opinion....
  7. #26
    750+ Posts
    May 2009
    Down South
    Amen there timigala! I never let mine go much past 3,000 miles on the motor, every other oil change on the primary and every third oil change on the transmission. Just keep the fluids fresh and you can run just about anything you want to...within reason.
    Personally, I think changing primary and tranny fluids at each oil change is a complete waste of time. The primary fluid is going to start looking dirty after a ride around the block anyway and I have never drained anything but clean fluid out of a transmission if I changed it at 3-4,000 mile intervals. That stuff will go 10,000 miles easy, but in any case....change it all once a year, even if it has done nothing but sit in the garage.
  8. #27
    Jul 2010
    jefferson tx usa
    Mobil 1 syn 20-50 v twin oil HD+ in primary , Mobil 1 syn gear lube 75-90 in tranny oh by the way hd syn 3 is a syn blend ,from what i read on some of the harley forums, just to let you know.as far as running dino oil in the primary i guess im oil school on putting syn in the clutch.but ive done it this way for the last 100,000 miles
  9. #28
    150+ Posts KRUZR's Avatar
    Oct 2010
    Aurora, IL, USA
    I run Amsoil 20W 50 in the motor, Bel-ray 85-140 in the trans and Formula Plus in the primary. There is White Paper data on the internet that clearly shows how it compares to other lube products. Check it out! I run the Bel-ray 85 -140 in the trans to quite it down. Ride Safe!
  10. #29
    In Memory of Bob Reeves trikes4ever's Avatar
    Aug 2010
    Lake Livingston, TX, USA
    Amsoil 20-50 engine and primary, Amsoil 75-90 in the trans - basically because my indy recommended it. Trans got quieter and easier to shift and find neutral, and oil temp is about 15 deg lower in summer. I'll probably switch to 20-50 in all three holes as that's what they recommend now for the TC, but won't be changing the trans fluid for a while. Just had a small leak (clutch cable) and patched it - fluid was crystal clear. I buy filters and cases of oil direct from Amsoil now. Previous ower used Syn3 and HD gear oil.
    2003 Deuce
    Triked with Frankenstein 34" Hot Rod rear
    Chrome everywhere - the Deuce comes that way
    My last VW trike build
  11. #30
    TOI - Pennsylvania White Knight 04's Avatar
    Sep 2010
    Rockland Pa. USA
    Quote Originally Posted by 1550vt View Post
    I agree I have used Mobil 1 for 45,000 mi in all three holes and never had a bit of trouble.... I did a cam and gear drive change to it at 24,000 when I tore it down there was very little wear and it look good in there except for the chain shoes inner and outer on both inner and outer chains....
    But we all know this is a weak spot in the twin cam 88...Mine were shot !!!
    I went with the Andrews 26g cams and S&S gear drive was definitely a very good choice it pulled like a truck after the change...
    I also went with a V/H fuel pack an Arlen Ness big sucker II and true duels with wild pig slash cuts and 2.5 baffles...:Computer: Just my 2 $ never have been able to put 2 cents in since I started riding Harleys 50 years ago it has always been Hundred Harley---- Dollars Davidson but would never have it any other way......Ride safe and long ...
    Jerry
  12. #31
    Aug 2010
    I listen to the experts
    That's funny. There's certainly no shortage of them.
    2003 Deuce
  13. #32
    100+ Posts mcdonaldroadcapt's Avatar
    Oct 2010
    Canton, Georgia
    Mobile 1 in engine and primary plus Reline Shockproof in tranny. Redline Shockproof is the best tranny lube you can use. Sticks to gears like glue and removes most noise from noisy 5th gears.
  14. #33
    150+ Posts
    Jan 2011
    Seaford, Delaware, USA
    Syn 3
  15. #34
    Sep 2010
    Rockland Pa. USA
    Mobil 1 all three holes, no problems in none of my Harleys....
    Never ride faster than your angel can fly !!
    Jerry & Linda
    Penna TOI ContactTOI #245
    2008 103 true duels, Master tune by TTS, Motor Trike I.S.Gladiator kit
    [SIGPIC][/SIGPIC]
  16. #35
    150+ Posts Southern Man's Avatar
    Jul 2010
    Axson, Georgia
    For all of the folks that want to do exactly what mother Motorcompany tells them to just try redline shockproof in the trans for (1) day. You will be amazed just how smooth it becomes within the first few gear changes.
    Also a note. If you take your "under warranty" Harley in to the dealership for a noise in the trans there is a 99% chance that they will replace the syn3 oil with Redline shockproof lube and give you back a quiter bike with a grim on their face.
    YOu will not find Redline on the shelf out from for sale but you will find it in the service area of the dealership.
    [SIGPIC][/SIGPIC]
    FAMOUS LAST WORDS: Don't worry boy's thoes Rebels could not hit an elephant at this distance. Gen. John Sedgewick @ Spotsylivania 1864.
    4 Heritage Springers all 2 wheels
    1997 x 2 Blue & White, 1999 Red,2002 Black
    2004 ~ GL1800/CSC Kit Black w Red pinstripes
  17. DKCustoms postbit
  18. #36
    600+ Posts 427dave's Avatar
    Jan 2011
    The Villages, FL
    Engine = Amsoil 20-50 for motorcycle
    Primary= Amsoil 10-40 for motorcycle
    Tranny= Amsoil 75-140 Gear oil
  19. #37
    30+ Posts cewhit1's Avatar
    Dec 2010
    Logansport, IN. USA
    Try RED LINE in the Tranny. Works great.
  20. #38
    Dec 2010
    Logansport, IN. USA
    Quote Originally Posted by 1852cc View Post
    Ok, just want to know what you all are running in twin cam's (ultras, trikes etc), and why you have settled on that brand and weights.
    What are you running in all 3 holes, motor, primary and trans.
    Thank You
    Mike
    I have a 09 HD Tri-Glide Ultra. I run Lucas 20-50 in Motor. Red Line in Trany and regular HD Primary in Primary. Works great.
  21. #39
    20+ Posts
    May 2011
    Epping, NH, USA
    Well,
    I just got a 2011 Triglide in April. Went over the 1000 mile threshold and went to my Mechanic for the 1k check.
    Syn3 20 - 50 in the primary and engine
    Redline in the tranny.
    Call me crazy but my trike shifts sooooo much better and finding Neutral is a breeze. Also I am getting 37 MPG over varying speeds since the oil change. At best I got 31 MPG before.
  22. #40
    20+ Posts bsickels's Avatar
    Aug 2010
    Collegeville, PA, USA
    Syn 3.
  1. sportster fluids
    By drvndbus in forum Harley Trike Conversions
    Last Post: 09-07-2014, 07:05 PM
  2. we want a Harley
    By lboos in forum Harley Trike Conversions
    Last Post: 08-20-2014, 02:36 PM
  3. Harley's Gone
    By Johnlyn in forum Harley Trike Conversions
    Last Post: 09-08-2012, 10:57 AM
  4. Harley Reverse Trike - Morgan Threewheeler to Return with Harley Power
    By SBStormy in forum Harley Trike Conversions
    Last Post: 11-08-2010, 07:43 AM
