Results 1 to 8 of 8
Thread: Question to help a good friend find an answer here...HELP
    70+ Posts Roadbuz's Avatar
    Jan 2015
    Deltona, Fl
    Default Question to help a good friend find an answer here...HELP
    Howdy Guys and Dolls,
    I have a good friend of mine (not a trike owner) who I've known for years and is always helping others with their problems, has the following problem :
    "I was swapping out LED bulbs on the front turn signal globes (already have rear and tail lamp LEDs) and tried to instal a module (Custom Dynamics Module Strobe HD #2050-0120) to make the tail lamp and rear signal globes flash when braking.
    Now I have a constant red key icon lit on the dashboard and the signal indicators both stay lit continuously. The signal globes flash normal when I push the button, but after a couple of normal blinks the go into a fast flash.
    I never got the Custom Dynamics module to work so I removed it and returned it to stock (less the HD converter that allows the signal globs on the rear to act a running lights like the tail lamp).
    With the flasher module on the system the brake light would not come on and the tail light would not come on."
    Any HD riders here willing to help us out ??? Thanks before hand...Ron
    4750+ Posts
    Mar 2015
    Texas
    When you go from incandescent to LED, don't you have to have a resistor somewhere to draw more load to make everything function properly? That has been my understanding. Where you do that I don't know. Electrical stuff is a near mystery to me.
    American Legion Rider
    I think you hit it on the head ... the red key is for the security system I believe. It needs that load to work properly ... contact the led manufacturer and they can tell ya what amp load ya need and where in the system to install it.
    500+ Posts WindyOne's Avatar
    Dec 2009
    Va.
    Quote Originally Posted by Roadbuz View Post
    I have a good friend of mine (not a trike owner)ewho I've known for years and is always helping others with their problems, has the following problem :
    Were there any directions with the module? I had to have one on my previous bike. I just connected it under the seat to a connector there provided in the instructions. Is it possible that you might have the wrong module for your trike?
    Agree with Fuzzy give a call to CD customer support. They will have you up and running quickly.
    20+ Posts
    Oct 2013
    Branford CT
    By changing the front signals to LED your removed to much load from the turn signal controller
    and now it thinks you have blown bulbs. Call Custom Dynamics tech support and they will tell you what load resistor you need and were it should be installed.
    Jan 2015
    Deltona, Fl
    Default Thanks
    Thanks gentlemen.....I've passed your responses along and my friend will contact their support reps Monday....Ron
    Gone But Never Forgotten dirtdobber's Avatar
    Jul 2011
    sand mountain, AL
    My suggestion is to contact cd.
    Or remove everything to get it back to stock, after inspecting that your lights are working normally start again. Most LCD conversions require a diode/ resister to keep the load within specs...
    Do a research and you can find how to make your own or buy one. In the front you can use majic adapter. I forget what they call it for the rear but the majic adapter won't work in the rear. Using LCD lights will cause them to flash fast. I will double check to see if I have any.
    According to Custom Dynamics you need to use a majic converter when using LCD lights on the tourpak or tail lights.
    http://i25.photobucket.com/albums/c5...an_cross_f.jpg
    20015 freewheeler
    2005 113 pro twin super glide
    2010 ss106 wide glide
    2004 1800 VTX custom
    2012 GW RS
    1000+ Posts Texan's Avatar
    Jun 2013
    Texas
    I had to install a BadLander module to get all my lights and turn signals to work properly.
    8~\o
  1. Replies: 6
    Last Post: 02-26-2016, 12:12 AM
  2. Rake Question: Cups good enough or what?
    By BearE in forum Tires, Wheels, Brakes, Front End
    Last Post: 11-15-2014, 04:05 PM
  3. good question.
    By tom w in forum The Gun Enthusiast
    Last Post: 02-18-2014, 09:39 PM
  4. Story of a good friend
    By Phill Griggs in forum General Discussion
    Last Post: 11-29-2013, 08:29 PM
  5. looked and looked- can't find answer
    By jackpoet in forum Honda Trikes
    Last Post: 02-09-2013, 10:49 PM
