Likes Likes:  6
Results 1 to 8 of 8
Thread: Front Wheel Wobble at SLOW Speed
    1+ Posts WCGeez's Avatar
    Mar 2015
    Manassas, VA
    Cool Front Wheel Wobble at SLOW Speed
    I recently purchased a 2003 Electra Glide Ultra Classic with a 2007 CSC Conversion. I have a major front wheel wobble, only at very slow speeds. She's smooth as silk at anything over 15 or 20 mph. I read some discussions here before about Bazooka's rake kits, but I can't find them now. I'm also having trouble finding a steering dampener that will fit the Ultra. Any help or advice would be much appreciated. Thanks!
    2500+ Posts Keystone's Avatar
    Jul 2010
    Minnesota
    I'm sure Zook will be along soon to direct you to the right parts.
    BKMNI
    2015 Harley FLRT
    2018 Can-Am F3 Limited
    Quote Originally Posted by WCGeez View Post
    have you checked the steering head bearing tightness? It needs to be tighter then what is specified for a 2 wheel setup. Also if it is not raked that will also help the issue but the bearing still will need to be tighter. Both is what makes the difference. Even then it still may have a slight shake but not objectionable. PM Bazooka for a rake kit.
    Ditto on Zook ... he'll know what to do
    Feb 2008
    Anderson, Missouri
    When we had a GL1500 with a standard front end there was a low speed wobble. Nothing dangerous, but noticeable. Added a rake kit, and not only did the ease of steering improve but the wobble went away.
    800+ Posts Trikindan's Avatar
    Lexington.SC USA
    Quote Originally Posted by Ozarkryder View Post
    Me Too!!!!
    JUST ME ON THREE
    1998 GW 1500 MotorTrike
    Saddle up boys...we're burning daylight!!
    "The Duke"
    Thank You Vets
    Sep 2009
    Near Myrtle Beach SC
  1. Front end/wheel wobble voyager
    By hd4bw in forum Outrigger Style Trikes
    Last Post: 05-14-2014, 07:54 AM
  2. wobble on front wheel
    By lbs12345 in forum Tires, Wheels, Brakes, Front End
    Last Post: 09-12-2011, 09:13 PM
  3. Low Speed Wobble
    By Alan Oakley in forum General Discussion
    Last Post: 11-19-2010, 05:17 PM
  4. Slow speed head shake
    By Saltywheels in forum General Discussion
    Last Post: 09-02-2010, 04:23 PM
  5. Goldwing front wheel wobble
    By ssdyle in forum Honda Trikes
    Last Post: 04-19-2009, 10:32 AM
Tags for this Thread
