Speed Bleeders
Likes Likes:  14
Page 3 of 3 FirstFirst 1 2 3
Results 41 to 60 of 60
Thread: Brakes and Clutch
  1. #41
    50+ Posts
    Aug 2012
    Nova Scotia, Canada
    Quote Originally Posted by DeathBySnuSnu View Post
    That does look like it would work.
    Now to figure out how to get it on the scooter.
    Mine is very similar. I cut the pivot out of the bracket and welded it in where I wanted it.
    But I need a single circuit master cylinder? I still don't know why I can't bleed and block off the front half
  2. #42
    850+ Posts vwbug72501's Avatar
    Apr 2015
    Batesville, AR. 72501
  3. #43
    50+ Posts
    Aug 2012
    Nova Scotia, Canada
  4. #44
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Quote Originally Posted by East Coast View Post
    That would probably work pretty good East Coast.
  5. #45
    50+ Posts
    Aug 2012
    Nova Scotia, Canada
    This one is a bit cheaper but not sure what size it is?
    http://www.ebay.com/itm/VOLKSWAGEN-V...d3b0ef&vxp=mtr
  6. #46
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Yep. A std buggy unit. A good choice.
    With a built in resivoir it has to be mounted level.
  7. #47
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    If you zoom in on the number of that master cylinder, it is merely a standard VW bug early style master cylinder. You can go to your local NAPA parts store and get one pretty much identical for cheaper. You can probably buy the res from them as well. Then you don't have to rely on Ebay sellers shipping the product to ya.
  8. #48
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    It don't say what size it is.
    But i do know that at least one of those stock type iron ones with the threads for the resivoir is a 22mm.
  9. #49
    50+ Posts
    Aug 2012
    Nova Scotia, Canada
    Quote Originally Posted by stinger608 View Post
    I will go and price one out there thanks, plus I would have to get the ebay seller to ship it to canada
    What year would I ask for?
  10. #50
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Do not get the 22mm bore unit.
    Make sure it is no bigger than 3/4 or 19mm.
  11. #51
    50+ Posts
    Aug 2012
    Nova Scotia, Canada
    ok but whats the difference?
  12. #52
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    A 34% difference in piston area.
    So the peddle will be 34% more difficult/stiffer/harder to push with the 22 than the 19.
  13. #53
    50+ Posts
    Aug 2012
    Nova Scotia, Canada
    oh ok, not sure what size I had in the mock up but it was easy to move with my hand
  14. #54
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Ok.
    That is not what I am talking about.
    The mock up is excellent for helping understand the mechanical connection to the master cylinder.*
    But what you are moving there is a near zero load.
    Now you have to be able to consume the kinetic energy of 1200 lbs traveling at 70mph and convert it to heat.
    You don't want a peddle that takes 800 lbs of force on it to stop you. This is where a mechanical advantage comes in. By multiplying the input with the ratio of levers and piston sizes you can create *a lot of force.
    It will take a small diameter master and a large slave to do this. You will need to change the wheel cylinders on the back also.
  15. #55
    Apr 2015
    Default Brakes and clutch
    Right on point Death. Here's a link that demonstrates the master/slave relationship. http://science.howstuffworks.com/tra...hydraulic1.htm One thing to notice is that the bigger cylinder has less stroke displacement than the smaller cylinder. So if your master cylinder is too small in relation to your slave you might not have enough stroke to apply the needed pressure to the brake shoes. Also consider the mechanical ratio of the pedal from foot pad to pivot and pivot to master cylinder tab. If you don't get this correct you might end up having to move your foot 18" to get enough stroke on the master cylinder to develop enough hydraulic pressure to push the shoes out and stop you. Could get exciting!
    Remember when you were sitting in high school math class wondering "When am I ever going to use this stuff?" Well, here it is.
    Another approach is to look at the pictures posted from other builds. If you can find something in the picture that you know the dimensions of, you can usually "guestimate" the dimensions that they are using.
  16. #56
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Exactly vwbug.
    Thanks for posting the link!
    That is why I do not recommend using a motorcycle master cylinder. Just not enough displacement, even more so for drum brakes. The automotive /dune buggy stuff usually have more stroke length.
    Still I would stay 17mm (11/16) to 19mm (3/4) master size and the 22.8mm super beetle front slaves nice condition drums and quality shoes. Or even better yet, get disc brakes.
  17. #57
    50+ Posts
    Aug 2012
    Nova Scotia, Canada
    ok thanks guys
    what year should I ask for? would it be for a bug or a bus?
  18. #58
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    We may need some help from the guys who know some more history.*
    But from what I remember. ..
    The dual cylinder came in 66 or 67.
    So i am gonna say 52 to 65 beetle if you are looking for cheap.
    I like that aluminum buggy one you found before.
  19. #59
    50+ Posts
    Aug 2012
    Nova Scotia, Canada
    yeah it was nicer looking and looked more for a bike, but it cost more and I would have to get it shipped into Canada
    your talking about this one http://www.ebay.com/itm/Unpolished-M...fc5005&vxp=mtr
  20. #60
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Yep that one.
    Also solves the problem of mounting the resivoir and/or rubber grommet/ tube of a stock type master.*
    I don't have the room for it on mine.
    So take in account where you are gonna mount it.
  1. Rear disc brakes, VERY HARD pedal, weak brakes????
    By TrikerDoone in forum VW Powered Trikes
    Last Post: 05-29-2016, 12:14 PM
  2. New Build Hydraulic Clutch/Brake Clutch Pedal Fabrication
    By usnavy8084 in forum Home Built Trikes
    Last Post: 10-21-2012, 08:18 AM
  3. VW clutch
    By Snyiper in forum VW Powered Trikes
    Last Post: 05-26-2011, 09:04 AM
  4. clutch
    By sprayman in forum General Discussion
    Last Post: 05-29-2010, 08:50 PM
  5. Clutch
    By jwall11 in forum Harley Trike Conversions
    Last Post: 11-17-2009, 07:15 PM
