Likes Likes:  2
Results 1 to 6 of 6
Thread: Turn Signal Indicator Lights
    80+ Posts Roadie's Avatar
    Oct 2013
    Fredericksburg, VA
    Default Turn Signal Indicator Lights
    "08 Yamaha Road Star W/Champion Conversion
    Here's what I did - Took off OEM running lights/turn signals -
    Rear signals are LED and fronts are not -
    Installed Harley style (bullet) front signals -
    Had to add additional load equalizer (Champion uses one for the rear LEDS) too keep all signals from fast flashing -
    The issue is, the signal indicator lights on the dash fast flash (very dimly) steady when engine is running - When I hit the turn switch (R or L) that light flashes as it should and the other indicator light still fast
    flashes (brighter) -
    All signals work as they should, it's just the indicator lights that are freaking out!
    I hate electrics - any ideas ?
    Oct 2013
    Fredericksburg, VA
    One other thing - Anybody know the color of the wires that operate the two indicator lights - Will render them inop if need be - Don't really need them to know if my signals are on.
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    Quote Originally Posted by Roadie View Post
    Remove the load equalizer and install an electronic flasher.
    Oct 2013
    Fredericksburg, VA
    Electronic Flasher? Any more info you can give would be much appreciated.
    Jan 2013
    the signal flasher that controls the turn signals. About 1" sq. cube. I don't know where it located on your bike.
    Found this for you. It's under the right side cover.
    Re:Turn signal flasher location 5 Months, 3 Weeks ago
    Like Erbman02 said. Right behind the rear cylinder, where the two side covers meet, there is an Allen head screw that helps holds the right cover on. You have to get at it from the left side after removing the left cover first.
    Oct 2013
    Fredericksburg, VA
    Got wiring diagram from a guy in the know on RS Clinic and did the snip snip now all is right with the would.
  1. Turn Signal
    By shadow in forum Honda Trikes
    Last Post: 11-17-2014, 01:33 PM
  2. Roadsmith Turn Signal
    By Blueribbon in forum Honda Trikes
    Last Post: 08-25-2014, 09:02 AM
  3. Turn Signal
    Last Post: 08-18-2013, 09:17 AM
  4. Turn Signal Cancellation
    By bluesuedeshoes in forum Harley Trike Conversions
    Last Post: 12-11-2009, 11:12 AM
