Results 1 to 8 of 8
Thread: Question for my fellow Road Star Trikers
    200+ Posts dbruce56's Avatar
    Nov 2014
    Salem, Al
    Default Question for my fellow Road Star Trikers
    With a Champion conversion. Are any of y'all running an aftermarket exhaust? If so what are you running?
    OK, two questions,,,,
    20+ Posts
    Jan 2012
    hyattsville, MD
    Default Question for my fellow Road Star trikers
    Yes. I bought the bike with Bub Stubbies on it.
    Needless to say, had heat and exhaust fume issues after the conversion.
    Found a shop locally that mandrel bends exhaust systems for hot rods and muscle cars.
    They did pipe extensions in stainless for me in 2". real nice work for reasonable $$$$.
    Nov 2014
    Salem, Al
    And another question,,,, How are you determining if your bely is properly adjusted? It looks like with the Champion kit the belt check window is gone. I'm assuming it was a part of the original swing arm.
    80+ Posts Roadie's Avatar
    Oct 2013
    Fredericksburg, VA
    I use the usual 10 lb tension tool and made a measuring device to determine how much slack there is in the belt.
    Nov 2014
    Salem, Al
    Roadie, do you have the measurements for that device. I'll have to fab one up.
    Oct 2013
    Fredericksburg, VA
    Should have approx. 6-8 mm or 1/4 - 3/8 in slack in the middle of belt. Made sure you use the tool that allows you to put 10lb of upward pressure on the belt to get a good measurement.
    Nov 2014
    Salem, Al
    Looks like I'll get the tension gauge and then play with tension until I get it right in that ballpark then make a device to make it easier for the next adjustment.
    Nov 2020
    merritt island
    Default Anybody got stock champion Roadstar exhaust
    Does anyone have a stock Yamaha roadster OEM exhaust with the champion adapters that go in the middle and the Chrome piece that goes on the back of the muffler
  1. Triking a Road Star
    Last Post: 03-21-2022, 06:45 PM
  2. Champion/Road Star Build
    Last Post: 04-26-2014, 12:09 AM
  3. No More Champion/Road Star kits
    Last Post: 12-28-2013, 01:13 PM
  4. Hello to all Star Silverado Trikers
    By BobLuke in forum New Member Introductions
    Last Post: 11-04-2013, 03:08 PM
  5. Hello fellow Trikers
    By Zorro in forum General Discussion
    Last Post: 01-11-2013, 02:49 PM
