Results 1 to 7 of 7
Thread: fuel shut down switch
    Nov 2010
    Newbern Tenn.
    Default fuel shut down switch
    I hit a pot-hole and the fuel shut off switch cut the fuel off. It also will blow a 40 fuse when this happens. I had to replace the fuel shut off switch. It must have go weak with age. If you do not reset the shut off switch it will blow a fuse every time you replace one.
    950+ Posts
    Jun 2013
    DFW, Texas
    Just where is this thing located???
    Its under the seat next to the fuse box. Has a red button on top. I have had to reset it only once in 7 years from hitting a really big bump. Did not blow a fuse.
    950+ Posts
    Jun 2013
    DFW, Texas
    Thanks.
    450+ Posts rocket1lf's Avatar
    Dec 2013
    Hot Arizona, USA
    Gorilla, I would like to thank you so much. I've been getting the trike ready for a 2000 mile trip leaving Sunday. I saw the red button but didn't know that this thing had a fuel cut-off like a car. I went out tonight to take it out and adjust the lights I have under the mirrors and it wouldn't start. I remembered this thread, pulled the seat and the button was out. I reset it and wham the trike started.
    There is going to be a lot of rain in Colorado where we're going, so I'm curious as to whether or not that cruise/brake light switch will fail. I called Richard and asked about getting a newer style one, that is supposed to be better in the rain, but he said mine should be fine. I guess I'll find out.
    By the way, the HID's I installed work great. I put it on a dark street and I could see several hundred feet with just the low beam and when I turned on the high beam, it went quite a bit farther. I had the air bags set at 32, so the front was not high. I walked down the street and checked and the low beam was not pointing up into on coming traffic.
    Stallion #378
    Suzuki Burgman 650
    your welcome and enjoy the trip. ride safe
    Dec 2013
    Hot Arizona, USA
    Right now we're in Estes Park, CO. We've had rain for the past 3 days on the road. A couple of small wacky things have happened on the trike from the rain, but nothing drastic. We'll be back Saturday. Hope it stops raining before then.
    Stallion #378
    Suzuki Burgman 650
  1. A/C shut off
    By Doc7402 in forum Stallion Trikes
    Last Post: 07-17-2014, 08:10 AM
  2. Gas dripping after shut off
    By esa3 in forum Honda Trikes
    Last Post: 09-29-2013, 12:12 PM
  3. rear cly. shut down
    By lboos in forum Harley Trike Conversions
    Last Post: 02-12-2013, 04:17 PM
  4. Stallion's Fuel Line Shut Off
    By Jerry126 in forum Stallion Trikes
    Last Post: 10-11-2012, 11:05 AM
