Likes Likes:  12
Page 2 of 2 FirstFirst 1 2
Results 21 to 30 of 30
Thread: 2015 FLRT Rear Wiring Harness Insert
  1. #21
    Dec 2015
    Fallbrook,ca,usa
    Default Freewheeler trailer wiring harness-plug and play
    Quote Originally Posted by Springman2007 View Post
    Keystone,
    Your premade insert is most likely cheaper than ordering the HD parts and its pre-made. Please post details on it - maker, place of purchase, part number, and price.....
    Springman
    Quote Originally Posted by Keystone View Post
    Just bought a harness to run my trailer. They use the same/similar set up. Plugs in and add the proper plug for the trailer is all.
    Quote Originally Posted by GLT View Post
    Ok, all is good. I'll make one or two. Safe travel.
    Did Keystone find a vendor that makes this harness?
  2. #22
    2500+ Posts Keystone's Avatar
    Jul 2010
    Minnesota
    Quote Originally Posted by dmj1970 View Post
    No I did not. I found two that claim theirs fits, but they don't.
    BKMNI
    2015 Harley FLRT
    2018 Can-Am F3 Limited
  3. #23
    Dec 2015
    Fallbrook,ca,usa
    I spoke with Sandy at Open Road Outfitters. She thinks her electrical supplier will have one within 2 weeks. Maybe a contact from you will confirm that it is for a freewheeler. I've had the same results as you, where two different vendors have sent a harness they thought would work, but did not. Since the Freewheeler has become more popular, you'd think someone would make this part.
  4. #24
    70+ Posts topsgt75's Avatar
    Jul 2015
    Lexington, Ky
    FYI.... I just put on a hitch and wiring harness for my Freewheeler. Got them from Open Road outfitters. They have a trailer harness just for the Freewheeler now!!! Saved a lot of time and headaches!!!
  5. #25
    Mar 2016
    Auburn, NH
    Default Has anyone found a supplier of the 8 pin molex cnnector for rear lighiting?
    Seems evevyone sells the 6 pin molex adapter that won't work on my 2016 Freewheeler. Need the 8 pin adapter as seen in the start of this thread. Not into getting all the items from HD but will if I have to.. Bueler?
  6. #26
    Jul 2015
    Lexington, Ky
    At the end of March Open Road Outfitters had the 8 pin harness for the Freewheeler!
  7. #27
    Mar 2016
    Auburn, NH
    Quote Originally Posted by topsgt75 View Post
    Would you happen to have the link? I have been looking every where... Thank you for your post!
  8. #28
    Jul 2015
    Lexington, Ky
    Quote Originally Posted by Jaycee1964 View Post
    Here you go:
    http://www.openroadoutfitters.com/in...roducts_id=466
  9. #29
    # 30 and 25 is where the wire harness should pass thru the body from under the seat, I cannot believe this is not stock on ALL trikes I aint paying 85.00 for some thing that should already be there, I have a magnetic LED light hung in my trunk
  10. #30
    350+ Posts Springman2007's Avatar
    Sep 2014
    Grafton, OH, USA
    Default Freewheeler Hiring Harness Insert - UPDATE
    Sub-Harness for 2015+ Freewheeler only (Rear Wiring Harness Insert) from www.electricalconnection.com
    cost is $24.95
    To Explain. The above is a pre-made insert made like the one I originally built and made in my initial post to this thread.
    This unit is again pre-made - and a lot cheaper. SO, I thought this may help some of you out there.
    Springmag
  1. RS trailer wiring harness
    By wiredgeorge in forum Roadsmith Trikes
    Owners Forum
    Last Post: 08-22-2014, 06:35 PM
  2. trailer wiring harness
    By sassoman in forum Can Am Spyder Trikes
    Last Post: 04-25-2014, 09:54 PM
  3. trailer wiring harness
    By greybeard.3 in forum Trailers / Campers
    Last Post: 02-23-2013, 10:51 AM
  4. trailer wiring harness
    By fordor328 in forum Trailers / Campers
    Last Post: 12-02-2012, 09:28 AM
  5. Hitch & Wiring Harness for Yamaha
    By BinIdaho in forum Yamaha Trikes
    Last Post: 08-01-2011, 11:20 AM
