Results 1 to 4 of 4
Thread: RSV/Hannigan exhaust and electric reverse questions
    950+ Posts
    Oct 2014
    Rochester, NH, USA
    Default RSV/Hannigan exhaust and electric reverse questions
    Need some suggestions for aftermarket exhaust.
    I wanted my Baron's Nastyboy 2-4-2's put on my trike but since the rear end only has the mouse hole cut out I don't think they will fit or look good.
    Just looked at another set of pipes from Baron's Custom but they say the bracket raises the pipes to give more ground clearance. Thinking they would need a custom bracket designed for proper fit up.
    Also, I tested the electric reverse on my test ride today. First time I hit the switch, I almost crapped my pants. The trike jerked backwards at a pretty good clip and it was very loud. Is that normal? Can the electric motor be adjusted so it's smoother? Any tricks backing up without the jerking?
    800+ Posts Motorcycle Mike's Avatar
    Jul 2014
    Lawrenceville, Ga
    I can't help with the exaust but your reverse sounds normal. Your owners manual even warns, "Press reverse switch cautiously, as initial engagement is powerfull and quick." I've got used to it, Shirley, not so much. Even when I warn her it startels her.
    There may be some way to step down the voltage on the motor but I sure don't know how.
    You don't quit riding because you get old.
    You get old because you quit riding.
    Mike & Shirley
    950+ Posts
    Oct 2014
    Rochester, NH, USA
    Quote Originally Posted by Motorcycle Mike View Post
    good info!! I was told to give a very short pull on the toggle and let off....still a surprise the first time..LOL
    Since I have not taken possession of the trike yet I have not owner's manuals. The shop is going to contact someone to see if anything can be adjusted.
    Good news is I plan on going forward 99.99999% of the time
    700+ Posts kybigmac's Avatar
    Oct 2014
    murray.ky usa
    That's a good plan!
  1. CSC electric reverse
    By bflonez in forum California Sidecar Trikes
    Owners Forum
    Last Post: 03-30-2013, 06:14 AM
  2. electric reverse for trike
    By Fabio70 in forum Harley Trike Conversions
    Last Post: 10-15-2011, 03:56 PM
  3. Electric Reverse
    By Ironhorsepilot in forum Harley Trike Conversions
    Last Post: 02-16-2011, 12:42 AM
  4. questions about champion exhaust
    By WEB in forum Harley Trike Conversions
    Last Post: 01-17-2009, 04:50 AM
  5. questions on reverse
    Last Post: 06-01-2008, 08:54 AM
