SSpoon7Uncle FesterNew Member Introduct...Hello from VA
SSpoon7rhino 2New Member Introduct...Hello from VA
SSpoon7trike ladyNew Member Introduct...Hello from VA
SSpoon7SullyNew Member Introduct...Hello from VA
SSpoon7Jack KlarichNew Member Introduct...Hello from VA
SSpoon7GorillaNew Member Introduct...Hello from VA
SSpoon7SSpoonNew Member Introduct...Hello from VA
Likes Likes:  3
Results 1 to 11 of 11
Thread: coil relocation
    200+ Posts
    Apr 2015
    pineville, la
    Default coil relocation
    I am going from dual webers to a single weber and the coil is going to be in the way. It is mounted right by the fuel pump. Looks like the old bugs with single carbs had the coil mounted on the fan shroud or cover. I wonder if it as mounted with a sheet metal screw or a bolt with nuts on the back side. Anyone know or where do they have their coil mounted. A picture would be good. I don't take directions too well. Thanks
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    I can get ya a picture this evening bro.
    As your looking at the engine; the coil mounts on the left hand side of the fan shroud. About half way up from the cylinder tin. There should be a couple of holes already in the shroud for the coil bracket.
    But I'll shoot a picture tonight and post it here for ya.
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
Size:  358.5 KBName:  IMG04140-20111116-0129.jpg
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Quote Originally Posted by Rsw View Post
    Yep, there ya go man. That is exactly what I was about to go out and take a picture of.
    Thanks for posting that up Rsw!
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    You don't have to absolutely put it only there.
    That is a handy place and stock plug wires fit it there.
    It will function anywhere you can get wires to.
    Mine used to be mounted under the starter.
  6. #6
    200+ Posts
    Apr 2015
    pineville, la
    Thanks for the pictures. I will probably try and go with the firewall mount. My coil has only one bolt to hold it. I have a aftermarket fan shroud. I wounder if it is thick enough to use a sheet metal screw to hold the coil and bracket. I may also look at the starter mount also. Thanks for the pictures an suggestions.
    Quote Originally Posted by DeathBySnuSnu View Post
  7. #7
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    O I see.
    The factory style housing has nutserts in it. Which is a nut made in it.
    Definitely need 2 bolts holding it.
    Not all coils are ok mounted tower down.
    If it is a bosch blue or one intended for a vw tower down is ok.
    Self drilling tapping screws tend to come loose with vibration.
    My pic was just to show that it don't have to be on the fan. For example if you did not want to drill holes in your shiny fan housing you could mount it in any convenient location.
  8. #8
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    On the firewall will probably work great. You'll just have to get a long coil to distributor wire.
  9. #9
    200+ Posts
    Apr 2015
    pineville, la
    I wonder if there is any way to mount mine to the firewall without the nuts that are made in to the firewall. I would like to mount it the fan shroud if I could. The one I have will work laying down so I could mount it somewhere else. Any more ideas?
    Quote Originally Posted by stinger608 View Post
    Death, I forgot to ask . Is that a single bolt coil bracket you used to mount the coil by the starter. I have a single bolt on mine but I have a two bolt ordered in case I have to use a to bolt instead of a a one bolt. I can't make it out in the picture. Thanks
    Quote Originally Posted by starrider1946 View Post
  10. #10
    VW Tech Contributor
    TrikeTalk Moderator
    Mar 2012
    Vicksburg MS USA
    Stock 2 bolt. I don't like the single bolt for hanging a coil. Maybe if it is layer flat, but not hanging.
    Find someone with a nutsert gun and pop two nuts in. They go in from the outside like a big pop rivet.
    Or take the fan housing off and weld two nuts to the inside of it.
    Or take it off and bolt a nut plate inside of it.
    Or take it off and drill the hole and put a bolt from the inside with a jam nut on the outside, leaving a stud sticking out to mount too.
    Or just bolt it solid up and put the fan housing on and worry about how to service it later.
  11. #11
    200+ Posts
    Apr 2015
    pineville, la
    I ordered me two bolt holder. I have a feeling I will mount it somewhere else. I don't want to pull the fan housing off. The insert gun sounds good but I don't know anyone who has one. Man it's always something. Got all my stuff in today. I've also got to figure out someplace to mount a breather but I think I've figured that out. The guys at carcraftstore store said it had to be vented in at least two places. Does that sound right? Hopefully I'll get it figured out. Thanks for the suggestions.
  1. DK Coil and Coil/Key Relocation Customer Review and Pics
    By DK Custom Products in forum DK Custom Products
    Last Post: 04-26-2023, 01:28 PM
  2. Motor Trike Coil Over Shocks
    By jmoraniii in forum Honda Trikes
    Last Post: 05-05-2014, 09:18 PM
  3. Stupid coil question
    By vwjoe in forum VW Powered Trikes
    Last Post: 01-08-2012, 08:33 PM
  4. coil springs on a champion trike
    By tingrin in forum Miscellaneous
    Last Post: 03-12-2011, 10:28 PM
  5. air bags??? or coil over shocks
    By cra-ze-trikeman in forum Motor Trike
    Last Post: 01-06-2010, 09:00 PM
