SSpoon4SullyNew Member Introduct...Hello from VA
SSpoon4Jack KlarichNew Member Introduct...Hello from VA
SSpoon4GorillaNew Member Introduct...Hello from VA
SSpoon4SSpoonNew Member Introduct...Hello from VA
Likes Likes:  10
Results 1 to 14 of 14
Thread: Linked Brake System Info And Explanation Of How It Works
    450+ Posts Bill G's Avatar
    Mar 2015
    Bakersfield California USA
    Default Linked Brake System Info And Explanation Of How It Works
    I read everything in my Trike service Manuel today concerning the linked brakes. It said nothing about any special adjustments needed. It did however go into detail about a specific way the linked brake system is suppose to be bled and serviced. If this is not done correctly there could be issues or if there is a plugged or blocked bleed back valve on the front there could be braking issues. There were several symptoms mentioned which included dragging or locking brakes.
    This is how the Linked Brake system functions according to the manual.
    The rear brake peddle activates the middle pistons in the front brake calipers when applied along with the rear brakes. The front brake applies the rest of the pistons in the front calipers when applied. The outside line to each front caliper is from the rear brake peddle. The front brake by it self only operates the front brakes.
    Ride Safe All,
    Bill G
    Through Jesus Christ, I a sinner am saved. Not by my doing but through his doing by his sacrifice and Blood Shed on the Cross. His gift to all mankind that will only believe and accept him by Faith. Through his Death and Resurrection I am Saved by Grace and someday I will be with our Lord in Heaven forever.
    1000+ Posts screwball's Avatar
    Santa Clarita, SoCa & Bullhead City, Az
    Need to sit and do a 'look-see' at reversing the pedal / lever. My old Polaris Quads had a break lever that did both, and a pedal for just the rear breaks. It would be SOOoooooo much easier for crippled old me to do most of the breaking with my hand.
    http://www.triketalk.com/forum/custo...epic4494_1.gif
    Why 3 wheels?
    because 2 isn't enough and 4 is too many
    We are really Steve & Vesta Brown
    Her: 2014 Tri-Glide Me: 2015 Freewheeler
    Vietnam Vet 1967-68 U.S. Air Force
    100+ Posts hdruss's Avatar
    Mar 2011
    chicago,illinois
    Quote Originally Posted by screwball View Post
    I am curious whether you did a "look see" and came up with a way to brake with your hand - Russ
    Black '19 FLRT , Detachable Bat Wing Fairing
    '82 FXR Being Triked
    TOI #01075, ABATE of IL. & MI., BTW, HOG
    60+ Posts
    Jun 2015
    Tickfaw, LA, United States
    Default Looking for break mod info.
    I'm a right A/K amputee currently riding a 2015 Freewheeler. Looking for info on how to modify brakes so right hand lever operates front and back. The local Harley shop tried a modification that left me with locked up front brakes about 5 miles from home. Another possibility would be a rear brake pedal on the left side of the trike. Currently using a RIDE-ABLE pneumatic system for the rear, but it lacks the sensitivity of hand or foot operation. No one I know of in Louisiana does these kinds of mods. Any help would be appreciated!!
    Quote Originally Posted by FleshWound View Post
    Adjustable combo valve from summit racing?
    30+ Posts
    May 2013
    Elmhurst
    Default Unified bracking
    My understanding from an HD tech was that this system IS UNIFIED when your speed is under 25 MPH this is when it kicks in. So being an avid down shifter I just wait until thats my speed.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Jim Murphy
    Iron Butt Rider 2001
    I would still opt for an adjustable combo valve JMO With braided steel lines, Flush the fluid once a year
    Use these to test the copper content of your fluid
    Available at any good parts store
    20+ Posts
    Lafayette IN
    I don't know if you've figured yours out yet or not but i built a Sporty trike last year and built a system where my front and rear works off my front brake lever. I used a wilwood distribution/ proportioning valve so I could adjust how much brake went where and I used goodridge sniper brake lines and fittings that I got from tcbros.com and it works great!
    5000+ Posts MDO's Avatar
    Oct 2017
    St. Louis, MO USA
    I'm a little late to this topic, but could someone explain the basics of bleeding the Freewheeler linked brake system?
    20+ Posts
    Lafayette IN
    A vacuum bleeder would probably be your best bet.
    Oct 2017
    St. Louis, MO USA
    I probably wasn't clear & I apologise.
    I understand the basic procedure of bleeding & have done it on cars & bikes,
    But as the OP mentioned, I have heard there is a specific procedure because of the linked system, i.e.
    due what bleeder 1st, 2nd, etc.
    Oct 2017
    St. Louis, MO USA
    I recently purchased an electronic service manual covering my 2017 FW. I has the specific order to bleed the brakes.
    If you don't have 1 of these manuals & like myself, do your own maintenance, it is well worth it.
    Oct 2017
    St. Louis, MO USA
    Never mind, I'm having technical difficulties.
  1. Need Lehman disc brake info
    By suvcw04 in forum Honda Trikes
    Last Post: 07-29-2013, 09:41 AM
  2. Motortrike Drum Brake Rattling Info
    By FLTR2008TRIKE in forum Motor Trike
    Last Post: 08-29-2012, 06:55 PM
  3. attn. anyone installing the perf. machine stage 1 brake system(help)
    By eagle1 in forum Harley Trike Conversions
    Last Post: 02-20-2012, 10:15 AM
  4. K-Lever Brake System
    By Aussie Annie in forum Harley Trike Conversions
    Last Post: 12-13-2011, 12:30 AM
