Likes Likes:  1
Results 1 to 10 of 10
Thread: Floorboard removal/ speaker replacement
    20+ Posts
    Jan 2015
    Bloomfield Hills, Mi. USA
    Default Floorboard removal/ speaker replacement
    Howdy
    Can anyone tell me how easy/difficult it is to remove/re-install the right floorboard on a RSV Hannigan? I need a small area repaired and painted. The body shop estimates 3-5 days and they don't have a lift that will work on the trike so they insist on removing the floorboard. If I can bring them just the floorboard I can save money on labor and not tie up the entire trike!
    Also has anyone replaced their stock speakers with the Polk 4" DB401's and was there a noticeable
    improvement in sound quality?
    mozrocks
    300+ Posts Cougar's Avatar
    Mar 2009
    Near-Iowa City,Iowa
    Polk 4" DB401's and yes there a noticeable diff.
    Call Jim G at Hannigan and ask him how to remove it.
    Jim Gooch
    Hannigan Motorsports
    270-753-4256 ext. 225
    OR
    email him.. phone is faster
    Jim <jim.hms@apex.net>
    20+ Posts
    Jan 2015
    Quote Originally Posted by Cougar View Post
    Jim Gooch
    OR
    Cougar
    Thanks for the response! I installed the Polk's in the front and yes they sound good but I noticed distortion at higher volume. Is this caused by clipping? Do I need to install an amplifier? If so can anyone recommend an amp that will clean up the distortion?
    Mar 2009
    Near-Iowa City,Iowa
    I have tried amps, don't bother.
    For the distortion you can try bass blockers, your (our) problem is all in the radio head. you will never get better then what you have now. so save your time and money.
    The problem is the front fairing as you will notice better performance from the rears as they are better closed in. hope all this makes since to you.
    20+ Posts
    Jan 2015
    Yep, makes sense! I think I'm having a senior moment as I'm staring at the rear speakers and wondering how to crack them open? Do I need to pull the trunk off? I pulled the rubber pad off the top and removed 3 screws and that's where I'm at!
    mozrocks
    Mar 2009
    Near-Iowa City,Iowa
    Nope just carefully lift the arm rest pads off the arms.
    I am OLD to LOL , remove rear seat for some room if needed
    It is held on with grey 3M tape, might want to have some laying around
    just in case, I have been able to re-use mine several times.
    Then I think you can handle it from there :-)
    Keep us posted.
    Jeff
    I think I did a write up on it years ago at the venture site.
    Or its also on the other ventuers site as well.
    20+ Posts
    Jan 2015
    Nope just carefully lift the arm rest pads off the arms. I am OLD to LOL , remove rear seat for some room if needed It is held on with grey 3M tape, might want to have some laying around just in case, I have been able to re-use mine several times. Then I think you can handle it from there :-) Keep us posted. Jeff I think I did a write up on it years ago at the venture site. Or its also on the other ventuers site as well.
    Well I got one side almost apart but something is keeping it together at the bottom of the enclosure! I don't know if there's a screw or what? I don't want to be too heavy handed with ABS. Has anyone else had this issue? mozrocks
    Mar 2009
    Near-Iowa City,Iowa
    look under the arm :-)
    20+ Posts
    Jan 2015
    I found the lower screw but not accessible due to trike body so I had to detach the trunk for screw access.
    Mar 2009
    Near-Iowa City,Iowa
    Stubby Screw Driver should work just fine. anyways ya got the hang of it now :-)
  1. Speaker distortion in 2015 TriGlide
    By vbbuilt in forum Harley Tri Glide
    Last Post: 09-17-2014, 06:32 PM
  2. SPEAKER
    By cjmitch in forum Honda Trikes
    Last Post: 06-26-2013, 02:21 PM
  3. rear speaker wires
    By cwlemu in forum Honda Trikes
    Last Post: 04-08-2013, 09:38 PM
  4. Helmet speaker replacement
    By GoSlo in forum Harley Trike Conversions
    Last Post: 12-26-2012, 10:44 PM
  5. speaker covers from Performance Machine
    By morrishuckeba in forum General Discussion
    Last Post: 08-14-2011, 05:49 PM
