Likes Likes:  11
Page 1 of 3 1 2 3 LastLast
Results 1 to 20 of 47
Thread: coverting a Trike Glide to independent suspension
    Oct 2012
    Jasper,Ga.30143/USA
    Default coverting a Trike Glide to independent suspension
    This may be a dumb question can a Trike Glide Soild Axe be replace with independent suspension
    2500+ Posts Keystone's Avatar
    Jul 2010
    Minnesota
    BKMNI
    2015 Harley FLRT
    2018 Can-Am F3 Limited
    I'm guessing that's a few shekels ... $$$$ ... and the whole warranty thing comes to mind.
    9750+ Posts Rod69's Avatar
    Dec 2011
    Lawrenceville Il. USA
    Sure would be nice to try out. Don't like to buy before I try.
    Rod69 Illinois TOI #900
    Joan71 Illinois TOI #901
    300+ Posts J.T.M.'s Avatar
    Jan 2015
    Buffalo, Ky, USA
    I am sure it could be done but why not buy something with independent suspension and sell the tri glide. Would probably be cheaper.
    $6K for parts and installation.
    Quote Originally Posted by Clint44 View Post
    Might be worth looking into when the warranty runs out.
    Jan 2015
    Buffalo, Ky, USA
    At 6k it would be worth looking into.
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    I talked to DFT & they will let you do the install if there isn't an authorized dealer around. Cuts the price quite a bit.
    You end up with the Harley wheels also.
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
  11. #10
    350+ Posts Springman2007's Avatar
    Sep 2014
    Grafton, OH, USA
    OK, if it will fit a TriGlide.....will it work on a Freewheeler?
    Now, that may be a Freewheeler Mod to consider................
    Springman
  12. #11
    300+ Posts 0pini0nated's Avatar
    Oct 2012
    Willow Grove, PA Turnpike, Exit 343
    Quote Originally Posted by Springman2007 View Post
    Springman
    It looks like it's a Tri-Glide-only conversion: http://www.lat-enterprisesinc.com/
    POWER ARM SUSPENSION - Independent Suspension Conversion Kit for Harley Tri-Glide Trikes
    2005 FXST Softail Std | 2015 FLRT Freewheeler | 2015 FLD103 Switchback
    *14-year Member, ABATE of PA- ABATE.ORG
    * MRF- MRF.ORG
  13. #12
    Quote Originally Posted by 0pini0nated View Post
    My guess is they haven't updated that page,yet. The Tri-Glide and Freewheeler both use the same rear suspension & frame.
  14. #13
    300+ Posts roadking2's Avatar
    Oct 2013
    North Lawrence, Ohio
    My opinion is that it would be cheaper to get a ultra and convert it using one of the many quality kits available. Throw another 6K on top of a triglide and now you have about 40K invested to get the same result as spending 30K for the converted ultra. That extra 6K you put into the tri to make it IRS you will never see again and I doubt there is any market for a used rear suspension from a tri. The conversion dollars you spend on the Ultra you will see most of it again and you can probably sell most of the ultras rear end. Fender, lights, bags, etc. Besides that, if you convert a Ultra, you can also put a mechanical reverse on it. You can do the same to the tri, but you already paid for the electric when you bought it. Those are some of the things I'd consider before changing out a Triglide but you may see it from a different point of view.
    If it fits a freewheeler, I'd get a RK and convert that. You lose the flared fenders, but you gain a removable windshield. See my pic
  15. #14
    Sep 2014
    Grafton, OH, USA
    Quote Originally Posted by roadking2 View Post
    Well I have a Freewheeler and not a RoadKing. And, I have a removable windscreen on the Freewheeler now....
    This is probably the last bike/trike I will be buying in my life; so, your overall cost argument is not really going to apply.
    What I would like to know is what I would be getting in overall ride-ability? Would I go out today and buy this package....no....but, I would consider it for later down the road.....
    Springman
  16. #15
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Springman
    You would be surprised at the difference in ride between IRS and straight axle, I know my wife and I was. My 2010 Triglide rode pretty decent, but my 2012 Hannigan Wing, its a Cadillac ride.
  17. DKCustoms postbit
  18. #16
    It's only money,guys. If it makes you happy,buy it.
    I've never seen a Brinks truck in a funeral procession.
  19. #17
    200+ Posts
    Apr 2014
    Pt Charlotte FL
    Good one!!!!!!
  20. #18
    Oct 2012
    Jasper,Ga.30143/USA
    Default getting soilded axe my need changing latter
    I have just put in a ofter for a 2012 trike glide.If all go,s well by Wednesday It will be home
    I had whanted one with ABS but the price looks to good to past up (keeping my payments so I afford it)
  21. #19
    Jul 2012
    Chubbuck Idaho
    Quote Originally Posted by rwwracing70 View Post
    None of the Harley Trikes have ABS. '14's & '15's have a unified brake system with the front & rear when you use the rear brakes over 25MPH. But that isn't ABS.
  22. #20
    900+ Posts HDB0B's Avatar
    Jul 2014
    S.E. PA, USA
    To be clear ... the Tri Glide rear brake is linked to the front all the time. Only the reflex linked brakes with ABS on the 2 wheelers are speed sensitive.
    Bob
  1. 2014 Tri Glide rear suspension
    By 12Wing Nut in forum Harley Tri Glide
    Last Post: 11-22-2014, 02:37 PM
  2. bad ride poor rear suspension on tri glide
    By mark mccallum in forum Harley Tri Glide
    Last Post: 09-10-2013, 09:29 AM
  3. HD Tri Glide suspension lift
    By Jeff-Kim in forum Harley Tri Glide
    Last Post: 03-19-2012, 08:14 AM
  4. Tri Glide Legend Suspension
    By trikermutha in forum Harley Tri Glide
    Last Post: 04-11-2011, 10:02 AM
