14TG3Jack KlarichHarley Tri GlideInstallation of a new Fuel Filter &...
14TG3TrampasHarley Tri GlideInstallation of a new Fuel Filter &...
14TG314TGHarley Tri GlideInstallation of a new Fuel Filter &...
Results 1 to 4 of 4
Thread: Squeak from front of trike
    200+ Posts
    Apr 2015
    pineville, la
    Default Squeak from front of trike
    I have a squeaking noise coming from the front of my trike. I have the springer front end that came on the roadhawk. It sounds like it is comming from the springer. I took a small paint brush and greased the two rods that that the springs are mounted on. I thought it might be the washers going up and down on the rods. After I greased the rods it quit for a short and now it's back. I don't see anything else that would squeak up front. Anyone else had this problem? Or how to diagnose a noise.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    First of all, with the trike parked, push up and down on the front end. Does it squeak then? If not then raise the front end and spin the tire to see if your getting the squeak.
    I have seen a lot of the springer type front ends that squeak when they bounce up and down.
    However, if after raising the front end and spinning the tire, you then hear the squeak it would indicate a bearing in the front rim.
    VW Tech Expert Loner's Avatar
    Aug 2010
    Harvest, AL USA
    I've found that noises from a springer often come from the top and bottom seats of the springs. It will be a bit of a challenge if you use grease, but try lubricating each spring seat, both top and bottom for each. A shortcut to lube those areas would be to spray a bit of lubricant/penetrant liberally on each seat area.
    Hope that helps.
    All my advice comes with a money back guarantee.
    200+ Posts
    Apr 2015
    pineville, la
    Default squeak from front of bike
    I'll try both of these suggestions. Maybe one will work. I haet a rattle or a squeak.
    Quote Originally Posted by Loner View Post
    Hope that helps.
  1. Kindra 130/70/18 on front of my Trike Shop trike
    By abohl in forum Tires, Wheels, Brakes, Front End
    Last Post: 05-04-2015, 06:56 PM
  2. Trike Low in the Front
    Last Post: 02-26-2014, 04:53 PM
  3. Aggrevating Squeak
    By SchubeCM in forum General Discussion
    Last Post: 10-13-2013, 06:11 PM
  4. Loud Creak/Squeak in rear.
    By Keystone in forum Harley Tri Glide
    Last Post: 09-07-2013, 06:37 PM
  5. Squeak in conversion kit
    By FRR in forum Honda Trikes
    Last Post: 08-30-2013, 06:59 AM
