ADSavarese11Jack KlarichNew Member Introduct...New member from FL
ADSavarese11woodyNew Member Introduct...New member from FL
LD-Ordie1LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese11hardwickbvNew Member Introduct...New member from FL
ADSavarese11ol' schoolNew Member Introduct...New member from FL
ADSavarese11GorillaNew Member Introduct...New member from FL
ADSavarese11Marc HNew Member Introduct...New member from FL
ADSavarese11ADSavareseNew Member Introduct...New member from FL
ADSavarese11Phu CatNew Member Introduct...New member from FL
ADSavarese11trike ladyNew Member Introduct...New member from FL
ADSavarese11Uncle FesterNew Member Introduct...New member from FL
ADSavarese11rhino 2New Member Introduct...New member from FL
Results 1 to 6 of 6
Thread: Steering Head Bearing Adjustment Hannigan
    300+ Posts Cougar's Avatar
    Mar 2009
    Near-Iowa City,Iowa
    Question Steering Head Bearing Adjustment Hannigan
    Any of you try and adjust the Steering Head Bearing nuts through them tiny little holes ? what's the trick ? got the top cap loose and tried to put the screw driver in the hole and I cant seem to turn the nuts in there, any tool or tip I need to know about ? Be good if they made that hole larger, mine is 6 years old so maybe they do now .
    Thanks for any help.
    Jeff
    350+ Posts
    Aug 2009
    Wayne, Mi USA
    Jeff pretty sure Hannigan made larger slots in the newer triple trees to get to those adjusters. I think there was a difference between my 09 and the 05 anyhow. I just used a long tapered punch when doing mine on the 05. I made a tool that fitted the nuts but to use it the top tree had to come off. A lot of work.
    Larry
    Oh wait the 05 had a different companies triple tree on it . Also remember that there's a metal locking tab between the top and bottom adjusting nuts. Just go slow when using the punch method. If taking the top apart to adjust the nuts and bearing use 25lbs torque to seat the bearings. Factory specs are way to loose for a trike set up
    Mar 2009
    Near-Iowa City,Iowa
    Question Head Bearing Adjusted
    Well, I was able to get in there with a punch and I was able to turn it about 3/4
    of a inch, got it all back together and it's still doing the same thing. shake at 70 mph.
    So I am now thinking its not the head bearing, and maybe a balance problem.
    I did have to drill the hole larger to be able to do this adjustment.
    150+ Posts
    West Bloomfield, Mi
    Give it a try from below the top tree, worked for me. Torque it to 28#
    Mar 2009
    Near-Iowa City,Iowa
    Question
    There is nothing under there to see or get to, you guys must have a diff tree on yours.
    Take a pic for me one day please.
    150+ Posts
    West Bloomfield, Mi
    Quote Originally Posted by Cougar View Post
    You are right Jeff, I was thinking of the stock top tree. I was able to get a punch in the ez steer tree hole and tap the locking ring. So far pics have not come out to well, I'll try again tomorrow.
  1. Replies: 31
    Last Post: 08-13-2015, 02:12 PM
  2. Poll - 2014-Up Steering Head Bearing - 25k Service
    By DK Custom Products in forum Harley Trike Conversions
    Last Post: 07-08-2015, 09:36 PM
  3. Steering Head Bearing Grease
    Last Post: 03-11-2015, 09:01 AM
  4. VTX head light adjustment
    By mtn rider in forum Honda Trikes
    Last Post: 12-02-2011, 11:04 PM
  5. v8 trike steering bearing
    By jasandbob 2 in forum General Discussion
    Last Post: 11-15-2010, 03:44 PM
