Likes Likes:  1
Results 1 to 6 of 6
Thread: 16x5.5 inch rear wheel converted to dual dics front wheel
    450+ Posts irmagoo's Avatar
    Dec 2012
    washington il.
    Default 16x5.5 inch rear wheel converted to dual dics front wheel
    ok I needed a wheel for a trike build and wanted a wide tire so this is how the wheel mods got started.
    1.shows wheel and hubcap I built at first,, was going to go with one rotor- I cut about 1/2 off the drive pulley side of wheel at this point to made it look a little cleaner as front wheel.
    2. when I decided to make it dual rotor I cut a additional 1/4 inch from pulley side of wheel and cut fingers back so that I could add my adaptor to wheel and both rotors would be aprox. same distance out-from wheel center.
    3. cut a bearing recess location into outboard side of adaptor also counter sunk 5 - 3/8 mounting bolt holes and tapped 5 rotor 5/16 bolt holes.
    4. installed adaptor and you can see the step in od of adaptor (where red layout goes to raw aluminum) where the hubcap will set.
    5.shows rotor fitment to adaptor
    ok this is what wheel looks like when done
    1. hubcap center opened to 3.900" to fit adaptor od step and 5-1/4 mounting holes counter-sank
    2. hubcap on wheel hub.
    3.right side rotor installed.
    4. just a look at how everything centered up..
    there are more details on this in my 3.8 super charged trike build in home built trike's here at trike talk,,, but know that a lot of you guys are just looking for wheel info hope this helps!
    magoo
    Dec 2012
    washington il.
    ok a couple pics. of wheel on the trike I'm building ... hope this may help someone wanting to build wide tire front end.
    1&2. shows the new rotor that I added- mounted to front end.
    3. shows the factory rotor.
    magoo
    1250+ Posts jaxbobg's Avatar
    Nov 2011
    Jacksonville Beach
    Pretty impressive but looks like a lot of work.
    Just how long did it take you to complete this mod?
    How's the ride now that you made this change?
    (Oh, one more thing ... I've looked at all your pictures pretty closely but still can't find the two dicks referenced in the title of this thread. )
    Quote Originally Posted by jaxbobg View Post
    Jaxbobg, They are a little hard to see but he took a rear wheel which would normally have just one brake rotor and the drive sprocket. He modified the sprocket side to attach a rotor. If you look rear close in the last picture you can see rotors one on each side. Quite the mod.
    Dec 2012
    washington il.
    I spent a few hours,,, it took about 3 hours to machine the adaptor and about 2 hours to machine side of wheel down remove material inside-drill and tap mounting hole's etc.
    I started this thread as I know many folks have talked about wide wheel and tire I could not find a front wheel wide enough for 7" tire so this was my way to get there-if you use single disc just machine side off like I did at first or a machinist could probably do this faster than I did but I got time- sorry if some of my spelln is off...
    magoo
    Jan 2013
    Fort Worth, TX USA
    Wow! Color me impressed! I'm using the same style HD wheel on the trike I'm building, only the standard front one which is a paltry 3 inches wide.
  1. I am almost convinced...rear tire on front wheel & TG is running great!
    By DK Custom Products in forum Harley Tri Glide
    Last Post: 12-19-2023, 08:05 AM
  2. Front Wheel--Rear Wheel
    Last Post: 08-06-2015, 12:45 PM
  3. Replies: 5
    Last Post: 12-08-2014, 01:03 AM
  4. Looking for comparison of two front vs two rear wheel trikes
    By Big_Blue in forum General Discussion
    Last Post: 07-21-2013, 03:01 PM
