Likes Likes:  8
Results 1 to 8 of 8
Thread: dragging pipes and hitch on Hannigan 2012
    20+ Posts Judge1962's Avatar
    Jul 2015
    Murray,KY,USA
    Default dragging pipes and hitch on Hannigan 2012
    We have a 2012 w/Hannigan conversion. We love the ride but have one issue with it. We drag the end of the pipes and hitch when going in and out of drives and over speed bumps. Has anyone else had this issue? If so, is there a easy fix with out loosing the ride?
    250+ Posts Hannigan Motorsports's Avatar
    Jan 2012
    Murray, KY
    Thanks much for this Post.
    As with any Unit like our Trikes (or any other Manufacturer of Trikes) that has a 77" Wheelbase and low Rear Ground Clearance. "scraping" is an unfortunate yet common Issue. It is difficult if not impossible to effect a true Solution without conversely creating another which may be even more displeasing.
    The best Method to address the Issue is of a Preventative nature. Easiest & Simplest Way is to decrease the possibility of dragging/scraping occurring by altering One's Angle of Approach to the Terrain or "Obstacle". Try hitting the Curb, Speed-bump, steep Driveway, etc. at an approx. 30* Angle depending upon the Obstacle itself. Doing such will usually avoid scraping/dragging all together or vastly reduce it from happening.
    Hope that helps and will prevent or reduce the scraping problem you are experiencing.
    All the best to you and we do thank you for your Post and your ownership of a Hannigan Trike
    Murray, KY
    270-753-4256
    hannigan@apex.net
    www.hannigantrikes.com
    Jul 2015
    Murray,KY,USA
    Default Thank you for the reply. I forgot to say this is a 2012 Goldwing w/Hannigan Trike
    Quote Originally Posted by Hannigan Motorsports View Post
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Quote Originally Posted by Judge1962 View Post
    Thank you
    Maybe I've been lucky, I haven't drug anything on my 2012 Hannigan wing. But then I was schooled early on when I had a Triglide, out of the box that sucker drug its tail often. I had to put a lift kit on the Triglide to make it stop. I learned as Hannigan put it, alter my approach when I thought I might drag something.
    Jul 2015
    Murray,KY,USA
    Quote Originally Posted by msocko3 View Post
    100+ Posts
    Dec 2013
    Omaha
    When I approach something that I think will cause me to drag, I raise up off my seat. - Funny that this doesn't seem to help much.
    Jan 2012
    Murray, KY
    Quote Originally Posted by Craigatcsi View Post
    Murray, KY
    270-753-4256
    hannigan@apex.net
    Now that's funny ... probably because I do the same thing with the same result.
    Definition of insanity: Performing the same task over and over again expecting a different outcome.
  1. Custom Tow Bar for Hannigan Hitch
    By 3rdwheel in forum Hannigan Trike
    Last Post: 11-26-2015, 11:55 AM
  2. Hannigan trailer hitch
    By alwrmcusn in forum Yamaha Trikes
    Last Post: 04-02-2013, 07:04 AM
  3. Trailer hitch for a 2012 Tri Glide?
    By Triken in forum Harley Tri Glide
    Last Post: 04-24-2012, 09:34 PM
  4. 2012 TriGlide Hitch
    By Cybyrd1 in forum Harley Tri Glide
    Last Post: 09-15-2011, 05:59 AM
