Results 1 to 14 of 14
Thread: Front Wheel Fender Clearance
    30+ Posts
    Jul 2015
    Fairfield, CA
    Default Front Wheel Fender Clearance
    My wife and I have "his and Hers" Stallions. There is a difference of one inch in clearance from the floor of the garage to the tip of the front fender. One is at 19 1/2 inches and the other at 18 1/2 inches. The 18 1/2 inch clearance is causing some fender rub on the front tire in tight turns. Anyone know what the clearance is supposed to be.....and/or how to adjust the front wheel clearance?
    1000+ Posts tomg's Avatar
    Oct 2009
    Titusville, Florida
    Mine is 20 inches
    Tomg
    30+ Posts
    Jul 2015
    Fairfield, CA
    Default Thanks
    Quote Originally Posted by tomg View Post
    Mine is 20 inches
    Tomg
    Do you know the procedure for adjusting this clearance?
    Oct 2009
    Titusville, Florida
    No but you might want to check the measurements at the triple tree and the top of the down tubes to see if they are the same. You may just need to loosen the brackets and allow the tubes to come down some?? Or you could call TMS and ask them.
    Tomg
    TOI - South Dakota pmar6004's Avatar
    Mar 2010
    Watertown, SD, USA
    Quote Originally Posted by Tigercat View Post
    You might also check the shock settings on both your Stallions. It could be that their settings are not the same. Settings are changed with the spanner wrench that came with your Stallions when they were new. Prior to changing the settings, raise the front end with a jack to take the weight off the front end. Good Luck..!
    Daydreamer
    "Life is not measured by the number of breaths we take,
    but rather by the number of things that take our breath away."
    2020 Vanderhall Carmel GT #014
    marquardt6004@gmail.com
    Paul Marquardt
    30+ Posts
    Jul 2015
    Fairfield, CA
    Quote Originally Posted by pmar6004 View Post
    Daydreamer
    Unfortunately, I did not receive the spanner wrench as I bought my Stallion from a private individual. Is this the type of wrench that can be purchased at a home depot or should I go to MotorTrike? Also, I noticed when I have both Stallions side by side with the hoods open, the one with the clearance issue has the headlight assembly resting on the front tire. On the second Stallion, there is about an inch clearance. I am not sure how to adjust the hood clearance. I changed the position of the rubber stops but it did not make any difference in the clearance.
    Thanks for the advice.
    3000+ Posts Ed Hobgood's Avatar
    Jan 2011
    Dexter, MO, USA
    You can get a spanner wrench at most automotive stores. My Stallion is an 08 and the hood rest on the tire ever since I've had it. You said you had fender rub on the tire but where does it rub?
    30+ Posts
    Jul 2015
    Fairfield, CA
    Quote Originally Posted by Ed Hobgood View Post
    Hi Ed,
    Hope all is Well in Missouri. I get a tire rub on the front fender when in a full steering wheel turn, depending on the grade of the road which appears to make a difference. I plan on picking up a spanner wrench tomorrow.
    Oct 2009
    Titusville, Florida
    spanner wrench does not come with the trike as some have mentioned!! the shocks should be set at one notch from the full setting. And DO NOT mess with the rear shocks!!
    Tomg
    350+ Posts Doc7402's Avatar
    Mar 2013
    Thonotoassa ,Fla ,USA
    i'll have to go out and check mine also , I know there was talk about it in the past , and also how to adjust the shocks in the front ( AFTER JACKING UP THE FRONT WHEEL * * * First )
    30+ Posts
    Jul 2015
    Fairfield, CA
    Tomg
    I got a spanner wrench from a local motorcycle shop, (Free), and extended the strut to full extension. It is not change the ground clearance whatsoever..... You appear to know what you are talking about....what would you suggest I do next? The Stallion is a 2013 with about 4000 miles.
    I think you may have to look at your issue from the other angle. If adjusting the shocks did not help then I can say that there is no real adjustment to the forks. You could try to move the legs down in the triple trees but that is not how they are designed. I think I would look for ways to eliminate the rubbing by adjusting the parts that are being contacted. Maybe a little trimming will solve your issue.
    Jan 2011
    Dexter, MO, USA
    I know this sounds crazy but has the front tire been replace with a different size tire? I know you said is is a 2013 with low miles but just wanted to make sure they were the same size tires.
    Oct 2009
    Titusville, Florida
    I would say to take a couple of photos showing the height of the front edge of the fender height, the triple tree showing the top section and if possible the tire contact with the light. Then forward them to TMS and ask for their help.
    Tomg
  1. No front fender is it legal in Ca.?
    By V8Rida in forum General Discussion
    Last Post: 04-14-2022, 01:58 PM
  2. 16x5.5 inch rear wheel converted to dual dics front wheel
    By irmagoo in forum Tires, Wheels, Brakes, Front End
    Last Post: 01-15-2022, 08:29 PM
  3. Front wheel and fender from freewheeler
    By kubotajim in forum Harley Trike Conversions
    Last Post: 09-30-2015, 08:40 PM
  4. Front Wheel--Rear Wheel
    Last Post: 08-06-2015, 12:45 PM
  5. Front Fender Flap
    By hARLEY jOE in forum Harley Trike Conversions
    Last Post: 10-18-2014, 12:26 PM
