Page 2 of 2 FirstFirst 1 2
Results 21 to 38 of 38
Thread: MotorTrike air ride suspension
  1. #21
    100+ Posts mcdonaldroadcapt's Avatar
    Oct 2010
    Canton, Georgia
    Default Re: MotorTrike air ride suspension
    Back to ya! Probably seen you a few times since we are so close.
  2. #22
    Rider
    Jan 2009
    United States
    Quote Originally Posted by mcdonaldroadcapt View Post
    What happens if you run with no air? Are shock springs the only suspension left if air bags are not used?
    Hey Jim. Long time, no see. Hope you guys are doing well.
    The air bags are just ride suspension which assists the adjustable coil-over shocks. Riding two up and hit a bump could bottom out your trike but I don't think there is a danger if your air is gone. There will be a cornering difference though.
    When R&R did your conversion did they install the factory air pump? I'm sure they did and it's unlikely the bags are leaking. More than likely it is a leak at a connection point somewhere.
    If you want, bring it over here and we'll put it up on the lift and check where the leak is.
    Good afternoon Kraut. Hope you are well and didn't get that cold that has been going around.
  3. #23
    100+ Posts Krautster's Avatar
    Jul 2013
    Holly Springs, Ga.. USA
    Howdy Dave, im doing good and stayed away from people, havnt got the bug, lol
  4. #24
    Oct 2010
    Canton, Georgia
    Hello Wiz,
    Yes I have on board compressor, Tried pumping up to 90 lbs yesterday for a few hours and then lowered to 30lbs and it has held overnight. Perhaps the extra pressure theory actually works?
  5. #25
    Rider
    Jan 2009
    United States
    It's true what they say... the air hose connections can get lazy. By bringing up the pressure they will seal themselves. This worked on my MT conversion but not completely. I would lose about 10 lbs a week.
    I did find a small leak on the air pump and on the left side bag connection. After repairing that it still leaked down.
    Inherent to Motor Trike air ride systems? Maybe. Mine leaked from day one until I sold it and went TG.
  6. #26
    Oct 2010
    Canton, Georgia
    Pardon my ignorance, but what is TG?
  7. #27
    Rider
    Jan 2009
    United States
    Harley Tri Glide
  8. #28
    Oct 2010
    Canton, Georgia
    Now I get it. For a moment I was thinking of Tourglide. Thought of doing the same thing but have too much money tied up in Screaming Eagle Ultra plus triking kit. Will have to ride it out but still love it.
  9. #29
    Rider
    Jan 2009
    United States
    Don't blame you one bit. Yours is the most beautiful conversion Harley I've ever seen.
  10. #30
    Oct 2010
    Canton, Georgia
    Thanks, we enjoy the ride.
  11. #31
    100+ Posts msrvpeig's Avatar
    Feb 2008
    Home of the Buckeyes
    I had the bags replaced by the installer on my first trike, a '93 1500 Motor Trike back in '05. It cost around $325 back then.
  12. #32
    Oct 2010
    Canton, Georgia
    Did it solve your leakage problem?
  13. #33
    Oct 2010
    Canton, Georgia
    Wiz, I sent you a PM>
  14. #34
    500+ Posts
    Feb 2008
    Planet Earth, Alpha Quadrant
    Is it the check valve in the air pump itself?
  15. #35
    Aug 2014
    Toronto Canada
    I have had a little bit of experience with air equipped vehicles. As for going with copper lines to your air shocks, I would not connect the copper line directly to the air shock but use a piece of soft line between the copper and shock. Again that defeats the use of copper lines directly to seal for any leaks. If you have a trike that has a lot of vibrations the copper line will eventually break leaving you in a serious stranded position. It will also kink leaving no air going to your shocks should they lose pressure or will make one shock not inflate or not properly inflate to desired position.
    You can buy those air shocks from Air Ride Corporation who Manufacture those shocks. Google the company name and have a look around their site and you will get a phone number and can call them and pick their brains about the bags.
    Also Goodyear Air products also have I believe those bags. Again Google and call them and see what they have. I hope this helps out.
  16. #36
    May 2013
    Vero beach,fl
    Mine leaks as well,replaced the bags and shocks still leaks!
  17. #37
    Sep 2009
    Near Myrtle Beach SC
    Resurrecting this thread again......
    Seems my MT air suspension after taking the setup apart this winter to do 60k maintenance and a few upgrades I had the bad air leak after re-assembly. After replacing all the air lines and most of the fittings, including adding a second one way check valve, a new air gauge I found I had one of the MT air bags leaking at the top of the bag above the clamp seal
    I replaced both air bags with Firestone air bags ( http://www.truckshop.com/product.php?productid=22175) ( http://i993.photobucket.com/albums/a...psvg5bo4ok.jpg ) re-check the entire system for any leaks using soapy spray on all joints finding no bubbles. I still have a slow air leak in the system. I have tried the 90 lb pump up and still it leaks very slowly.
    I am convinced that the air leaks through the air gauge. New or older, its a hit or miss
  18. #38
    Aug 2014
    Toronto Canada
    I believe your air leak is through your air compressor if all lines are tight. Put a one way valve just between the air compressor and to your air shocks. This valve allows air to go to air shocks/tank but does not allow air to come back into the compressor. I had to install one on my air compressor for another project and it cured the problem.
  1. rear air ride suspension
    By moonpilt in forum Harley Trike Conversions
    Last Post: 03-31-2016, 04:07 PM
  2. bad ride poor rear suspension on tri glide
    By mark mccallum in forum Harley Tri Glide
    Last Post: 09-10-2013, 09:29 AM
  3. TriGlide Suspension Upgrade By Progressive Suspension
    By JohnC in forum Harley Tri Glide
    Last Post: 02-22-2012, 05:22 PM
  4. Which is best the Champion Independent Suspension or Solid Suspension.
    By glawrence7 in forum New Member Introductions
    Last Post: 11-24-2010, 12:00 AM
  5. Motortrike introduces NEW IRS trike suspension
    By cjmitch in forum General Discussion
    Last Post: 09-27-2009, 11:18 PM
