Gernerwa10Jack KlarichNew Member Introduct...New Member from Bellingham, WA
Gernerwa10trike ladyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GorillaNew Member Introduct...New Member from Bellingham, WA
Gernerwa10rhino 2New Member Introduct...New Member from Bellingham, WA
Gernerwa10Marc HNew Member Introduct...New Member from Bellingham, WA
Gernerwa10Uncle FesterNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ZammyNew Member Introduct...New Member from Bellingham, WA
Gernerwa10hardwickbvNew Member Introduct...New Member from Bellingham, WA
Gernerwa10ol' schoolNew Member Introduct...New Member from Bellingham, WA
Gernerwa10GernerwaNew Member Introduct...New Member from Bellingham, WA
Speed Bleeders
Likes Likes:  5
Results 1 to 11 of 11
Thread: Towing VW Trike
    100+ Posts sonny8l3's Avatar
    Oct 2014
    Livingston (Colyell ), Louisiana, USA
    Default Towing VW Trike
    I have seen pictures of some thing that looks like a front wheel chock and sling combination for towing trikes.The front wheel goes in the sling and the whole thing goes into a receiver hitch. I'm wondering where to buy one and what has to be done to the VW to keep from damaging the motor and/or tranny. Any other info will be appreciated.
    Thanks for your time
    Dec 2014
    Grand Junction, Co. USA
    My concern would be lubrication ... If the VW is one of those vehicles that can be towed, I'm guessing it would be okay.
    Meme Master
    Jan 2014
    Farmington, NH USA
    www.etrailer.com Has a few receiver type towing rigs.
    If the above doesn't work, Google: Oldenkamp Hitch Cargo Carrier - RHMC1SV
    The upper weight limit on the receiver hitch type tow rig is around 800#.
    Not sure your trike weight, but most VW trikes are >800#
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Remember this. All the stresses of towing, pulling, stopping the trike will be put through the forks. A lot of forces and in directions not intended.
    The tow hitch needs to be hinged to help twisting stress on the fork.
    For an emergency or short distances being very careful I would be ok with it.
    The std shift gearbox is a sump splash oiler, no problem with towing. But remember every mine you tow it is the same wear to the gearbox as if it was driven.
    *I would use trailer.
    20+ Posts
    Jul 2015
    Janesville, CA, USA
    Default Tow Thingy
    I saw this on Trikerdon's website. Its called a tow thingy but it's for short emergency hops http://trikerdon.50megs.com/towthingy.htm
    You remove your wheel and put your axle through with spacers to keep it from moving side to side. If you have an auto or an autostick, make sure to disconnect the cv joints so the tranny doesn't burn up.
  6. #6
    850+ Posts vwbug72501's Avatar
    Apr 2015
    Batesville, AR. 72501
    Default Towing VW trike
    Possum Pride Trikes has a picture of a tow bar that they used to make that would solve the front end stresses because it pulled from the frame. Might call them and see why it is no longer available. Looks like it attached to a bracket on the frame and cradled the front wheel. Might be tough to lift it onto the hitch once it's attached to the trike.
    http://possumpridetrikebodies.com/frames.html
  7. #7
    Dec 2014
    Quote Originally Posted by vwbug72501 View Post
    Pretty kewl web site ... got my wheels turning.
  8. #8
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Sure makes me wonder why they quit offering that tow bar? I have to wonder if it had something to do with safety.
  9. #9
    Apr 2015
    Might be. Might be CYA in today's world if they don't install the frame mounts. I'll bet it would be a bit of a strain to lift the coupler onto the ball once installed.
  10. #10
    Meme Master
    Jan 2014
    Farmington, NH USA
    It's hard to imagine how hooking up to trike & attaching it to tow vehicle is accomplished, by just the one pic in their website.
    It would be good to know why it is gone. Was it safety?, was it physically too much to attach once loaded, for one person? or???
    Perhaps a past customer of P/P/T/B who owns one, will see this discussion & offer some clarity...
  11. #11
    200+ Posts ea81slush's Avatar
    Nov 2011
    Strathbogie Victoria Australa
    These hitches are common in Oz. Made to bolt onto a large lug under the fuel tank directly below the riders butt area it is a "U" shaped section so the front tire can sit in. Most VW trikes in Oz are wired so you just connect a wiring loom lead into a socket then attach it to your tow cars wiring for all rear lights.
    It works ok however I've heard that the trike bounces around a lot on its rear wheels and it prone to paint damage. If your trike has an auto transmission then the driveshafts should be disconnected 6 hex bolts each side.
    Best to use a trailer.
    http://www.youtube.com/watch?v=HXwh4z8d66o
    Subaru ea81 SPFI manifold, 32/36 carb, VW auto
    Trike talk trike of the month Jan 2012
    N3W (Aust) most outstanding trike 2012
    UKtriker trike of the month June 2012
  1. Help With Towing New Trike
    By Birdman-68 in forum General Discussion
    Last Post: 11-04-2013, 12:28 PM
  2. Towing with a VW trike
    By ea81slush in forum VW Powered Trikes
    Last Post: 01-10-2012, 11:03 PM
  3. Towing a trike
    By MDDOUG in forum General Discussion
    Last Post: 08-06-2011, 09:21 AM
  4. Trike Towing
    By White Wall in forum Trailers / Campers
    Last Post: 03-06-2010, 11:58 PM
  5. Towing a Harley Trike
    By trikerman in forum Trailers / Campers
    Last Post: 11-05-2009, 05:01 PM
