Thanks Thanks:  2
Results 1 to 11 of 11
Thread: Lehman Monarch II Brake pads.
    Mar 2015
    Pittsburgh, Pa
    Default Lehman Monarch II Brake pads.
    Hi All, I'm going to replace the rear brake pads on my newly acquired 2009 Honda GoldWing 1800 with the Monarch 2 Trike kit. The bike has aprox. 12000 miles on it and the pads are gone. Just wondering if anyone has done this and if there are any Tricks in doing the pads. Any info would be helpful. Thanks.
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Quote Originally Posted by Tagg View Post
    Remove the wheel, the caliper is in 2 parts, the outside and inside halves held together by 2 5/16" bolts. Use a 1/2" wrench to separate the outer half, remove it and the outer pad, remove the rotor, remove the inner pad. Install the new pads in reverse order and making sure the pad material is facing the rotor. Install the outer half and slowly tighten the bolts. Check brake fluid to make sure the reservoir is not over filled. Repeat operation on the other side.
    Jim Murphy
    Iron Butt Rider 2001
    Mar 2015
    Pittsburgh, Pa
    Ok got the disc pads off and found out that Lehman shipped the wrong pads. Is there a cross reference number for the Wilwood # 150-7192K or EBC # FA314R that can be referenced thru an auto parts supplier ??? Got it tore down and just sitting right now. Any HELP would be appreciated. Thanks.
    Martinsburg, WV
    The EBC 314R are readily available at most motorcycle shops for around $34-35 a set. You need 2 sets.
    Jim Murphy
    1250+ Posts cavie's Avatar
    Jan 2013
    Port Charlotte fl/Hinsdale MA
    FA 314r $23.00 and free shipping amazon.
    Rider
    Sep 2016
    Colombia
    Looking for a good quality set of pads and rotors for a b6 Passat Ive seen different brands and prices so Id like to hear some opinions. Is my daily but I wouldnt mind to upgrade to something different like cross drilled / slotted or just a decent set up that wont brake the bank thanks in advance Sent from my iPad using Tapatalk
    Welcome aboard someone should be along that knows your needs. Ride safe
    Martinsburg, WV
    Quote Originally Posted by PatrickMek View Post
    Try this site. The better the brakes, the more they cost.....
    http://ebcbrakes.com/automotive-products/
    Jim Murphy
    20+ Posts
    Jan 2018
    West Portsmouth, Ohio, Scioto
    Can anyone help me find brake pads for a 2006 GOLDWING LEHMAN MONARCH II trike?
    Martinsburg, WV
    I have disc brake pads, park brake shoes, brake rotors and brake calipers.
    http://mjtrikes.com/shop/index.php?m...index&cPath=89
    Jim Murphy
    20+ Posts
    Jan 2018
    Default Brake pads
    Quote Originally Posted by Keith G View Post
    THANK YOU for the help
  1. Residual brake valve on Lehman Monarch 1
    By DeerWrangler in forum Honda Trikes
    Last Post: 09-01-2023, 09:55 AM
  2. 2003 Lehman Monarch II
    By CyberVet65 in forum Lehman Trike
    Last Post: 12-05-2015, 06:20 PM
  3. 2003 Lehman Monarch II
    Last Post: 10-15-2015, 08:54 AM
  4. Lehman brake pads and rotors
    By gwetts in forum Lehman Trike
    Last Post: 01-18-2015, 07:21 PM
  5. Germany need your help, Lehman Monarch
    By ramon in forum Lehman Trike
    Last Post: 11-24-2012, 07:47 PM
