rhino 212rhino 2General DiscussionRainey day thought's ¶¶¶
ZZMACH11ZZMACH1Harley Tri GlideSTOCK HARLEY ECM MAP with DynoJet
ctdair9ROAD DOGHarley Tri GlideHot Rotors After New Pads
rhino 2121dn5upGeneral DiscussionRainey day thought's ¶¶¶
ZZMACH14ZZMACH1Harley Tri GlideElectric Fans on 2014 Tri Glide
Davep10SullyNew Member Introduct...Hello from the mountains
rhino 212Phu CatGeneral DiscussionRainey day thought's ¶¶¶
ctdair9ctdairHarley Tri GlideHot Rotors After New Pads
ZZMACH14ol' schoolHarley Tri GlideElectric Fans on 2014 Tri Glide
hardwickbv3KoolbreezeHarley Tri GlideGot a Code P0152 Engine Running Ric...
Davep10DavepNew Member Introduct...Hello from the mountains
Davep10woodyNew Member Introduct...Hello from the mountains
dthorn6Jack KlarichHarley Tri Glide2024 Tri Glide front axle nut torqu...
rhino 212Jack KlarichGeneral DiscussionRainey day thought's ¶¶¶
ctdair9Jack KlarichHarley Tri GlideHot Rotors After New Pads
Davep10Jack KlarichNew Member Introduct...Hello from the mountains
Davep10ol' schoolNew Member Introduct...Hello from the mountains
Tritek1TritekLehman TrikeAvoid buying a Lehman?
ZZMACH14Rmitchell55Harley Tri GlideElectric Fans on 2014 Tri Glide
Davep10trike ladyNew Member Introduct...Hello from the mountains
Bonsai11Marc HNew Member Introduct...New member from Texas
Davep10Marc HNew Member Introduct...Hello from the mountains
Bonsai11ZammyNew Member Introduct...New member from Texas
Davep10ZammyNew Member Introduct...Hello from the mountains
chucktrue555ZammyHarley Freewheeler /...Rear shock adjustment
Bonsai11Uncle FesterNew Member Introduct...New member from Texas
Davep10Uncle FesterNew Member Introduct...Hello from the mountains
ZZMACH14rhino 2Harley Tri GlideElectric Fans on 2014 Tri Glide
dthorn6dthornHarley Tri Glide2024 Tri Glide front axle nut torqu...
ctdair9MykneesbehurtinHarley Tri GlideHot Rotors After New Pads
chucktrue555rhino 2Harley Freewheeler /...Rear shock adjustment
chucktrue555JTJerseyHarley Freewheeler /...Rear shock adjustment
chucktrue555ROAD DOGHarley Freewheeler /...Rear shock adjustment
ctdair914TGHarley Tri GlideHot Rotors After New Pads
Sunman7pwhoeverHonda TrikesF1 Warning Light
Davep6DavepHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
Sunman7GoldWingrGregHonda TrikesF1 Warning Light
chucktrue555chucktrue55Harley Freewheeler /...Rear shock adjustment
Davep10rhino 2New Member Introduct...Hello from the mountains
Bonsai11Papa ZookNew Member Introduct...New member from Texas
Bonsai11SullyNew Member Introduct...New member from Texas
Bonsai11BonsaiNew Member Introduct...New member from Texas
hardwickbv3Jack KlarichHarley Tri GlideGot a Code P0152 Engine Running Ric...
DrCrazyTrain5Jack KlarichHarley Freewheeler /...True Dual Header
Bonsai11Jack KlarichNew Member Introduct...New member from Texas
gfaltersack8Jack KlarichHarley Tri GlideDK Customs remote oil filter kit in...
kj5ix32ADSavareseHonda TrikesMotor Trike Service Manual Finished
gfaltersack8Old Road DogHarley Tri GlideDK Customs remote oil filter kit in...
Davep6Old Road DogHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
ctdair9Old Road DogHarley Tri GlideHot Rotors After New Pads
Bonsai11ol' schoolNew Member Introduct...New member from Texas
Sunman7rhino 2Honda TrikesF1 Warning Light
Papa Zook1Papa ZookHarley Tri Glide2024 Harley Trikes Lineup - Laidlaw...
Bonsai11rhino 2New Member Introduct...New member from Texas
Bonsai11GorillaNew Member Introduct...New member from Texas
Rawhideken1714TGHarley Tri Glide2024 Tri glide
kj5ix32trike ladyHonda TrikesMotor Trike Service Manual Finished
Bonsai11trike ladyNew Member Introduct...New member from Texas
Sunman7BowdenTrikeHonda TrikesF1 Warning Light
LD-Ordie10Marc HNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13ZammyNew Member Introduct...New member from FL
DrCrazyTrain5rhino 2Harley Freewheeler /...True Dual Header
LD-Ordie10ZammyNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10Uncle FesterNew Member Introduct...Newbie from the Mojave Desert
DrCrazyTrain5Ron BaxterHarley Freewheeler /...True Dual Header
Burnerboy10rhino 2Can Am Spyder Trike...How many of you ride a Can Am spyde...
DK Custom Products362PosseRiderHarley Tri GlideWhat did you do to Your Tri-Glide T...
Davep6rhino 2Harley Tri GlideTRI GLIDE AIR FILTER QUESTION
Sunman8PuckoachHarley Freewheeler /...Value of 2015 Freewheeler
dthorn6rhino 2Harley Tri Glide2024 Tri Glide front axle nut torqu...
gfaltersack8rhino 2Harley Tri GlideDK Customs remote oil filter kit in...
gfaltersack8gfaltersackHarley Tri GlideDK Customs remote oil filter kit in...
hardwickbv3hardwickbvHarley Tri GlideGot a Code P0152 Engine Running Ric...
dthorn6Papa ZookHarley Tri Glide2024 Tri Glide front axle nut torqu...
SSpoon14cycle7447New Member Introduct...Hello from VA
Richard D12CorkeykHarley Trike Convers..."Himsl Praying Mantis" Sh...
gfaltersack8ISP-FLHarley Tri GlideDK Customs remote oil filter kit in...
LD-Ordie10ol' schoolNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17KoolbreezeHarley Tri Glide2024 Tri glide
LD-Ordie10trike ladyNew Member Introduct...Newbie from the Mojave Desert
Davep6KoolbreezeHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
LD-Ordie10GorillaNew Member Introduct...Newbie from the Mojave Desert
LD-Ordie10rhino 2New Member Introduct...Newbie from the Mojave Desert
LD-Ordie10SullyNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13SullyNew Member Introduct...New member from FL
Davep6Jack KlarichHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
LD-Ordie10Jack KlarichNew Member Introduct...Newbie from the Mojave Desert
Rawhideken17LD-OrdieHarley Tri Glide2024 Tri glide
ADSavarese13Jack KlarichNew Member Introduct...New member from FL
ADSavarese13woodyNew Member Introduct...New member from FL
LD-Ordie10LD-OrdieNew Member Introduct...Newbie from the Mojave Desert
ADSavarese13hardwickbvNew Member Introduct...New member from FL
SSpoon14hardwickbvNew Member Introduct...Hello from VA
ADSavarese13ol' schoolNew Member Introduct...New member from FL
Davep6New Orleans KevinHarley Tri GlideTRI GLIDE AIR FILTER QUESTION
gfaltersack8TFNCHarley Tri GlideDK Customs remote oil filter kit in...
ADSavarese13GorillaNew Member Introduct...New member from FL
ADSavarese13Marc HNew Member Introduct...New member from FL
ADSavarese13ADSavareseNew Member Introduct...New member from FL
ADSavarese13Phu CatNew Member Introduct...New member from FL
ADSavarese13trike ladyNew Member Introduct...New member from FL
ADSavarese13Uncle FesterNew Member Introduct...New member from FL
dthorn6nucsealHarley Tri Glide2024 Tri Glide front axle nut torqu...
dthorn6TrampasHarley Tri Glide2024 Tri Glide front axle nut torqu...
ADSavarese13rhino 2New Member Introduct...New member from FL
Likes Likes:  2
Results 1 to 3 of 3
Thread: Altitude issues.... Why?
    100+ Posts
    Dec 2013
    Omaha
    Question Altitude issues.... Why?
    We are on a trip thru Rapid City, SD the Coy, WY and Yellowstone, etc.... I have gone over the mountains in CO before and have had similar issues as today in the Mountains. When waaay up there my clutch doesn't want to disengage. It usually disengages very early, but when up there it is very near the bars before I feel any resistance in the handle, and it is difficult to shift. The same happened to my rear brake only, the front brake was not affected at all. At one point, I had NO rear brake until I pumped it a few times, then it was fine. My buddy was on his 08 HD and had no affects from the altitude.
    Please understand that I know it is caused by the altitude and differing pressures in the air, but....
    How does it / WHY does it do it to CLOSED hydrolic systems? (All of mine have been flushed / new within the last couple of years and are at the appropriate levels.)
    Why aren't my buddy's HD hydrolic systems being affected - like my front brake?
    150+ Posts
    West Bloomfield, Mi
    I can tell you from similar experience that your clutch &amp; brake fluids have excessive moisture in them and need to be changed. I had the same issue on a trip over Beartooth, flushing with new fluid solved the problem. &nbsp;Change the fluids every season, cheap, easy insurance.<br />
    <br />
    Quote Originally Posted by Craigatcsi View Post
    We are on a trip thru Rapid City, SD the Coy, WY and Yellowstone, etc.... I have gone over the mountains in CO before and have had similar issues as today in the Mountains. When waaay up there my clutch doesn&#39;t want to disengage. It usually disengages very early, but when up there it is very near the bars before I feel any resistance in the handle, and it is difficult to shift. The same happened to my rear brake only, the front brake was not affected at all. At one point, I had NO rear brake until I pumped it a few times, then it was fine. My buddy was on his 08 HD and had no affects from the altitude. Please understand that I know it is caused by the altitude and differing pressures in the air, but.... How does it / WHY does it do it to CLOSED hydrolic systems? (All of mine have been flushed / new within the last couple of years and are at the appropriate levels.) Why aren&#39;t my buddy&#39;s HD hydrolic systems being affected - like my front brake?
    Gone But Not Forgotten
    Lee H. Mann's Avatar
    Martinsburg, WV
    Decreased pressure on the outside increases pressure differential on the inside.
    Make sure your clutch reservoir is not over-full.
    Jim Murphy
    Iron Butt Rider 2001
  1. GPS Issues With 2014 Tri
    By The_Bob in forum Harley Tri Glide
    Last Post: 08-27-2015, 08:26 AM
  2. Radio Issues
    By Bonedaddy in forum Harley Tri Glide
    Last Post: 11-16-2014, 02:55 PM
  3. Any clutch issues?
    By motoadvrider in forum BMW Trikes
    Last Post: 02-24-2013, 07:19 AM
  4. High Altitude ECM chip
    By GoSlo in forum Harley Trike Conversions
    Last Post: 12-14-2012, 05:25 AM
  5. Warranty issues
    By tfdeputydawg in forum General Discussion
    Last Post: 02-04-2011, 05:06 PM
