Speed Bleeders
Too Pa Pa Zook
Too Pa Pa Zook
Likes Likes:  5
Page 2 of 2 FirstFirst 1 2
Results 21 to 35 of 35
Thread: Anyone else break the swingarm on their trike?
  1. #21
    60+ Posts
    Apr 2013
    Bedford, TX
    Quote Originally Posted by Lee H. Mann View Post
    That is caused by a twisting of the motorcycle frame. This seems to be a weak link in the IRS system. I would check the upper frame bracket and connections. Looks like a beef-up of the swingarm is in order.
    The shop now has the body off and is able to get a better look. The service manager thinks there was a bad weld. He said the weld didn't get hot enough to penetrate the metal. They're sending the unit back to Champion for their evaluation.
  2. #22
    Senior Moderator
    Gorilla's Avatar
    Oct 2008
    Key Largo. Fl,. USA
    we are all human errors happen. making it right is the human factor
  3. #23
    1250+ Posts Sloufoot's Avatar
    Jul 2012
    Chubbuck Idaho
    Quote Originally Posted by Dennis Murawski View Post
    I think the shop is fishing for answers there. But the picture isn't complete enough to see the other side of the tube. There shouldn't be a weld where the tube broke at.
    If you will look to the left of the break there is a weld. That is the proper way to weld a frame member. NEVER straight across.
    If you looked inside the tube, I bet you will find the inside tube ends just about right at the break. There is a mount just above the tube that would put stress on the area. the stress would cause the outside tube to flex at the first point after the double tube. This doubled area wouldn't allow any flex.
    If there is an intersecting tube on the inside that isn't visible from the photo, the joint should be designed to spread out the stress in the area & not compound it. It would need a gusset shaped like a diamond & shaped (bent) across the joint as to not be straight across either of the joining tubes.
    Been welding too many years to buy just a cold weld theory.
    2012 Tri-Glide, DK's Lift Brackets, 416 Progressive shocks, S&S Power Tune Duals Header, V&H Monster Rounds , HD Ventelator AC, FCS Fans, Tank raised 2", Dual Halogen Headlight, L.R.S 10" Tinted Windshield, Hammock Seat, Tourpak 1"raise & 2" back & Light conversion, PV w/Target Tune, Bagger Bar, Harley 2" pullback bars, Running AmsOil in all Boxes.
  4. #24
    Sponsor
    TrikeTalk Sponsor
    DK Custom Products's Avatar
    Jun 2013
    Red Banks, MS
    Yes, I did haul a Lees-ur-lite Excel motorcycle camper. The load was balanced (at least I thought so anyway) and the tongue weight, although I didn't weigh it, seemed to be within the specs. Hmmm, maybe next time I should get a scale. I had a tool kit in the trike box, but that was centered between the wheels. But still, one would hope the design would be a bit more robust than that.
    I found the easiest way to weigh the tongue weight is with a fish scale.
    www.DKCustom.com
  5. #25
    Rider
    Jun 2011
    tx
    What's the latest on your trike,Dennis?
    Congrats on the new Boss Hoss.
  6. DKCustoms postbit
  7. #26
    60+ Posts
    Apr 2013
    Bedford, TX
    Quote Originally Posted by Clint44 View Post
    I stopped by the shop yesterday. The broken assembly was shipped to Champion but as of yet, they have not heard back.
  8. #27
    Rider
    Jun 2011
    tx
    I read about your adventure with your Boss Hoss Deuce. Don't feel bad,I had a few incidents with ours early on but it seemed like once we got the bugs out of our 57,it was pretty reliable after that.
  9. #28
    5+ Posts
    Sep 2017
    Darby, Montana. USA
    Default Ultra Glide / Lehman Renagade conversion swing arm breakage
    So I found this thread on a "Bing search". Just had same issue with my 08 Harley Ultra with a 2015 Lehman/Champion Renegade LLS . Swing arm broke on both sides. Any idea how many of these have done this? conversion has 13000 mi on it ,was installed by Lehman/Champion dealer, has never pulled a trailer and rarely rode 2-up.
  10. #29
    800+ Posts FLTR2008TRIKE's Avatar
    Sep 2009
    Near Myrtle Beach SC
    Quote Originally Posted by fl68hog View Post
    If you look under the oil pan, the gusset or welded brace from the factory is bowed. That can have an affect on the handling and create stress on the swing arm assembly. Also the tubing and welded gussets on the swing arm not thick enough steel.
    Overcoming Adversity is the path to better ideas!!
    2008 Roadglide w/ MOTOR TRIKE Kit
    S&S 124" Headwork & Custom designed cams by John
    Custom made right side shifter (Lost my left leg above the knee due to a hit n run driver) SOOS's custom made floorboard spacer
  11. #30
    Gone But Not Forgotten
    Tech Contributor
    Lee H. Mann's Avatar
    Apr 2011
    Martinsburg, WV
    Looks like very poor (South of the Border) welding. Nearly missed the joint completely or the welder didn't intend on hitting the joint in the First Place.
    On the IRS (LLS Lehman) the swingarm acts as a dead-man. There is stress as the picture shows but I believe it is defective construction.
    Jim Murphy
    Iron Butt Rider 2001
  12. #31
    4250+ Posts pcombe's Avatar
    Feb 2013
    casper,wy. usa
    I have to agree.
    Question?
    Is this only on the IRS suspension models?
    I have seen no evidence of cracks on my champion straight axle.
    I have to wonder if the failures were a part of a certain serial number run, Date of manufacture etc?
    I bought my kit in the spring of 2013.
    Enjoy life now!----------IT HAS AN EXPERATION DATE
    1989 HARLEY DAVIDSON TOUR GLIDE ULTRA CHAMPION- A WOLF IN SHEEP'S CLOTHING-(CUT YOUR WOLF LOOSE!)
    the difference between a good trike and a bad one depends entirely on the integrity of it's builder!
  13. #32
    Tech Contributor
    Apr 2011
    Martinsburg, WV
    Quote Originally Posted by pcombe View Post
    I have to agree.
    Question?
    The only ones I have seen (2) are on the LLS models, not the straight axle models.
    Jim Murphy
  14. #33
    Feb 2013
    casper,wy. usa
    Thanks amigo
  15. #34
    10000+ Posts
    TrikeTalk Founder
    Papa Zook's Avatar
    Dec 2007
    Conroe, Texas
    2
    As far as I know, this was an IRS model issue only and was addressed by Champion a long time ago. I'm not sure of the exact time frame, but they totally changed the way the swing arm is reinforced. It is boxed on all sides now. I will post pictures shortly of one I am building now to show you all what the new part looks like.
  16. #35
    5+ Posts
    Sep 2017
    Darby, Montana. USA
    Default Swing arm up-graded
    Papa Zook You are correct on the new improved swingarms. The new replacement is also boxed on all 4 sides with what looks to be a little thicker metal ? The old style that cracked only had the 3 sided sleeve that appeared to be of a lighter gauge material? Welds also look better on the later style ? Time will tell and I'll add this "check swingarm" to other weekly checks (tire pressure, fluid levels, belt, ect.) Thanks for input!
  17. DKCustoms postbit
  1. Rear Axle Rigid Swingarm or 4 Link?
    By mutwagn in forum Home Built Trikes
    Last Post: 03-19-2013, 09:05 PM
  2. Parking Break on GL1800 Lehman Trike
    By Motogordo in forum Honda Trikes
    Last Post: 09-05-2012, 08:22 AM
  3. Softail Trike Swingarm
    By crzrlou in forum Harley Trike Conversions
    Last Post: 01-19-2012, 04:57 PM
  4. Chain adjuster on swingarm.
    By BIBS in forum General Discussion
    Last Post: 11-08-2010, 11:56 AM
