Hi Durango9, here is a PDF of the installation manual for a 2012 or newer Champion IRS (I'm not sure what year kit you have)
http://www.championsidecars.com/uplo..._indep_kit.pdf
If you look at page 7, I have to assume your Lehman conversion has already disabled the secondary master cylinder so that all you need to do is remove the line that joins the rear brakes to the lower connections on the front calipers.
Page 8 explains how to evacuate the fluid from the system....(note, you only have to evacuate the fluid from the 2 lower bleed valves on the front calipers back to the rear rear calipers and the rear master cylinder.)
The only steps that pertain to the system you need to evacuate are "a" "g"(hook up the vacuum bleeder to the right rear caliper) "h" "i" "j" and "k".
I don't think you need to evacuate the line going to the left rear caliper.
Once you have drained the fluid, you can modify the plumbing on page 9.
Step "a" should already be done. You would do step "b" and step "c".
If you look at step "e" on page 10, you may decide that you want to move this line over, but I doubt it is necessary!
Now all that's left to do is hook up the rear MC to the residual pressure valve and fill and bleed the system.
If you go to page 16 it shows you what to do with the brake line you disconnected from the rear MC. All you need to do is zip tie it to the other 2 lines that were disabled during the conversion.
Now go to the bottom of page 21, were it tells you to install a new 10" line and residual pressure valve.
It then tells you to run a 25" hose from the RPV to the tee at the differential.
If your Lehman conversion is like mine, there already is a RPV at the tee by the differential, so I'm thinking all you would need to do is run a line (approx. 36" long) from the rear MC to the RPV. (I believe the line would need a banjo fitting at each end)
That should complete your plumbing so that all you have to do is fill and bleed you lines from the rear MC to the rear calipers.
If you look at the "Note:" on the "Evacuation of the fluid" on page 8, it tells you to lock the pedal on the rear MC in the engaged position to eliminate the need to bench bleed the MC!!!!!!!
If you don't already have one, you would probably want to buy a vacuum bleeder.
BTW, I haven't done mine yet but I plan on doing it before Spring. Let me know how you make out. (You can PM me with questions)
Best regards, Marcel
