Results 1 to 7 of 7
Thread: 1500 with a Califorina sidecar
    50+ Posts
    Jul 2013
    Buffalo Lake Mn. USA
    Default 1500 with a Califorina sidecar
    I have a line on a 1997 wing with a California sidecar on it, and looking for any info. on it. Not sure on the model of the sidecar. They are both white. The wing has 81,000 miles but the car has under 200 on it They have not been used much for a couple of years ,but have been run during that time. .
    Meme Master
    Jan 2014
    Farmington, NH USA
    Without pics or more info on the sidecar, its tough to give any useful info.
    Older wings were known for needing timing belt replacement.
    Hopefully it was garaged, or covered from the elements while it was in storage.
    However if the price is right, it might be a good deal...
    7000+ Posts Lucky's Avatar
    Dec 2009
    LaFayette
    Good luck with your decision. Why only 200 miles on the side car? RIDE SAFE
    400+ Posts
    Sidecarbill's Avatar
    Feb 2015
    Sussex nj usa
    The older model csc didn't have a flip front. This makes them hard 2 get out of. Just a thought in case someone is going 2 ride in it.
    50+ Posts
    Jul 2013
    Its a newer car, the front flips up. The owner had just put the car on and got hurt and stopped riding. It was stored in a shed seams clean. I need to look at more closely.
    20+ Posts cruzerdog's Avatar
    Aug 2015
    Folsom
    had a california Side car and it was FANTASIC
    does it look like this
    John
    El Dorado Hills CA
    2015 HD Tri Glide / 1932 Ford 5 window "fenderless" Coupe Hot Rod
    /1950 Ford Club Coupe --302 injected V8- AOD Automatic
    Lone Dog ... No Woof
    600+ Posts keepinon's Avatar
    Dec 2011
    New Caney, Tx
    Sidecars are neat looking, but I've never owned one. However, I've owned several 1500 'Wings. My only concerns with the one you're looking at would be gunked up carbs, &/or rust in the fuel tank with your extremes in temperature up there causing condensation.
    If those two items are good, inspect the timing belts (not that hard) & change if they look cracked, or for peace of mind. Pull the rear wheel and check/lube the final drive splines with moly-60 grease, check the oil levels, and BOOGIE. Those 1500's are known for 200k miles with very few problems.
    Good luck on your find.
  1. HD Sidecar parts
    By onahog in forum Sidecar Forum
    Last Post: 02-27-2015, 07:12 PM
  2. Sidecar VS Trike ???
    By sandrooney in forum Harley Trike Conversions
    Last Post: 06-20-2013, 08:59 PM
  3. Strange Sidecar
    By Paul_Trike in forum General Discussion
    Last Post: 04-26-2012, 06:11 PM
  4. Welcome California Sidecar!
    By Papa Zook in forum California Sidecar Trikes
    Owners Forum
    Last Post: 12-08-2010, 12:35 PM
