Likes Likes:  1
Results 1 to 9 of 9
Thread: voyager trike issue...Drive wheel problem
    50+ Posts baba67's Avatar
    Sep 2015
    Falmouth, CapeCod,MA.
    Question voyager trike issue...Drive wheel problem
    Well I finally had a chance to install the voyager kit yesterday.
    And I took it out on a test run before leaving on a trip this coming week and we will be towing a trailer.
    I seem to have a real problem with the rear wheel looseing traction, And a trailer may really cause traction issues.
    Any gravel, stone, dips in the road. etc. seems to be a real problem.
    At times I had to push the bike to get enough traction to move.
    I assume it is a pre-load issue?
    I set the preload at 1/2 inch as suggested for Goldwing GL1500.
    The voyager suspension wheels do not move independently over uneven surfaces.
    In their videos. it actually shows a trike riding with one wheel over a curb.
    My kit does not have that flex in the rear wheels.
    How do I allow more independent movement and still allow the MC drive tire to stay in contact with the road surface?
    I really would appreciate and info you can suggest to resolve this issue.
    80+ Posts Condor's Avatar
    Sep 2014
    Carmichael, CA, USA
    Just a thought. When you adjusted the pre-load did you re-torque the flat bar under the rear cross member?? It just seems from what you're describing you have way too much pre-load. Are you sure you only have 1/2"?? It sort of a trade off. The more pre-load the less traction and visa versa....
    150+ Posts mirider's Avatar
    Jun 2015
    West Michigan
    Most problems I have heard about relate to incorrect pre-load and initial installation. I haven't experienced any of the problems you relate to and I have put close to 5K miles on my Voyager since I got it. Many of those miles were pulling a trailer and I didn't even know it was back there. Guess I am lucky to have my installation done by a local dealer who has done numerous set-ups over the years.....
    Dave
    14 HD Tri Glide
    H.O.G. Member
    20+ Posts
    Oct 2013
    Branford CT
    You have to much preload, reset with 1/4 preload plate and that should solve your problem.
    20+ Posts
    Oct 2013
    Branford CT
    Voyager has a video on how to set the preload, may help.
    http://www.mtcvoyager.com/resources/videos/
    Jun 2011
    CaLdwell, idaho, USA
    Default preload
    Youve got a bit to much preload. There is a fine line of too much and too little. Once ou got it right enjoy it.
    Aug 2015
    East Peoria
    Had mine installed at dealer. They set air pressure at 63 lbs and used 1/2" spacer under drive wheel. No traction problems. Mine is also a 1500. I have played with the pressures some, if you let to much out it rides like crap. If you go 2 up you might have to increase a little.
    Sep 2015
    Default My voyager experience so far.
    Well I have been riding on the voyager kit for about 800 miles, Two up, And I think I have most of my problems taken care of.
    First I had to set my preload, riding two up I have found that one and a half inches of preload works best for me....(section of 2x4 flat under rear wheel)
    Rear tire at factory rec. press.
    Voyager tires at 18 lbs.
    Gl1500 rear susp. set at 75.
    I am still dealing with my leaf springs coming into contact with my mufflers on hard bumps, And of course the arm/bushing rattles on uneven roads.
    But, overall I am beginning to enjoy the out rigger advantages,...Stable stops on uneven ground, etc.
    My next step will be installation of a darkside rear tire, and modification to the leaf springs and mufflers.
    For the investment, I think this will work out well.
    Note,
    I also found pulling a trailer makes the voyager even MORE stable and improves the overall ride quality.
    Aug 2015
    East Peoria
    Mine had some rattle from the rear fork and bushings, I bought some thin nylon washers from hardware store cut them to fit the bearing or bushing whatever you call it. Put one on each side of the fork, seemed to help the rattle. Other than that the bit of bouncing is the only thing that kind of bothers me, something you have to get use to.
  1. Voyager handling problem
    By sidecarwilly in forum Outrigger Style Trikes
    Last Post: 07-27-2014, 08:10 PM
  2. What rear tire will work best to drive my Voyager kit ?
    By krazybob in forum Outrigger Style Trikes
    Last Post: 02-23-2014, 02:44 PM
  3. another gravel in drive belt problem
    By eagle1 in forum Harley Trike Conversions
    Last Post: 05-11-2013, 05:02 PM
  4. Replies: 4
    Last Post: 09-22-2012, 08:09 AM
  5. Drive Belt Problem on Frankenstein conversion
    By icebite1 in forum Harley Trike Conversions
    Last Post: 09-02-2011, 02:15 PM
