Likes Likes:  2
Results 1 to 20 of 23
Thread: Reverse Not Working on 2015 Tri Glide
    Jul 2015
    Oklahoma City
    Default Reverse Not Working on 2015 Tri Glide
    Recently bought a new 2015 Tri Glide. A buddy of mine was putting it in reverse, tried backing up, then realized the emergency brake was on. Released the emergency brake, but now reverse does not work. It acts like it is engaging when you put it in reverse and push the reverse button, it makes the "locking" sound when you push the button, but nothing else happens. Almost as if it is trying to engage but not engaging all the way or something. We rode it, shifted it, brought it back and re-tried it, but no luck. Anyone ever experienced this? Obviously it is under warranty, just curious if it is something you have experienced?
    Also, I have a 2010 TriGlide for sale, does this forum allow sales ads?
    30+ Posts briar's Avatar
    May 2014
    Olathe, CO USA
    Quote Originally Posted by sdavidson View Post
    Behind the right side cover is a circuit breaker with a little red button on top. This will pop when you do what got done. Push the button down and try again.
    =bob=
    40+ Posts hedgie57's Avatar
    Jan 2014
    Ohio
    Lotsa info like this in the owners manuel
    Jun 2010
    Coram, NY USA
    What they said....
    ...And go to Forum/Classifieds to start a thread listing a For Sale item.
    Jul 2015
    Oklahoma City
    Default x
    Quote Originally Posted by briar View Post
    =bob=
    Thanks Bob, I tried the reset, for some reason it doesn't want to stay engaged. I tried to depress it running, off, several different ways etc; no luck. I can tell it "clicks" when you depress the R button, but is not engaging. Is there a fuse to this somewhere that may need replacing?
    250+ Posts BOXX3R's Avatar
    Jul 2015
    Huntington Beach, Ca
    sdavidson......
    I had the exact same thing happen to me when I first got my TG. After reading the manual twice I figured out that there is a little black lever that pops out when you do something wrong, like try to put it in R while the parking brake is on. You have to push that lever back in to reset, and then follow the recommended backing up sequence.
    Make sure Trike is in NEUTRAL
    Start Trike
    While foot or hand is on a brake, release the parking brake.
    With foot or hand still on brake push the R button until the R appears in the right gauge, take your finger off the R button.
    Make sure you have a clear path behind you and release your foot or hand off the brakes and re-push the R button to start backing up..
    "HOW we ride today, may determine IF we can ride tomorrow"
    Jul 2015
    Oklahoma City
    Default Thx
    =bob=
    Thanks Bob, I figured it out. There is a small black swing arm that has to be closed right below the red button which fixed it. Thanks for your help.
    Quote Originally Posted by hedgie57 View Post
    Good Idea.... The manual shows a swing arm that has to be engaged that slides under the red reset button. Thanks for your help.
    May 2014
    Olathe, CO USA
    Default Red Button
    OOPs!!! I got that one totally and completely wrong. Glad you got the help needed.
    =bob=
    Sep 2015
    Chesterfield
    Default reverse issues
    It blew the fuse, just pop off the right triangle panel above your right rear tire, there is a red button if its popped up, the fuse is blown, there is a little tiny black tab sticking out under the red button, push that back in until it clicks and put the panel back on, I blow mine because I keep forgetting the parking brake is on.
  11. #10
    700+ Posts Steve on 3's Avatar
    Oct 2014
    Lancaster
    The excellent thing is it appened and now you know how to fix it. I did it too and had been lucky enough to have read the manuals and a post online. another thought is that backing up with your parking brake on is n ot conducive to long pad or rotor life. No need to ask how I know that.
    Just make sure the red parking light is out before you ride away and you will be fine.
    Enjoy your trike
    Steve
    2020 Triglide MidnightBlue/Barracuda Silver
    Just beginning our ride together
  12. #11
    Sep 2015
    Chesterfield
    Quote Originally Posted by Steve on 3 View Post
    Enjoy your trike
    Steve
    When I bought my trike they made me take off the panel and trip the fuse myself so that I would know how to do it. I will make sure the red light is out before riding away, I seem to mostly do it just starting out, so used to just having a kickstand and boom off I go, this has been the only hang up of switching to three wheels.
    Question...do you ever get over that feeling.... on a down hill slope with a corner of feeling like your going to tip? I have only had mine a month and put 500 miles on and I love it and have done alot of twisties but on the downhill tight turns I noticed that I am actually yelling
    Helen
  13. #12
    Quote Originally Posted by radtech40 View Post
    Helen
    I'll tell you what was told to me ... go to a parking lot, do tighter and tighter figure 8's. Just till you tip (just kidding), really helps with the learning curve.
    If you have any reason to believe your trike is not handling right, take it to the dealer and get them to check the alignment. Mine had to be realigned after a belt replacement ... huge difference. I'd bet big money mine was off from the factory.
  14. #13
    Sep 2015
    Chesterfield
    Thank you so much for the advice and for the laugh out loud about tighter and tighter turns until I tip...I was reading and then my mouth flew open and then I realized you were kidding, hahaha. It seems to handle great, I really need to get to a parking lot though and get my confidence up for the downhills I can believe that they can have issues right out of the factory. I bought a Deluxe Softail brand new a few years ago and it wobbled, had it in the shop 3 times until I finally said 'trade it!'
    Helen
  15. #14
    40+ Posts
    Jul 2014
    Bath,MI,USA / Zephyrhills, FL
    Ever wonder why, with a warning light that tells you the emergency brake is on, HD doesn't just lock out the reverse motor, like they lock out the starter when it's not in neutral??
  16. #15
    Sep 2015
    Chesterfield
    Angry
    Quote Originally Posted by scooterbum46 View Post
    That would be a great design, maybe they want you to blow the reverse motor because its a $1,000 replacement. I found out the first time I couldn't start it that it had to be in neutral. I thought that was strange too.
  17. DKCustoms postbit
  18. #16
    1000+ Posts screwball's Avatar
    Santa Clarita, SoCa & Bullhead City, Az
    Have you read all the posts about their trike won't start because there is a lockout on the clutch AND break when it is in gear?? Just what we need is another safety gaget to go bad and strand you
    http://www.triketalk.com/forum/custo...epic4494_1.gif
    Why 3 wheels?
    because 2 isn't enough and 4 is too many
    We are really Steve & Vesta Brown
    Her: 2014 Tri-Glide Me: 2015 Freewheeler
    Vietnam Vet 1967-68 U.S. Air Force
  19. #17
    Sep 2015
    Chesterfield
    Quote Originally Posted by screwball View Post
    Wow, I am afraid to read about it.
  20. #18
    5750+ Posts BillR's Avatar
    Aug 2015
    Gloucester, VA
    Default Parking brake light
    Does the 2010 have a brake warning light? I looked today and couldn't find one on the trike, and saw no mention in the owner's manual.
    Bill
  21. #19
    Sep 2015
    chatsworth
    Default Brake saftey switch
    its the safety switch located under the right side cover where the air valve . I think its black next to a red button just reset it by pushing toward the front on your bike
  22. #20
    4750+ Posts msocko3's Avatar
    Sep 2009
    NE Ohio
    Quote Originally Posted by BillR View Post
    Bill
    No.
  1. 2015 Freewheeler Reverse
    By JohnT1949 in forum Harley Freewheeler / Road Glide 3
    Last Post: 09-29-2018, 09:44 AM
  2. Reverse not working
    By DK Custom Products in forum Harley Trike Conversions
    Last Post: 09-04-2018, 04:15 PM
  3. New 2015 Tri Glide
    By uppercaseJC in forum Harley Trike Conversions
    Last Post: 07-13-2015, 02:15 PM
  4. 2010 TriGlide Reverse Not Working
    By eforman48 in forum Harley Tri Glide
    Last Post: 05-01-2015, 07:39 AM
  5. 2009 Reverse not working
    By tri glider in forum Harley Tri Glide
    Last Post: 08-14-2012, 04:19 PM
