Likes Likes:  1
Results 1 to 10 of 10
Thread: What size weber
    200+ Posts
    Apr 2015
    pineville, la
    Default What size weber
    Going to a single weber on my trike. Type one, dual port, stock motor. Running dual 34epc's now. Everybody says go to weber so here goes. Looking for opinion on size and where to buy. Also how much trouble is it to put the manifold on for the single carb. Does the alternator have to come off.
    900+ Posts Fowler's Avatar
    Sep 2014
    Moneta VA
    I run a single Weber progressive
    I think I have it right now.
    http://www.3fowlers.com/carb.html
    1000+ Posts Rsw's Avatar
    Sep 2011
    Little Hocking, Ohio
    Never delt with them but might be a place to start.
    http://www.webercarbsdirect.com/
    Old Redneck Motorhead
    VW Tech Contributor
    TrikeTalk Moderator
    DeathBySnuSnu's Avatar
    Mar 2012
    Vicksburg MS USA
    Has been a many years since I have run a single.
    Will toss up a few thoughts.
    A single one barrel takes the same tuning as any dual set up. You just have to do it x4 with dual 2bbls. Then x2 with dual 1bbls.
    A big single barrel would be the simplest to tune. A tandem 2bbl on a plenum intake next. Then a non plenum 2bbl. Then the 2 one barrels. Then the 2bbl progressive. Then the dual 2bbls.
    A progressive 2bbl once gotten right does drive real nice. Not bad on gas driving sane, but still has some kick when mashed.
    Sep 2014
    Moneta VA
    Quote Originally Posted by starrider1946 View Post
    I was thinking about this.
    On mine, yes the alternator has to come off because I have the heat risers. The heat risers will not fit past the alternator with it on.
    If you do not have heat risers then the alternator should not have to come off. BUT you want the heat risers. That extra heat helps atomize the fuel and stop icing.
    In fact I have done some other things just to get more heat to my carb and manifold
    Since I have aftermarket Exhaust I made this modification (works good)
    http://www.3fowlers.com/images/photo...t%20risers.jpg
    This seems to help when its real cold also. Now I have heat coming from both sides I just do not have a Pic of it
    http://www.3fowlers.com/warmairintake.html
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Cheyenne Wyoming USA
    Here is the single progressive kit from CarCraft: http://carcraftstore.com/progressivecarbkits.aspx
    However, keep in mind, that no matter where you get your kit or what style you go with, you will need stock end castings:
    http://carcraftstore.com/dualportendcastingkit.aspx
    Sep 2011
    Quote Originally Posted by stinger608 View Post
    You have to be careful of what you buy. Those might be Empi or another China repo.
    1000+ Posts
    VW Tech Contributor
    stinger608's Avatar
    Jan 2014
    Quote Originally Posted by Rsw View Post
    Yep, I'm pretty sure they are the EMPI version.
    "Tin Man" Doug D.'s Avatar
    May 2012
    Vienna, MO USA
    I have a Weber 32/36 progressive on a 1641 cc. A definite improvement over the stock Solex. I had the generator off anyway, and I also had to switch out the fuel pump to get clearance for the Weber manifold. And yes, stick with the genuine Weber...
    Oct 2015
    Conway
    Default Found a good sub
    When I was building my sand rail I went to a Pinto carb 34/36 progressive got it on eBay 40 bucks rebuilt and it is a weber made for ford works great also same bolt pattern
  1. tuning weber idf 40
    By starrider1946 in forum VW Powered Trikes
    Last Post: 05-18-2015, 07:59 PM
  2. what size MPA do I need ??
    By stargzr57 in forum Tires, Wheels, Brakes, Front End
    Last Post: 03-26-2013, 06:50 AM
